Back to:
Tags:
Kenmore Oasis HE 27082 Stainless Steel Top Load Washer
Kenmore oasis long fill
posted by missy22961 on Jul 19, 2008
what can I do before I call service for an LF code on my oasis washer?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Oct 05, 2008
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
The electrical conections to the fill solenoids on the machines are terrible. Thw wires are twisted onto the tabs of tghe solenoids and covered with a plastic piece. to fix tyour problem take off the plastic pieces and solder the wires to the tabs on the solenoids
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on kenmore oasis long fill:
I don't want to Accept this solution
Solution #2
posted on Jul 27, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
Check your hot and cold water supply hoses for residue buildup that restricts the flow of water.....there is a small metal screen filter that clogs up ....most likely the cause if your pipes are old and the inside walls are shedding deposits into the water line.
Thank You!
Can you Help with these Washing Machines problems?
Kenmore Oasis HE 27082 Stainless Steel Top...
The cycle signal volume doesn't stop bepping.
Doing laundry a clothe got trapped underneath the...
F1 shutting off have to adjust load and reset a number of...
where is the location of the lid switch on the kenmore...
my washer stops working and give an F1 with blinking...
Loading problems.
Repair Service
Find Washing Machine Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
