Question about Hoover Dryers
How to wall mount hoover clothes dryer 3525D?
3 Suggested Answers
ginko
  • 19396 Answers
SOURCE: Hoover clothes dryer 3.5 kg 3525D stop working
If it does not even start then it is power supply.
If it stopped running at all then it is probably the motor.
If it runs but not dries is the heating element to be replaced.
Post make and model to get parts and diagrams
Posted on Apr 23, 2008
SOURCE: Hoover 3525D clothes dryer
The most likely cause is a faulty start capacitor. I obtained a new one for $22.00AUD from a local spares shop. You have to remove the back and then the motor mounting plate to get access to it as it is behind the mtr when viewded from the rear I had to remove the long wires from the connector block to attach the replacement directly. You will also need a cable tie to attach it.
Be carefull and make sure the dyer is unplugged as lethal voltages are present.
Good luck
Posted on Dec 15, 2008
Westinghouse dryer LD505E is to be mounted on a brick wall ,what size rawlplugs & screws are needed .I bought the wall bracket mounting kit
that unit does not have wall mounting information its user manual
or a wall mount bracket supplied with that dryer
its a 5KG dryer by the looks of it
thats means its load a with 5kgs of wet clothes on the floor
suggest to me its no meant to be wall mounted
http://laundry.manualsonline.com/manuals/mfg/whitewestinghouse/whitewestinghouse_dryer.html?p=7
wall mount kit might be say suit most dryers
you have to go by common sense
use bigger mountings and fixings that you think it needs
has to hold up on the wall
this much weight
the all up wet weight of clothes
the dryer dry weight empty
and steady any vibration with the rotation on full load
into wood walls depends on the thickness of wood
if into dry wall ...need to hit the wall studs centre
I would not try it
if going into brick concrete ...hammer drill in and . ranset bolts
Sep 16, 2016 | Dryers
Can I wall-mount a Hoover Aqua vision tumble dryer?
Depends on the wall. Unless solid masonry it would be better standing on floor-standing racking or a platform.
I mounted our half-size dryer on a home-made shelf above our chest freezer as a space-saving measure and given the space and a very substantial wall there is little reason why a full-size dryer should not be similarly mounted.
The cabinet of the dryer is not rigid enough for direct wall mounting (if it was it would be far too heavy) and so it must stand on a shelf strong enough to support the weight of the machine and the load and the shelf must also be capable of absorbing a certain amount of vibration and be purpose-built to prevent the machine rolling off due to the vibration or internal forces.
I don't know of any commercially-built shelves for the purpose so one would need constructing, probably from a mixture of timber and steel or aluminium and the whole very firmly anchored to the wall with through-bolts if possible or resin-bonded anchors or similar. Ordinary plugs and screws would not be suitable.
Jul 22, 2016 | Hoover Dryers
Hanging Hoover Apollo Deluxe dryer unit from the wall
you will need to get a wall mount bracket. I found a couple on ebay for about $30.
Sep 30, 2009 | Hoover Dryers
Hoover 5010D dryer
There should be two rectangular holes about 2mm wide and 10-12mm long. There is a wall mount bracket [D470] which you install against the wall and then the hardest part is getting the dryer on the bracket.
Obviously when installing the bracket make sure that the wall and the screws can hold at least 30kgs.
Jul 18, 2009 | Hoover Dryers
Hoover Apollo Delux not drying properly and takes ages. Outlet air is hot but my wife says it's not drying as well as it used to. The front filter is clean but is there an inlet filter that I'm overlooking...
T^o much lint in duct work, causing moisture and not allowing cloths to dry. Vacuum out duct work in dryer and from dryer to outside of home.
Jul 17, 2009 | Dryers
I have a wall bracket on the laundry but hjow do I get the dryer on to the bracket
Is the wall dryer bracket, the correct one to fit your hover
May 28, 2009 | Dryers
Condensation is forming on the walls when I use my clothes dryer
Simpson may have a kit available for accomplishing this. Also, your dryer may have several optional ways of venting.
Mar 27, 2017 | Dryers
Hoover 5050ed clothes dryer/tumble dryer
If the dryer hasn't been mounted before, you'll need to punch the blank slots through. At the bottom of the dryer (because you wall mount it up-side-down, so these slots will then be at the top), you'll see a vertical hole in one layer of the metal on the back to each side. Knock these through to reveal the holes where the bracket can go in. You'll also want to replace the control panel decal with the wall mount one that has all the controls up the correct way when wall mounted.
Jun 04, 2008 | Dryers
Good luck
May 05, 2008 | Dryers
Apr 23, 2008 | Dryers
Dryers Logo
328 people viewed this question
Top Hoover Dryers Experts
Tim Whalen
John Tripp
John Tripp
Are you a Hoover Dryer Expert? Answer questions, earn points and help others
