Question about Sub-Zero 690 Side by Side Refrigerator
Sub zero 690 ice maker
Already asked in forum and no solution yet. Ice maker doesnt seem to cycle. Checked FAQ. Freezer at 9 degrees, wire down, water ok from front dispenser. Also getting vaccum condenser message even though it is just vacuumed.
  • Anonymous Aug 30, 2008
    same problem, no solution yet either
    Problem Solver:
  • 7 Answers
Also discovered if ice box auger not engaged exactly right with auger drive motor, then ice box won't be able to be pushed back the last half inch to engage the secret "turn on the ice maker" switches. Juice storage brackets also won't engage since ice bucket not flush with front of cover.
Posted on Aug 17, 2008
Sub Zero 690 ice make not working after tripping breaker
Is the "ice" icon displayed on the screen? you have to turn on ice production on a Sub-Zero
Aug 30, 2016 | Sub-Zero 690 Side by Side Refrigerator
Ice maker stopped making ice
If ice maker is not filling with water then fill with tap water and allow to freeze. If ice maker cycles and then does not refill then this points to water control valve. If that happens replace water control valve. Ifice maker does nothing but freeze water to ice then the ice maker will need replaced or parts causing problem fixed. Please call Sub Zero at 1-800-222-7820 and they will refer you to one of their six authorized parts and service centers. Thank You, Sea Breeze
Nov 24, 2011 | Sub-Zero 690 Side by Side Refrigerator
Unit is a 690 S #P1520647, built 1999. ice maker drips water from behind bottom grill near left side of freezer box.
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Jul 27, 2011 | Sub-Zero 690 Side by Side Refrigerator
I have a 12 year old Sub Zero model 624. The ice maker has completely stopped producing ice. And actually, when opening things up we can see ice cubes have formed but they just haven't dumped into the...
This is the procedure but yours seems to be a faulty Icemaker and needs to be replaced since your freezer is cold enough to make ice rapidly.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking same part needs replaced.The water valve at the bottom rear of fridge.
Thank you for using fixya
imufo2
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Jul 27, 2011 | Sub-Zero 642
Not making ice fast enough
Good day,
Assuming the cubes it's making are the proper size, the speed the ice maker produces ice is determined by the temperature in the freezer.
When the ice maker harvests a batch of ice, an electric heater heats up the whole ice maker.
There is a thermostat embedded in the ice maker. It must cool back down to approx. 12 degrees before making the next batch. The colder the freezer compartment, the faster the cycles.
If the cubes are too small then that is usually caused by a blockage in the water filter if your unit has one, or the water valve that feeds water to the ice maker is getting weak, or lastly the water supply to the machine has become partially restricted.
On extremely rare occasions the thermostat built into the ice maker goes out of calibration which can cause a delay in cycling and requires the ice maker to be replaced. But again, it is a very rare occurrence.
Oct 27, 2010 | Sub-Zero Bottom Freezer Refrigerator
Ice maker not making ice
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
Mar 31, 2010 | Sub-Zero 632 / S
In door water and ice cube not working
Water dispenser is a simple touch switch in door energizing a solenoid water valve behind ventilation grate above refrigerator. Water tube runs down into and ends at ice dispenser chute. Should hear solenoid click at top of fridge when activate water touch switch. Can unhook discharge side of solenoid valve temporarily to prove water output. If water dispenser tube acts blocked it could be frozen where it ends-look up the hole at the bottom of refrigerator control buttons.
Ice maker is totally different system. No clicking when push ice button but ice in bulk tray may mean the simplest of malfunctions: Ice bin not pushed in the last half inch if ice auger not lined up with drive pegs. There are hidden switches behind ice bin that need to be engaged or nothing will happen in the ice maker: no auger noise, no clicking, no new ice making. Ice bin will be flush with sheet metal if it is in the right spot. Also plastic juice rack won't hang properly if ice bin not pushed in all the way.
Dec 19, 2008 | Sub-Zero 690 Side by Side Refrigerator
Ice make wont fill or make ice. water is there because you can fill a glass
Jul 19, 2008 | Sub-Zero Refrigerators
ICE MAKER SUB ZERO REFIGERATOR
Check water turned on. check ice button switch turned on in fridge. remove juice storage, ice container in freezer, check ice bucket full white plastic flapper to make sure not stuck on a white peg at top. flapper must hang down and be freely movable to signal ice maker to keep busy. If up high will turn off ice maker. Lots of other parts especially heater circuits involved also: fill tube supply heater not working then frozen supply line then no ice. Look for wiring diagram in ziplock behind compressor grille. can order parts at repairclinic.com. logical design, layout, easy to get to sensors, heaters. makes sense if look at it long enough.
Feb 14, 2008 | Sub-Zero 690 Side by Side Refrigerator
Sub-Zero 690 Side by Side Refrigerator Logo
690 people viewed this question
Top Sub-Zero Refrigerators Experts
Mike Cairns
Mike Cairns
ACME Sub Zero...
ACME Sub Zero...
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
