Question about LG DU-52SZ61D TV
LG DU52sz61d - Just changed bulb and the picture is still real dim
Except for a two inch vertical strip on the right hand side.
SOURCE: Red Stripe, right side
Follow-up. I found the slip on which the LG tech wrote down the part number for the board to fix the vertical red stripe. I was mistaken in my previous post. It was not the Z-Drive board. The board you want is:
X DRIVE BOARD; Part 6871QRH043A
Type in the part number in a search engine and yuo will find multiple places to purchase. Ebay may be the cheapest. That's where I got another part which got my picture back. I did not buy this part myself because now that I have my picture back, I do not want to screw it up, so I live with the red stripe.
Posted on Jun 06, 2008
Shuttle83
  • 1139 Answers
SOURCE: Very dim picture but bulb is good
Hello onsitecomps/David
With all of this bumping and knocking, still the problem you are having should not be occurring. This is due to the fact that the light engine is basically protected from that kind of activity. Now I feel that I have to explain how the light engine works, because there are a few things I am going to ask you and I want you to know why I am asking you these specific questions.
First of all a light engine works in the following manner:
A digitized video signal is sent into the signal and control bus of a DLP processor the signal is used to activate the transistors that control the mirrors that reflect light from the light source (the bulb) to the screen (more explained in next sentence) of the TV. The light from the mirrors then is reflected into a color wheel which spins at a rate which allows the individual monochromatic lights from the mirrors to be reflected with its proper color sequence (this is what creates the color picture from the monochromatic light from the DLP processor). This is a high level description, yet it is accurate for the questions I am about to ask.
1) Is the color wheel moving? (you can tell because it will make a fan like noise when it is turning)
2) Is the bulb at its proper luminance? (you can tell by using a light meter)
3) Are all the lenses in place? (you can tell by opening the light engine and inspecting the lenses)
4) Is the light from the bulb striking the DLP processor mirrors? (This sounds like what is not happening in your case, this or the processor is bad, being blocked by an obstruction, or out of alignment)
I believe that the last question is what is happening in your case, please correct me if you think that my assessment might be incorrect.
As for doing any of the work yourself, I would advise against this because this is what may have happened in the first place with the first owner. (who knows for sure). I would suggest getting this repaired by a qualified TV repair shop since the placement of these parts and the handling is very critical. If you do plan on doing this yourself you will need the following items:
1) voltmeter (to measure the voltage levels on the DLP processor, and the other points on the circuit board)
2) schematic diagram with service manual (To see where parts are located and to indicate where test points are)
3) light level power meter or you can use a temperature meter and do the conversion formula for watts to lumens (heat energy to light energy)   4) Ohmmeter (to measure resistances of components and circuit devices)
5) Signal generator (to create/generate a reference signal source with which to test against)
Now, if you know what these pieces of test equipment are and how to use them great have at it, if not, my original statement hold true: get a qualified TV repair person to take care of this issue.
I hope this helps,
Thank you,
Shuttle83
Posted on Jul 23, 2008
albertv29
  • 87 Answers
SOURCE: green vertical stripes down right hand side of screen, no picture
Single color vertical stripes are an indication of a defective panel or panel control.
Posted on Jan 23, 2009
SOURCE: the left side of my LG plasma has vertical lines.
It sounds to me like one or more of your buffer boards has gone bad. You will probably have to have it looked at.
Posted on Apr 07, 2009
  • 187 Answers
SOURCE: blue vertical line thru picture
It is called "Thin vertical lines" and change colors depending on the background color.
It is fixable but there are several components that can show this sympton.
You will need a tech to fix it in order to save money (because you do not want to buy a board you dont know if will fix it).
Possible Solutions:
Replace Timer Control Board, if it is not fixed
Replace Sustain Board.
One of those boards needs to be replaced and I wrote the most likely first.
Posted on May 27, 2009
LG vertical line
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
May 15, 2016 | LG 47LV5500 47 Class LED TV with SmartTV,...
Red vertical lines on right side of LED TV set
It is likely the main board that processes all signal to and from the display panel (entire front screen unit).
It is also possible it is the display panel itself which is fatal.
May 16, 2012 | LG 55LX9500 55 in. 3D HD-Ready LCD TV
The right side of my screen at about 3 inches from the side has a vertical bar that is lighter in shade than the rest of the picture. It started as horizontal flickering lines contained in the vertical...
Hello
There must be some loose contact with the t'Con board of your tV. Just look for it. Just unplug and replugh all the strip wires goes to T'Con board. This must solve the problem to your Tv. OK.
Oct 13, 2011 | LG 42LC2D 42 in. LCD HDTV
I have a Sony 26 inch Bravia LCD tv model KDL-V26XBR1.It has thin vertical black and yellow lines about an inch apart across the whole display. Not noticeable from a distance but really see them up...
Well if the panel is bad it would not clear up in any situation, so its not the panel. most likely the t-con board or just poor connections inside. Julio Millenium TV in Las Vegas.
Dec 18, 2009 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
42 inch LG plasma
Check the COF panels if there are SMD resistors on it,resoldering the resisters could fix the problem.
Aug 05, 2009 | LG DU-42PX12XC 42 in. Plasma HDTV
Black strip down the right hand side on my viera plasma
Hello
black strip down the right side its about 2 inches wide there are also red and green flashing lights that is defective shorted capacitor at power inverter board section that was 300uf 200volts.
Angel
Thanks...
Aug 02, 2009 | Panasonic Viera TH-50PZ80U Plasma TV
Been following everyone's advice checking
I would start suspecting a DMD board
Aug 01, 2009 | Televison & Video
Vertical strip paler than rest of the screen
Check connectore for that area, may be loose, release the cable before pulling, and reinstall it. See if that works.
Dec 11, 2008 | Televison & Video
Got a blue vertical line on me plasma
Ohh you have a problem with the PLASMA gass ( RGB balance failiure )..don't switch it on again run to service center....
causes ;- heavy nonstop use, heavy impacts , can have probs from LG factory , we have nothing to do the only advice is run to a service center...don't try to do it yourself ....
so i identified your prob...PLEASE VOTE ME AS "FIXYA" (Successfully solved) for my help
May 29, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Red screen on LG 44-inch DLP
Go to this site, follow the instructions, and it might fix your problems. I did, and my tv is better than ever!
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Mar 28, 2008 | LG RU-44SZ51D 44" Rear Projection...
LG DU-52SZ61D TV Logo
142 people viewed this question
Computer Repairing
Computer Repairing
