Teac 3-head / 3 motor cassette deck problem
Howdy,
I've got a problem with the motor which runs the head lifting mechanismon a Teac V-770 3 head / 3 motor deck. Circa mid 1980's. Perhapssomeone with experience in this area can point me in the rightdirection. It won't quite fully lift the heads and pinch roller intoplace, and thus the unit won't play or record. If I give the beltdriven wheel a little help with my finger, the mechanism fully liftsand all is fine. Everything moves smoothly, is clean and lubricated,and the belt isn't slipping. The motor is driven by a BA6209 driver ICwhich is powered by 14 vdc. The output of this IC to the motor isexactly 10 vdc. Would anyone know if this is the correct voltage to runthis motor? I don't have a service manual, but I've found a websitewhich can supply one if need be, I was just kinda hoping to find a kindsoul here who knows a thing or two. I'm an electronics guy myself, butnot in this field, so feel free to get technical.
Thanks,
Larry
  • 1,252 Answers
Hi Larry,
I have worked on similar units just recently. Three things can be at issue here. 1 is the lubrication of the slide plates of the mechanism, 2 is the belt is loose and this is called a cam belt you can get them from MCM for around a dollar. 3 is a problem I found while working on these decks and that is not that easy to resolve but it can be fixed. I determined in the unit V750 that I was working on that the cam motor made a noise. This motor was taken out to see what was going on and I found that the unit shaft had become sloppy at the rear end where the brushes are due to the front having a brash bearing but the support in the rear was nylon. I then secured with some research a much better motor from an Electronics firm and installed it but it did need new 3mm screws and a little modification of the mounting plate- which can be done with a drill. I mounted this new motor and everything ran perfectly AND the new motor had brass bearings at both sides. Why do I know all this stuff? I am a past Lead Technician in Chicago from Teac corporation and I am still working on deck full time.
Posted on Sep 07, 2012
  • 1,512 Answers
Hi Larry
Sounds like you have a drive belt problem. Can you hook a cotton wool bud moistened with alcohol under the best to give it a clean.
You may need to replace the capstan belt to get the deck working. It will also be playing a little slow if the belt is shot. New belts can be purchased as a kit from here for $19.00 plus shipping,
I am more than happy to answer any other questions you may have about it, please get back to me here, or use the ASK function to go straight to me :) If you are still unsure, have problems, or we need to look at the situation more deeply, then before you give a rating for this advice, hit the ASK button Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Posted on Jul 27, 2008
Shows err 3 on power up.
It could be belts or internal cam motor contact sensors. The transports that Teac sells are not direct replacements and DO NOT WORK.
Sep 02, 2014 | Tascam 302 PRO DUAL CASSETTE DECK Single...
I want my teac w600ro pla y deck a then deck b then stopyt
The unit needs work but it might not be worth repairing- that is up to you but most dual cassette decks were very poorly made units. That is why I always steer people away from them. I worked at Teac in Chicago and in fact still work on decks now under the skywave tape deck repair if you were to look me up.
Apr 16, 2014 | Beltronics TEAC W-600R Home Double...
Repair manual for TEAC R-H500 Cassette Deck?
I think I got mine from owner-manuals.com for about $5.00
http://www.owner-manuals.com/index.php?main_page=index
Jun 08, 2013 | Teac R-H500 Dual Cassette Deck
Teac w-505r How good was this unit new
It is a Dual cassette which is one mark against it and it is a light weigh deck. These were made for profit purposes not for a long lasting cassette deck. As I have said from the day they came out stay away from Dual cassettes as they are nothing but junk and you are getting this info from a repair technician of 40 years that has mainly worked on tape deck. I also worked at Teac Factory Service in Arlington Heights where I got to the rank of Lead Technician.
You want a good deck- V900X, V1RX, C-3RX, Z6000, V2RX are some that come to mind Tascam 122B is another.
If you need more help- I run a repair service.
skywavebe@sbcglobal.net
Sep 06, 2012 | Teac W-505R Single Dual Cassette Deck
Cannot diengage tape heads . transport will not play or record but will rew and fast forward
The reel motor drive is independent of the head base actuator system.
You may need a new belt for the cam system or possibly a gear depending on what they used in this transport. This is a job for a Technician. I have not worked on one of those recently but have done thousands of other Teac and other brand decks over 40 years.
Sep 24, 2011 | Tascam 302MKII Single Cassette Deck
I have a TEAC W-450R Stereo Double Reverse Cassette Deck. For some reason, the REC/PLAY II side will not operate. It has not for some time. In fact, that is why I believe I mothballed it some years ago....
I have not seen those to a large extent due to their value not being worth a repair. I did work on them at Teac though. The capstan motor of the right side deck sound like it is burned out. I have some motors here so it is just a matter of if you want me to work on it or not. I get a lot of units in all the time- I am Skywave Tape Deck Repair in Chicago area.
Feb 22, 2011 | Teac DUAL CASSETTE A/R 110/220 Single Dual...
I need a capstan drive belt for a TEAC 3440 reel to reel recorder. Wherr can I find one?
Just measure the diameter in MM and put the result into google with the words 'cassette drive belt'. Belts are not maker specfic.
Oct 24, 2010 | Teac Audio Players & Recorders
Teac Cassette Deck V-518X. No Record Audio.
Found a pinched wire under the cassette deck from the record head. Move the wire out from under the cassette deck. Works fine!
Thanks!
JOHN
Aug 05, 2008 | Teac Audio Players & Recorders
267 people viewed this question
 Grubhead
Grubhead
