SOURCE: Tomtom One
If you have the programs downloaded from tomtom home then you need to copy them to the sd card that you purchased. In the home program you can choose to install the programs and map to the sd card. It takes a bit of a search to get the tomtom home program understood. The credit card with the codes is an authorization code for the program.
SOURCE: TomTom One XL battery not holding charge
Hi Theresa,
Yes , it should be covered by warranty. It's not a common problem but sometimes batteries do fail. It's a bit like when a light bulb goes in your house , you can get a brand new one out of the cupboard , plug it in and it either goes right away or only lasts a short while. Where thats the case the bulb was in fact defective and not fit for purpose. Same with your Tomtom battery . Good luck when you contact TomTom.
SOURCE: how do u change the time on the TomTom go 930
Tap screen, tap change preferences, right arrow to page 8...
SOURCE: Won't turn on
Try holding the power button longer (10-30 seconds). Also, ours does not hold a charge for very long when not used (maybe a week?) try putting it on the charger again.
SOURCE: Tomtom 930 does not find Iphone 3g bluetooth for connection.
The following has worked for me FLAWLESSLY :
1) Remove any old "pairing information" that you may have both on the iPhone and on the TomTom - both should be "clean" not knowing about each other..
2) Put iPhone into airplane mode.
3) Go to settings, and turn on Bluetooth
4) Do the regular "search for bluetooth device" and pair the two
devices
5) Turn off airplane mode
After I did this, I have never had a problem with iPhone 3GS / Tomtom - they find each other now every time, and all is happy..
