Thanks, George Just two things. 1. Where do I find the information regarding the correct size of the casing. And 2. What would happen if I "initialized" the  external HD by hitting that option on the error message? Thanks, Abrum
  • abrum Jul 19, 2008
    OUTSTANDING, KNOWLEDGEABLE EXPERT! MANY THANKS!!!
    Abrum
  • abrum Jul 21, 2008
    Hi George.  Well, the odds were against me. It turns out it wasn't the case on my HD Acomdata backup HD afterall. Got a new one (made by Rocketfish) and my computer (MAC G5) still says this computer doesn't recognize inserted disc. So, I tried disc firstaid and it came back the  source disc needs to be repaired. Stuck in mud, Abrum
  • 304 Answers
The Hard drive in your case is either 2.5" or 3.5". You will be able to tell right away. My next suggestion is to bring the actual hard drive with you to circuit city, or best buy and have an associate confirm which case will meet your needs. Do not skimp on your case either. There is a reseon some cases are more expensive than others and the main one is the quality of the components and their durability.
In the inoperative state of the controller initializing will have no effect on your data. Even if you formatted the disk your information would still be there and I have software that could restore your data even in that most of extreme cases.
Any other question feel free as usual, I'm online until midnight tonight. Don't forget to rate me. Half the people don't even appreciate my help enough to click a button.
Talk to you soon.
George
Posted on Jul 19, 2008
  • George Kohler
    George Kohler Jul 21, 2008
    I'm glad you found my solution Helpful. In return I ask you
    to go to my profile and read and rate some of my other solutions. I put
    25 years of experience, 3 years of Deans list University Dual Degree's
    in Business Management/Computer
    Science, 2 Years of Tech School for
    Industrial 3 Phase Wiring, Founder of three major businesses and 1 hour
    of research into nearly every
    post barring the short and obvious. As my post helped save you, I ask
    you to help some others by weeding out some of the garbage that winds
    up slipping though here. Some of the posts even involve "experts"
    recommending owners of powerful dangerous vehicles do a cobb job fix
    instead of repairing the advanced handling system specifically designed
    for the safety of the vehicle. This is like advising an F-16 pilot to
    scrap the fly by wire system in his Jet fighter and installing a cable
    system to his flight controls.
    Please take a few minute and go to my profile and go through
    my
    unrated posts and rate them objectively and fairly and you can help
    some others the way I helped you. Check out some of the comments on my
    online chats. You will see I'm constant and Your case was not just a
    fluke.
    Thanks,
    George
  • George Kohler
    Feel free to contact me at geokohler @gmail and I will finish helping you with this problem for free. Send me your number.
    George
Hi, the USB connection on the hard drive has come loose, how do I fix this? Do I need a new case or housing? Thanks
Yes sir it can, and your first conclusion was correct. The external enclosure itself is replaced.
There are two types of harddrives used at present. The old technology of IDE (PATA), and the newer technology of SATA.
You have a 2TeraByte Western Digital harddrive. (2.0TB)
Due to it's size I know it uses the SATA technology.
However look on the harddrive's label, and see if it states SATA, or look up the manufacturer code on the label, on the internet.
Example; WD2500BEVS
Western Digital harddrive that is 250GB in size, and uses the SATA technology.
Harddrives also come in two main sizes.
Laptop computer harddrives are 2.5 inches across in width.
2-1/2 Inches.
Desktop computer harddrives are 3.5 inches across in width.
3-1/2 inches.
From the camera views I can see it is a desktop size harddrive.
So,
1) SATA
2) Desktop size harddrive - 3.5
If the above holds true you need a 3.5 SATA external enclosure.
This is but one example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3672394&CatId=2780
The external enclosure has the small interface circuit board, with the USB cable attached to it.
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 31, 2012 | Computers & Internet
L7157 HP Laser Jet P2055
Unfortunately, this is a common problem. I suspect you're using MS Word to make the labels. Word takes the font and the dimensions of the labels and is supposed to transfer the correct sizes of everything to your printer. All to often it doesn't do this correctly.
One thing to try is a couple different fonts to see what happens. (use plain paper to experiment, it's cheaper.)
