Please help the copier machine sometimes appear error code E007...what should i do?
  • jeff heightchew
    jeff heightchew May 11, 2010
    Lets see, what brand and model copier do you have? is it a; AB,Copystar,Canon,Gestetner,Konica,Lanier,Minolta,Nashua,OCE,Panasonic,Danka,Savin,Toshiba,Xerox,Kodak,Ricoh,Pitney Bowes,Imagistics,IBM to name a few.Then there are the many models within each manufacturer. E007 means completely different things between manufacturers and often between models of the same manufacturer.
    Sergeant:
  • 329 Answers
Good chance it is a Canon with this code. If it is this code usually means a fuser problem, most likely in the fuser film area May be ripped, etc. Good luck
Posted on Jul 22, 2008
E007-9901. already change new fixing but the same error code keep appear.. help me :(
what driver does it use ? can you print a configuration page from the device and compare the printer languages used. Example PCL 6 , PS . Is the driver matching the accepted languages the printer requires.
Jan 02, 2015 | Canon iRC4580i
Canon iR-2016 System erro E007
The fusing unit needs to be replaced or repaired. Contact your dealer or service person
Nov 20, 2011 | Canon CLC 1140 Copier
I have ir4570 error code e00007
It is my pleasure to guide you.
Your Canon iR 4570 All in One Printer Manual iR4570
User's Guide can be downloaded at http://download.canon.it/manuali_operatore/files/iR4570_USR_ENG.pdf
Look at Chapter 3 Troubleshooting
List of Error Messages ..3-6
List of Error Codes without Messages. . 3-6
You will find the list of error codes.
Also, http://servisfc.blogspot.com/2010/12/detecting-error-e007-for.html
gives the following;
QUOTE
Detecting Error E007 at canon copier iR2270, iR2870, iR3570, iR4570, iR3530.
As part of its protective mechanism, the machine checks for the following error conditions.
Error Code: E007
Detail: 0000
Sympton: The fixing film rotates in an abnormal way.
Description: The reading of the main thermistor is in excess of 100 deg C with the fixing motor in a locked state and in addition, the machine fails to detect the marker signal for 6 second.
UNQUOTE
Good luck and please post back that you are successful, giving thumbs up, or that I can be more helpful.
Jun 09, 2011 | Office Equipment & Supplies
My canon iR 2022 is displacing the world System Error E007. If you put a paper, it also jams. What to do please ?
Canon fuser technology is hp laser printer system.This copier has a fuser film or eleventh cover.Some times its torn or short then this machine say E007.Its an error code.When occurred this E007 you should defective film.
Feb 14, 2011 | Canon iR 2022 Printer
My iR2016 displays "system error E007, would you please help me repairing it?-
it error code means fuser unite problem please change fuser unite then solve your problem
Nov 20, 2009 | Canon PC-940 Black and White Copier
I have System error E007 problem in my Canon iR-2016 copier machine
System error e007 for canon copier ir2016j copier needs solution
May 23, 2008 | Sharp AR-M350N Copier
The erreor code E007 has to do with the fixing ***'y upper film ***'y or roller. It is saying that the film is not moving in and out of "HP" Most of the time it means that the fusing film is torn and not moving properly. If you are getting paper jams in the fusing area and or unfixed or smeared copies. You most likly need to have the fusing film ***'y replaced. It could also be that it is out of place and needs to be readjusted. The only problem is that it's a little tricky to get to and not a bad idea to have a new film to replace the old one while you have it out. Good Luck
Mar 15, 2008 | Office Equipment & Supplies
hi how do solve this problem system error E007
Dec 04, 2007 | Canon CLC 1140 Copier
54 people viewed this question
jasbo
jasbo
