Question about Belkin 802.11b Wireless Notebook Network Card [ F5D6020 Wireless ] (109059)
Dell Wireless 2350 BroadBand Router
My router is connected to a Dell Dimension 4500 and I have a Dell Wireless 1450 USB adapter attached to a Dell Dimension 3000. The Dell with the router runs very fast with my Cablevision connection. The computer with the USB adapter always has a very poor internet connection. In fact, it recognizes 4 or 5 routers in the area, all with weak or marginal signals, and doesn't even recognize the Dell router on the computer in the same house. A laptop in the house can also recognize the other routers in the area, but not the nearby one. Do I probably need a new router? Is the Dell 2350 router a poor one? If I need a new router, can I use the Dell 1450 wireless USB adapter with it? Thank you for any suggestions.
Tom Murphy dadtom@msn.com
  • dadtom Jul 20, 2008
    Is it possible that it is not the aerial on the router, but that the transceiver itself has died? It used to recognize the router, even though the signal strength was weak or marginal. Now it doesn't even recognize it, even though it senses 5 or 6 other routers within range. Is it possible to get a stronger network adapter card than the Dell wireless 1450 USB adapter, so that it could read the other routers within range and raise the signal strength? I am not technical enough to download Netstumbler. I wouldn't even know what channel I'm on, or how to switch channels. Could there be a software glitch that prevents the network adapter card from receiving from my router?
    Thank you dadtom@msn.com
  • dadtom Jul 21, 2008
    I found out what the problem was. I had been resetting the router as people had suggested, but still was getting no reception. Cablevision provided me with the answer. I not only had to reset the router, I had to power off and reset the cable modem as well. The other system with the adapter card now recognizes my router with a good and very good signal strength. Thank you.
    Sergeant:
  • 287 Answers
You may get some benefit from downloading and installing Netstumbler
This util will allow you to scan the channels and select a chanel with less devices on it. then change the broadcast channel in the wifi router. This may reduce interference in the connection.
Also cordless phones are notorious for interfering with wifi routers so put some distance between the router and the base if you can.
Another option is to get an external antenna for the router to boost signal strength
something like THIS or THIS and place up high on a shelf. Just check your router antenna is the sort that comes off... should unscrew. not all do unfortunately so be careful not to break yours!!
BTW - the router is not a bad unit but it also is not the best around either REVIEW
Posted on Jul 20, 2008
  • Dave Jul 20, 2008
    yes it's possible that the router transmitter has died but you should try and prove it. As long as the wifi card is set up properly it should work. I suspect it is s signal issue based on your description....
  • Dave Jul 21, 2008
    great news.
How do I convert dell optiplex gx260 to wireless
A usb wireless card for the desktop and a wireless router connected to broadband. If you have the wireless router and broadband, then all you need is the usb Wireless Adapter for the Optiplex
Sep 25, 2010 | Dell OptiPlex GX260 PC Desktop
My wireless 2350 is attached to my desktop and I have a wiress card in my laptop (all Dell products). Everytime I rebbot my laptop I have to reinstall the utility software for a broadband connection. How...
shouldn't need the utility software to use your wireless. Windows has it's own wireless utility which works with any wireless device installed on your laptop. check the icons on your taskbar and right click the little computer screen with the radio waves and tell it to "view wireless devices" then follow the prompts.
Apr 01, 2010 | Dell Wireless 2350 Router
Second computer is not connecting to wireless
Check if you have DHCP enabled on your router.
If DHCP is enabled check Wireless Settings
Feb 20, 2010 | Dell Wireless 2350 Router
I cant connect wirelessy with my dell wireless 2350 broadband router
Unplug router for 10 seconds and reconnect. This will stop the static charge buildup that happens frequently with routers. If needed, set up a wireless network using the network wizard and set all settings to automatic.
Sep 22, 2009 | Dell Wireless 2350 Router
Forgot username/password for Dell Wireless 2350 Broadband Router.
Do you mean you have forgotten the wireless password for your network?
If so , there is are several tools available online which recover the wireless key as long as you have previously connected to that network from your computer.
Try http://www.nirsoft.net/utils/wireless_key.html
Dec 29, 2008 | Dell Wireless 2350 Router
Wireless internet
you need to get a PCI Wireless card or a USB Wireless adapter, if you are talking about an 802.11 wireless router.
If you are talking about Sprint wireless Broadband or the link (WWAN service) you'll need a USB WWAN adapter which are available by all major Wireless vendors (Verizon, Sprint, ATT etc(
Jun 25, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Wireless security
Hi
Here is good guide to setting up security
on Your Dell Wireless 2350 Broadband Router
http://support.dell.com/support/edocs/network/2350/en/ex_confg/set_sec.htm
Mike
May 14, 2008 | Dell Wireless 2350 Router
Lose wireless connection when the phone rings...
You won't have to buy a new adapter as long as the new router uses the same standard (i.e. 802.11b, g or n).
May 01, 2008 | Dell Wireless 2350 Router
Windows Vista and Dell Wireless 2350
Try updating the driver for your wireless adapter.
Jan 22, 2008 | Dell Wireless 2350 Router
Belkin 802.11b Wireless Notebook Network Card [ F5D6020 Wireless ] (109059) Logo
337 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
