Question about Dell W3201C 32 in. LCD Television
No sound i need a audio output circuit but cant find one do you have any idea where to get one ??
Help, I have a Dell Television that has no sound, do you have a solution?
Posted on Oct 08, 2008
I have an Insignia Tv cant get any audio any ideas
Check the speakers. If found OK check and replace the damaged components at its audio output stage circuit. If you wish to get more details visit the site linked here. http://electronicshelponline.blogspot.com/
Feb 28, 2017 | Insignia Televison & Video
Sound on samsung plasma tv. model #hln617wx/xaa
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience
http://electro-medical.blogspot.com/
Mar 08, 2016 | Samsung DLP HL-P5663W 56" TV
I cant get sound out of my tv
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Mar 11, 2015 | Televison & Video
I have a 2010 cobalt lt. Today both my feont speakers quit working. And now my turn signals make no noise. Or the door chime or the seatbelt indicator does not work. What causes this and how do I fix it?...
The chimes an turn signal noise come out driver door speaker . Both front speakers not working could be a blown circuit fuse inside the radio or just blown front speaker channel . Your best bet , take it to a GM dealer or someother qualified repair shop . You have no idea of the complexity of this . The radio can set DTC'S - diagnostic trouble codes , believe it or not !
DTC B1025, B1035, B1045, or B1055
DTC B1025 01: Audio Output 1 Left Front Circuit Short to Battery
DTC B1025 02: Audio Output 1 Left Front Circuit Short to Ground
DTC B1035 01: Audio Output 2 Right Front Circuit Short to Battery
DTC B1035 02: Audio Output 2 Right Front Circuit Short to Ground
DTC B1045 01: Audio Output 3 Left Rear Circuit Short to Battery
DTC B1045 02: Audio Output 3 Left Rear Circuit Short to Ground
DTC B1055 01: Audio Output 4 Right Rear Circuit Short to Battery
DTC B1055 02: Audio Output 4 Right Rear Circuit Short to Ground
Each of the audio output channel circuits (+) and (-), at the radio and audio amplifier have a DC bias voltage that is one half of the battery voltage. When using a DMM, each of the audio output channel circuits will measure approximately 6.5V DC. The audio being played on the system is produced by a varying AC voltage that is centered around the DC bias voltage on the same circuit. The AC voltage is what causes the speaker cone to move and produce sound. This voltage will vary depending on what type of audio is being listened to, talk or music, and type of music, as well as the volume setting of the system. Low volume and talk settings will measure around 1V AC and less, where constant music may measure 3V AC and slightly higher.
DTC B1287 01: Amplifier Control Signal Circuit Short to Battery
DTC B1287 02: Amplifier Control Signal Circuit Short to Ground
DTC B1287 04: Amplifier Control Signal Circuit Open
The radio provides a remote amplifier mute output circuit to control overall muting of the remote amplifier. The amplifier receives pulse width modulated (PWM) signals on the control circuit at varying duty cycle percentages for controlling muted and unmuted functions of the amplifier. Circuitry internal to the radio monitors the remote amplifier mute circuit for faults and sets the appropriate DTC when faults are detected.
Feb 16, 2018 | 2010 Chevrolet Cobalt
We cant hear sound in videocon t v.do you know how to solve this problem
Check whether the audio is muted or not, in the audio setup; If it is not muted, check and replace damaged component/s in its audio output section. Before doing anythng to circuit, check the speaker first.
May 14, 2013 | Televison & Video
My Toshiba 36" CRT TV has no sound any ideas?
Check its speaker and audio output section circuits for the fault
Sep 07, 2012 | Toshiba CF36G55 36" TV
Kdl-32v4000 sound
Check the speaker first. Check if there is any sound output comes from the audio out terminals at the back of the TV, by connecting them to any external audio out devices; such as an amplifier or so. If there is audio output comes from the external source such connected, and no audio output from the TV; since the speakers are good, the fault is with the audio output section circuit inside the TV. If there is no audio output from the external sources too, the fault is with the audio processing section circuit at the main board. If this is the case, main board is faulty, and should be replaced.
Aug 07, 2012 | Sony Bravia KDL-32V4000 32 in. LCD TV
No sound
Test on the audio output amp for a tone, check on speakers, if there is a tone you have a front end fault which could be the audio processor. If ther is no sound connect from the audio output to an amplifier for an output.Then you are lucky.... Hope it works.
Jul 01, 2010 | Samsung HP-R5072 50 in. Plasma HDTV
Hey hows it goin my Philips flatscreen TV is not ouputting any sound and i cant figure out why! its a 32PFL7532D/79 please help!
ok fist thing first do u have the mute on the tv set ? 2nd thing can u get audio out of the video and audio output jacks one way to find out is take the audio jack and run it to a stereo or your computer should have a audio input jack to see if any audio is coming out of the if circuit of the tv. if it is and u have sound thru the video and audio outputs then u may have blown the audio output ic in the set . please let me know how it whent marty
Oct 13, 2008 | Televison & Video
Toshiba 42H 94 speker sounds like its underwater
There may be a fault with the speaker driver, or the output stage circuits, or the audio decoding circuits.
Without proper troubleshooting, it is impossible to pin-point the exact fault.
Jerry G.
May 16, 2008 | Toshiba 42H81 42" Rear Projection...
Dell W3201C 32 in. LCD Television Logo
44 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
CoppellTVRepair.com
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
