Question about Hitachi Televison & Video
53sbx10b Tv has all the colors seperated, and picture pulls from top and bottom
  • Hitachi Master
  • 8,617 Answers
You will need to replace both convergence Ics and the six convergence resistors. Please respond to this same post and verify the model number of your set and I will post the correct ICs and resistors for your model, as well as where to get replacements with free instructions
Posted on Jul 19, 2008
My Toshiba TV was on like normal, then suddenly the green color seperated from the red and blue.. On the bottom left corner you can see the green is 4 inches up while the others stay at the bottom. So if...
Ur tv have a problems known as a convergence pictures problems,it is dead.Ur tv have any colors lines like R,B,G mis alignments,tv have any colors shadows pictures or have a 3D pictures look alike?Yes,than ur tv have a dead convergence board to causes the tv to have all of these pictures problems.The tv convergence board must have be repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops will cost u like $300-350 for parts and labors.
Sep 20, 2011 | Toshiba TheaterWide 52HM84 52" Rear...
Tv Colors are bad
You have a convervence problem. You will need to replace both convergene chips and possibly the resistors. You can get more information and a repair kit with instructions from www.TvRepairKits.com
Jan 09, 2009 | Philips Magnavox 9P6034C 60" Rear...
Hitatchi 53sbx10b
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Jul 19, 2008 | Hitachi 53SBX01B 53" Rear Projection...
Sony KP-53XBR35 TV Concave top & Bottom in wide screen, along with color distortion around sides
thats usually a convergence IC failure, Are you able to move the red and blue colors in the convergence adjustment menu?
Jul 14, 2008 | Televison & Video
Hitachi 53SBX10B RP TV won't turn back on.
there is a fuse in the tv that must be at the end of its life so it gets automatically off.and now that fuse is completely blown off.so it is now not turning on again.
Jun 05, 2008 | Hitachi 53SBX01B 53" Rear Projection...
Colors seperated on our projections TV. The magic focus will not correct. Convergence went out and it's a common problem. Am trying to find out the part and want to fix if I can. Hitachi 53SBX10B
remove the back panel on your tv and look at the large heat sink on the far right side and you will see the big black ICs let me know the STK numbers off them and I will post a link where you can get replacements and they will give free step by step instructions with pics so you can do the repair yourself which takes about an hour.
Apr 26, 2008 | Televison & Video
Hitachi 53SBX10B Projection TV
that is a convergence fail. would need dome new parts and board rework. expect somewhere in the neighborhood of $200-$500 for repair from most tv service centers.
Feb 20, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Convergence problem.
This sounds like one of your convergence IC's has burned out or its solder joints have cracked loose. Sometimes when this happens it burns up one or more of the 3 low-value resistors next to it. This should be repaired and realigned by someone with experience.
Jun 26, 2007 | Hitachi 53SBX01B 53" Rear Projection...
Televison & Video Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
