posted by victordykes on Jul 19, 2008
Electrical - motors is running
but no suction - changed bag and cleaned cloth filter
Solution #1
posted on Jul 20, 2008
Is there suction where the pipe hooks to the cannister? If so, then are all of the outlets without suction? Maybe the hose is plugged. If the hose is ok, and there is suction at the cannister, then **** up a small **** of paper, one for each room outlet, have a number on each piece of paper, Which ever one doesn't ,ake it thru to the cannasiter is the outlet that is plugged. You can use a plumbers snake to clean out a clogged outlet or even a clogged hose.
If the motors are running and sound ok, then there has to be suction at the outlet on the cannister. If the filter bag is old, it may be best to replace it with a new one.
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To:
GE 106766 Bagged Canister Vacuum
Black & Decker CFV9600 DustBuster Bagless Upright Vacuum
Black & Decker CHV1500 Bagless Handheld Cyclonic Vacuum
Bosch BSA2200UC Compact Plus Health Guard Bagged Canister Vacuum
Bosch BSG81215UC Beetle Dual Tech Bagged Canister Vacuum
Electrolux Envirosteamer 370A Canister Vacuum
Electrolux Eureka Upright Vac Maxima Bagless 1 eaVacuum
Can you Help with these Vacuums problems?
Hoover F6212-900 / F6215-900 SteamVac Agility...
It wont **** the water
what could I do to fix it? Answer This...
Repair Service
Find Vacuum Repairman Near You:
