Question about Dell Latitude D820 Notebook
Dell Laptop Battery
I am about to go on a bus trip and I will be taking my laptop. It is a 12 hr. ride. I know that my laptop battery is only going to last about 4 hrs. I will be accessing the Internet on it and watching DVDs. I need to know if there is a power source I can purchase to provide me with more battery life; or is the only option is to purchase an extra battery?
    Genius:
  • 2,028 Answers
Another battery is your only option. Check with the bus service to see if they have outlets at the seats. I know that a few bus companies are providing outlets on their buses for customers with laptops and other devices.
Posted on Jul 19, 2008
  • 1,031 Answers
Watching dvd reduces the the battery power especially when its uesd simultanously with other computer application that may reduce the hrs but since your mobile you need a portable device,and the option is to purchase another battery with more Ampere Hour (AH)rating that will last for longer hours more than 4hrs
How do I determine the battery pinouts for my Dell Inspiron 1526
the pin outs for the batteries in general are:
1 +Batt - Battery output voltage
2 SMB_SDA - System management Bus Serial data
3 SMB_SCL- system managemant bus Serial Clock
4 Batt_temp - Battery temperature monitor
5 battery_present or Battery ID
6 GND - ground
the SMB_SDA & SMB_SCL are used by IO controller chip in mainboard to communicate with the battery( battery type , charge level), and you can not use other model laptop batteries because it will not match with the bios whitelisted battery type.
no way you can fake the battery, instead you can flash the bios by modifying the flashing programs config.ini file so that it ignores the battery
Jun 24, 2014 | Dell Inspiron Computers & Internet
Tip
Lower replcement laptop battery and adapter
Something I had not heard was to take out your battery when you are plugged into a wall outlet. If you are working on AC power, then it’s not necessary to have your battery in the laptop. Overcharging can also present problems for your laptop battery.
Another problem I know is that the cords on the dell inspiron 5160 battery packs get damaged causing the user to have to purchase a replacement cord. Make you purchase the correct wattage cord because using a higher wattage than what the laptop calls for can damage the battery and possibly the motherboard.
Keeping your battery contacts free of dust and debris is important. When you remove your battery, take a little rubbing alcohol on a cloth and clean your contacts real good. Make sure the contacts are dry before you insert the battery back into the laptop and you are good to go!
Where laptops are concerned, I have always heard dell inspiron 5150 battery one question asked by owners. They want to know how they can increase the life of their battery. Having a full day charge in your laptop is difficult, but here are a few tips to extend your batteries life.
Try not to let you laptop get hot. This is a main cause of battery failure. The fan inside your laptop is designed to keep the inside of the laptop cool. Do not sit your laptop on a soft surface like a pillow or a blanket, better to have a cooling pad for your lap.
on Mar 31, 2010 | Computers & Internet
Tip
My dell pa 12 won?t start ?
When i start my dell pa 12up and it takes 10 mins to load to windows XP, , when the windowsloading screen comes up the FANS go crazy. I then wait till i’m at thedesktop at which point i immediately shut down the pa 12(which takes afurther 7 mins) while the FANs are going crazy.
answer :
Now if i start the pa 12 again it works normally.
I had to do this procedure everyday, untill today when i switched the pa 12 on, waited till the desktop appaered and i removed the battery while the pa 12 was on..
Now when i switch the pa 12 on it powers up but i’m not getting anything on the screen
First try a different AC adapter (such as :pa 10 ac adapter)
If no change then the issue is the motherboard. Often the AC adapter will fail then the battery discharges and you get the symptoms youdescribe.
SO AC adapter then MB
It shows no power on your laptop but it shows you the dvd player led comes on then off.
I would suggest try the following:
1. Remove laptop battery, optical drive, hard drive and ram. Remove external peripherals as well.
2. Make sure AC Adapter is not yet connected to the laptop. Pressand hold on the laptop’s power button for 10 seconds to drain the powerflea.
3. Connect the AC Adapter to a known good power outlet, check ACAdapter power LED if it is on. Try to sense if AC Adapter is not makinga bit of noise when it is plugin to the wall power outlet.
4. Connect now the AC Adapter (hp dv6000 ac adapter)tothe laptop. Check if AC Adapter LED stays on when it is connected tothe laptop. If the LED stays on means the AC Adapter is fine. If the ACAdapter LED turned off check the AC Adapter pin that goes to the laptopAC socket if it is loose.
5. If laptop AC Adapter stays on after connecting to the laptop try topower on laptop. If no power LED comes on then this is motherboardproblem.
6. Before replacing the motherboard there is one checking needs todo. If you can open your laptop bottom part then good, do this whenlaptop is not connected to any power source. Try to reseat the laptopCMOS battery then try to power on laptop after, if still fails thenreplace motherboard. I hope this helps.
on Feb 09, 2010 | Computers & Internet
Should i turn my laptop off when i am not using it?
Yes you should, to save battery/electricity and to prolong it's life.
Jul 18, 2011 | Dell 0Y3740 Keyboard
Mine is dell latitude d620 laptop.battery is new.problem is it was running both on ac and battery.suddenly battrey is not taking the charge but my laptop runs on ac power. can i remove the battery and run...
the batteries eventually wear out and quit taking a charge. You can run the system without a battery with no ill effects. replacements are about $100 for a new battery
Sep 27, 2010 | Dell Latitude D600 Notebook
How long do I have to put a new Vostro 1015 on charge before I start using it?
You can use it as soon as you plug it into the mains.
You may need to give it a 12 hr charge the first time before you use it on battery.
DO NOT use the laptop constantly plugged in, this will damage the battery.
Charge the battery and then use it on battery as much as possible
Sep 10, 2010 | Computers & Internet
Have battery and plug in for laptop. the laptop begin to start with the Dell page, then shuts off. the battery icon shows red like charging but them just shuts off . If I take battery out, no power at all.
This sounds like a problem with the AC charger not providing enough power. The battery never charges enough to maintain power during boot. See if you can borrow a charger to check (maybe from a local shop), or buy one (since you'll probably need one anyway). Don't over pay. I see them on eBay for $12 or so. I bought one recently from a local shop for $25. That should give you a ballpark price. Post your zip code, maybe someone here can help you.
May 06, 2010 | Dell Latitude D600 Notebook
Dell Inspiron B130 Battery Problem
Sounds like the cells in the battery went bad. Try to turn on your laptop with just the ac adaptor hooked up and your battery out off the laptop to make sure that your ac adaptor is working properly. If you can boot up into windows with just the ac adaptor hooked up then you know your ac adaptor is good.
If you get that far then try a different battery and see if the laptop charges with another known good battery. If it does then you know your original battery is bad. If it doesn't charge your different known good battery then you know the motherboard is bad. Hope this helps.
Ben
May 26, 2009 | Electronic Arts The Lord of the Rings: The...
Laptop battery won't stay charge, need battery relearning instruc
This process will take a lot of time and money, its better to buy new battery.
Apr 23, 2009 | Dell Inspiron 9300 Notebook
Resource Conflict - PCI Network Controller in Slot 02
check for an update of bios on acer.com it will fix your laptop problem....
Apr 24, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Dell Latitude D820 Notebook Logo
69 people viewed this question
Alun Cox