The other way is to set up a regular page in MS Word with 3 columns and fill the page with copies of your information. The trick is to adjust the font size on the empty lines between your information.
address line 1
line 2
line 3
[font size adjusted empty line]
address line 1
line 2
line 3
May 31, 2012 | HP LaserJet P2055d Printer
What size gas connector do i need for maytag gas dryer pyg2300aww
The size where the nipple that ya connect to that sticks out the back of dryer is 1/2inch..now your gas pipe in the house could be 1/2" or 3/4" so in that case if it is 3/4 you would need 1/2" connecter at the dryer and a 3/4" by 1/2" reducer to connect at your house gas pipe
while i am all about the can do spirit... certain things that if done impoperly can blow up your house should be done by professionals that will do it correctly
Aug 24, 2011 | Maytag PYG2300A Gas Dryer
I installed 2 new banks of 512 MB RAM in my COMPAQ PRESARIO S3000NX. The COMPUTER PROPERTIES SHOW INSTALLED RAM TO BE 480 MB ( Not 1GB as I expected) Why is this happening? George McGeachie...
Your bios may need to be flashed so your motherboard with recognize the ram. It also may be fixed by adjusting the speed of the ram in your bios settings. Be carefull and read about doing both of these procedured in your mainboard manual( should be able to get a manual from the compaq site if you do not have one).You can mess up your computer real good if things are set or flashed wrong. Good Luck
Nov 22, 2009 | HP Compaq Presario S3000nx (DC475A#ABA) PC...
CanoScan LiDE 20 started stretching image at the beginning of the scan, continuing just fine afterwards. Bottom part of the image (in my case a letter-size page) will not fit, about 1/4 of an inch would be...
Hi pallada,
This might be a case where we address the symptoms rather than the problem.
Instead of positioning the paper to be copied at the normal position, drop it down to the 2" mark. Then on the preview screen, adjust the area to be scanned down accordingly.
This should allow a full letter size scan with no loss, truncation or stretch.
Best regards,
Mike
Jul 18, 2009 | Canon CanoScan LiDE 25 Flatbed Scanner
Total size is not 80 GB IDE Hard Drive
Two possible solutions but both calls for another software/utility.
1. Use FDISK but you should be booting and running in DOS mode;
2. the other is Partition Magic which runs under Windows environment.
The idea is to delete the existing partition (that shows only 31.50Gb) and thereafter re-partition to the full capacity of the drive. of course doing so would erase the contents. Further, a format after the re-partition is required.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 19, 2008 | Seagate (ST380011A) 80 GB IDE Hard Drive
Wheelwriter 10 Series II doesn't work
My repair book shows:
1 Make sure the printwheel in installed correctly. 2. make sure the ribbon and correction tape are installed correctly 3. turn the typewriter off wait 30 seconds then turn back on if the same thing happens install another printwheel. 4 turn the typewriter off wait 30 seconds then turn it back on if the same thing happens call for service.
Jan 17, 2008 | Lexmark Wheelwriter 10 Series II...
Ejecting of harddrive
The only reason for the display "generic volume cannot eject now, try again later" is because it is still being accessed by your PC. This may be due to considerable large file size being transferred and/or being backed up, virus scan, a utility is still doing its work.
To answer your concerns:
1. Will there be a problem ...
Normally no, but yes it does happen. It happens when the actual physical removal of the USB connector(s) is not a continuous single motion.
2. How do you eject ... Shut down/power off your PC, once off remove and reboot.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Jan 12, 2008 | Seagate FreeAgent Go 120 GB USB 2.0 Hard...
Cobra pr250 2 way radios
Pls verify that both radios are:
1. within range of each other;
2. channel selection is identical;
3. CTCSS Privacy Code is identical;
4. Call Tone is identical;
5. Receive icon appears when the other radio's PTT is pressed;
6. Auto Squelch/Max Range is set to receive even weak signals.
Please correct settings if needed.
In some cases, it is the internal speakers that goes bad.
Hope this be of help/idea. Post back how things turned up or should you need additional information.
Jan 07, 2008 | Cobra PR-245/2 (7 Channels) 2-Way Radio
Monitor is enlarged, wont return to normal size
Hi, three possible things. 1) You have activated the magnifier. Go to Start, All Programs, Accessories, Accessibility, Magnifier - deactivate, should be a small window bottom left of the desktop. or 2) Your screen resolution somehow changed. Right click on any clear part of the desktop, go to properties, Settings Tab. Adjust screen resolution to desired setting then click Apply/OK. or 3)You are in Safemode. Restart and if same large icons etc, do # 2. Hope that this be of some help to you. Pls post how things turn up. Regards
Apr 27, 2007 | Gateway FPD1960 19" Flat Panel LCD Monitor
Computers & Internet Logo
120 people viewed this question
David Payne
David Payne
