Question about Asrock P4V88 (P4V88 RAID) Motherboard
Problem in Device Manager
In Device Manager, under System Devices, the "PnP BIOS Extension" driver has an error. Please could you give me some link where I can find the driver?
  • 2,427 Answers
Http://www.asrock.com/index.asp
just select your model mainboard and it will direct you to the drivers.
Posted on Jul 19, 2008
Tip
Where to find driver versions in Windows
Windows is a versatile operating system environment, and there is almost always more than one way to access information. If you need to see what version of a specific device driver you have, there are two main ways to do it.
- System Information
The System Information utility contains a lot of information about your computer. You can find out everything from the maker of your BIOS to what print jobs are currently pending.
System Information can be accessed through the Start menu (Start > All Programs > Accessories > System Tools > System Information). In Windows Vista or Windows 7, you can also type it in the Search bar.
You can view driver versions under either the Components heading -- where all of the driver info is displayed on the last line for each component -- or the Software Environments heading -- where all of the drivers are listed individually under System Drivers or Signed Drivers.
- Device Manager
The Device Manager is your one-stop shop for everything related to your computer's devices and components. For each device, you can view its current status, its driver version, as well as a basic troubleshooter.
To access Device Manager, type "devmgmt.msc" into the Run bar (or type "device manager" in the Search bar). When it opens, your devices will be broken into categories; just expand each category to see the individual devices, and double click on a device to view its properties. Driver information can be found under the Driver tab.
The Device Manager can also be found in the Computer Management console, which you can get to through the Control Panel, under Administrative Tools.
on Jun 03, 2010 | Computers & Internet
Lenovo 3000 N 100 integrated cam not coming in device manager
fistly you check ur bios setting & registry setting.
is that possible cam is disable by bios or registry, so kindly check it & reinstall ur cam driver.
Nov 17, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
USB works under BIOS, doesn't plug'n'play under WinXP
Seems u r having plug and play problem.
When the second problem appeared? after the upgrade?
Some weird things like this, exists with SP3.
Does Windows ask u to install them?
Check whether the PnP is enabled from the BIOS.
U can try installing your chipset driver (Update).
Go to action menu and Click on Show Hidden Devices. Go to Hidden devices and check whether there are entries related to usb with yellow marks. Parport,Mountmgr (non PnP). etc. Check whether you have any Viruses.
Important :
Check whether these services are functioning properly.
Go to Device Manager
Click On - Services
Plug and Play (Automatic-Normally) Service
and Such services as PLFlashDeviceIoControl Service, Portable Media Serial Number Service, Windows Management Instrumentation (Set to Automatic) and Windows Management Instrumentation Driver Extensions (Start it). They are the people who are responsible and caused these errors. Double Click an set each one's Recovery options.
Then go to Event Viewer and check System (ans Application) for specific erroneous entries.
Did u do a system restore. Anyway if you have upgraded u can't of cause. U could try that. Check whether ur usb root hubs are functioning. U have to upgrade drives for XPSP3. There are many compatibility issues.
Try the latest chipset drive.
Try removing these.
Then reboot and check.
If this solution works or helped you, please kindly RATE the answer.
Wish you luck!
Thanks.
Lasitha
Jun 28, 2009 | Microsoft Windows XP Professional With...
SM Bus Controller and Video Controller (VGA Compatible) drivers
You can download all Windows XP Home Edition drivers for the Intel D101GGC motherboard from Intel's web site at the following link:
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=2229&OSFullName=Windows*+XP+Home+Edition&lang=eng&strOSs=45&submit=Go!
May 15, 2009 | Intel D101GGC Motherboard
Camera Cannot Find Driver
In this case u need to update the drivers........ Insert the Software CD to the computer.... Right Click On My Computer..... Click on Properties........ Go to Hardware...... Click on Device Manager..... Now on that list u will find a option which will say Imaging Devices Under that u will see ur camera with an exclamation mark if it doesnt have an exclamation mark but it says cannot find driver u can just uninstall and reinstall the software...... But if it has a Yellow Exclamation mark then right click on the Camera click on Update drivers...... Click On Browse my Computer for software.......... Select the CD Rom drive from my Computer........ And click nxt not it will say ur hardware is installed and ready to use.... As it is done u will now be able to Import pictures from Camera.............
