Depends on the type of OEM radio you had in the system before the replacement. Your car may have an auxiliary amplifier between the radio and the speakers, and if so, you may have to bypass it. In any case, have a look at the original wiring diagram (Alldatadiy.com will probably help) and check your wiring again.
ANSWER: The USB is not going to work with your iPod. It is intended to be used with a flash drive or external hard drive with a folder structure containing either .mp3 or .wma files.
REASON: The way the USB works on the system is that it reads all the files and folders on the entire device and will say "reading" until it reads all the files and folders. This should only take a few seconds but if there is tons of files it may take longer. Main problem: An iPod contains much more than just music files and folders - it contains an entire operating system. Worse, the operating system which the iPod uses is protected, keeping other devices except for iTunes from reading the music files.
SOLUTION: You will need to use a flash drive or external hard drive with your USB. This device can only contain music, and the music must be organized into folders. Your iPod will not work. However, you can use Auxiliary input using a cable which both ends are 1/4" headphone jacks, one end going to the iPod and other plugged into your stereo. Good Luck! - Chris Proia p.s. Here is the User Manual for your XDM6350 : http://www.dualav.com/support/manuals/xdm6350.pdf
1988 Ford F150 Truck Car Radio Wire Color Codes
Car Radio Battery Constant 12v+ Wire: Green/Yellow Car Radio Accessory Switched 12v+ Wire: Yellow/Black Car Radio Ground Wire: Red or Black Car Radio Illumination Wire: Blue/Red Car Stereo Dimmer Wire: N/A Car Stereo Antenna Trigger Wire: N/A Car Stereo Amp Trigger Wire: N/A Car Stereo Amplifier Location: N/A Car Audio Front Speakers Size: 6? Car Audio Front Speakers Location: Doors Left Front Speaker Positive Wire (+): Orange/Green Left Front Speaker Negative Wire (-): Black/White Right Front Speaker Positive Wire (+): White/Green Right Front Speaker Negative Wire (-): Black/White Car Audio Rear Speakers Size: 6? x 9? Car Audio Rear Speakers Location: Rear Corners Left Rear Speaker Positive Wire (+): Pink/Green Left Rear Speaker Negative Wire (-): Pink/Blue Right Rear Speaker Positive Wire (+): Pink/Blue Right Rear Speaker Negative Wire (-): Green/Orange
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
The COIL PACK TOWERS are numbered :
coil----3---4
pack---2---6
plug----1---5
The engine cylinders / spark plugs are numbered :
passenger side , front to rear , 1 , 2 , 3
-----drivers side , front to rear , 4 , 5 , 6
The spark plug firing order is ( 1 -4 - 2 - 5 - 3 - 6 )