Jan 19, 2009 | Oregon Scientific DS6618 Digital Camera
Sound driver
Missing or lost sound in Windows 95 / 98 / ME / 2K / XP.
Cause:This issue could be caused by any of the below possibilities.
  1. Bad software settings.
  2. Corrupt or missing sound drivers.
  3. Compatibility issues with the operating system and/or other hardware.
  4. Speaker related issues.
  5. Bad or missing sound card.
Solution:Verify software volume control settings
First verify you see a small sound icon sound3.gif in the systray (generally at the bottom right hand corner of your screen). If this icon is missing follow the below section.
Windows XP
  1. Open the Control panel
  2. Open the "Sounds and Audio Devices" icon.
  3. Verify the "Place volume icon in the taskbar" checkbox is checked. If this option is not available or is grayed out, skip to the next section of this document.
  4. If you were able to check this box, click ok and close out of this window and the Control Panel.
  5. Double-click the sound icon in the systray and verify that all the sound volumes are mid-way or higher.
verify the installed driver settings
  1. Open the Windows Device Manager
  2. Verify there are no conflicts or errors listed anywhere in Device Manager. If conflicts exist skip down to conflicts section.
  3. Verify no other devices are listed. If other devices are listed skip down to other devices section.
  4. Verify that your "Sound, video and game controllers" category is listed, if not skip down to the missing sound card section.
  5. If no conflicts or other devices are listed and your sound card is listed with no conflicts, skip to the next section.
Conflicts section
If conflicts exists with your sound card and/or other devices installed in your computer it is likely that either the drivers are not properly installed for that device and/or the sound card and/or other devices are conflicting. If you open the properties of the device that is conflicting and view the properties, additional details about the conflict can be found. Additional information about error codes as well as help with Device Manager can be found on our Device Manager section.
If you are unable to locate additional information about your issue or are unable to resolve the issue, follow the below steps.
  1. Under Sound, Video and game controllers highlight each device and press the delete key to remove the device.
  2. Reboot the computer.
  3. As the computer is booting the system will detect the sound card and any of it's devices and re-install those devices. If prompted for a location of drivers, try pointing it to your sound card CD and/or your Windows CD. If this does not work or is unable to locate the proper files, you will need to get the latest sound drivers from your sound card manufacturer.
Other devices section
If other devices are listed, it is possible that these other devices could be the sound card or other devices conflicting with the sound card. If any other devices are listed it is recommended you remove those devices, reboot the computer and let Windows redetect the devices.
If this does not work, attempt to determine which device is not being detected and resolve that issue first.
Missing sound card section.
If you are missing the "Sound, video and game controllers" category in Device Manager, it is likely that the sound card drivers are not installed properly, sound card has been disabled, sound card is bad, or no sound card is available in the computer. First, verify no conflicts or other devices are present in the Device Manager; if these are present it is likely they are the sound card and/or devices causing the sound card not to be detected. Second, verify that the computer has a sound card and/or that the sound card is enabled on the computer.
If this is an on-board sound card you can verify that it is enabled in BIOS setup. Additional information on entering the BIOS setup can be found on document CH000192.
If you have no adapters and/or cannot click the down arrow to select the correct adapter, close out of this Window. In Control Panel double-click the System icon / click the Device Manager tab within Device Manager and ensure there are no yellow ! or red X.
If you have either of these on any of your sound devices, attempt to remove everything under Sound Video game controllers and reboot the computer. If after rebooting the computer you still have the same conflicts, double-click on the conflicting device and refer to our Device Manager error code section giving you additional information on the error code you are experiencing.
Verify speaker connections
Verify the speakers settings and speakers are not at fault by running through speaker troubleshooting steps in document CH000034.
Sound card drivers
If you have followed the above recommendations and you are still unable to get the sound card to work, download and install the latest sound card drivers from the computer or sound card manufacturer. A listing of sound card drivers can be found on our sound card driver page.
Dec 26, 2007 | Toshiba Satellite U205 Notebook
Unidentified devices
Although SP2 is improved, the device drivers can still be used from the original CD to initialize drivers. Insert this CD when prompted to update drivers.
Sep 02, 2007 | HP Compaq nc8430 Notebook
Asrock P4V88 (P4V88 RAID) Motherboard Logo
118 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
pankaj rautela
pankaj rautela
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
