Question about Mitsubishi VS-60611 60" Rear Projection Television
Mitsubishi tv model VS6061 rear projection with rolling picture.
I have a Mitsubishi tv model VS6061 the picture keeps rolling. Ocasionally it will stop or switch to a double picture. If I put the guide on the picture will stop but when the tv guide disappears and the normal size picture comes back it will again begin to roll. At first if I left the TV on it would not do it it only occurred when I first turned on the TV.
  • 3 more comments
  • ROBANDPAT89 Jul 22, 2008
    I HAVE THE SAME PROBLEM I have a Mitsubishi tv model VS6061 the picture keeps rolling. Ocasionally it will stop or switch to a double picture. If I put the guide on the picture will stop but when the tv guide disappears and the normal size picture comes back it will again begin to roll. At first if I left the TV on it would not do it it only occurred when I first turned on the TV.
  • jboudreau Aug 15, 2008
    Same problem with my Mitsubishi VS-6061. When powering up the TV, the image rolls, or sometimes stops rolling but shows two offset images of the same picture. After a long warm-up time (maybe half an hour) the picture becomes OK. I suspect a bad (aging) component, but I don't know which one.
  • vaggelis Sep 18, 2008
    I have the same problem. When my Mitsubishi 48" rear projection TV first is turned on, everything seems to be purple and green, then it starts rolling in a fast fashion, and after about 5 miunutes the picture is perfect. The colors are sharp and the picture crystal clear. The problem happens when the TV is "cold" and I suppose it takes its time to "warm" up. Any ideas/suggestions, will be greatly appreciated.
    Thank you
  • poorman561 Mar 24, 2009
    same
    save
I know this is an old thread, but I would like to post this information in the hope that someone will find it useful.
I just finished fixing this problem on my 1994 VS-6061... the problem is the PIP (Picture In Picture) board located on the Power Signal board. The PIP board contains the numbers 530B552. I bypassed the PIP board by following the directions I found at the following link:
http://forum.doityourself.com/entertainment-center-tvs-stereos-vcrs-dvds/130383-mitsubishi-cs-35301-rolling-picture-problem.html
"Plug in a 4.7ufd @ 35v filter cap (+)at pin 5,(-)at pin 11. Plug in a .01ufd(any voltage) between pin 7 and 9. Just plug the caps into the socket, where the PIP board was mounted (they don't need to be soldered). Just don't let the leads from the two capacitors touch, as they cross each other. The 0.01 cap is non-polarity, so either way it plugged is fine. Basically you will bypass y-signal through 4.7u, in pin 5, out pin 11, and bypass c-signal in pin 7, out pin 9 of the PIP socket.”
The bypass requires 2 capacitors: One 4.7ufd @ 35v and one Non-Polar 0.01ufd @ any voltage.
Remove the PIP board, then plug the two capacitors into the socket where the PIP board was mounted: plug the 4.7ufd capacitor with (+)at pin 5,(-)at pin 11 and plug in the non-polar .01ufd capacitor between pins 7 and pin 9.
If there is a ground wire (possibly brown) soldered to one of the tin cases on the PIP board, then you should connect this ground wire to the PIP socket either at pin 2, 4, 6, 8 or 10 which are grounds of the socket.
This PIP board was used in many Mitsubishi televisions and they were plagued with problems...This is why many of these older Mitsubishi televisions had similar problems…
Good luck
Posted on Feb 16, 2010
The horizontal hold
If model number correct (the one posted here) set does not have a horizontal (rolls left to right) or a vertical (rolls top to bottom) control.
Verify model and brand so I may offer some suggestions
Mar 22, 2012 | Mitsubishi VS-5075 50" Rear Projection...
Mitsubishi wd-52525
If adjusting the vertical hold trimpot at the rear does not cause it to resyncronize then it will need to have a few transistors replaced. You also need to check it its something close to the TV causing it that wasnt near it before (PC.. Laptop or some other electronic device)
please rate our help to keep the free service online
Aug 27, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Picture rolling when I first turn on my tv
A rolling picture or loss of vertical sync can be caused by several components including a bad signal board or jack panel assy. You will not be able to resolve this yourself. contact a Mitsubishi authorized service center.
michtech
Feb 14, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi
This is a case of bad capacitors in the PIP (picture in picture) module. If you have any electronics repair experience, you should be able to do the repair yourself. Here is some more detailed instructions:
http://forum.eserviceinfo.com/viewtopic.php?p=59404#59404
Jan 15, 2009 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi projection tv vs60va2 picture rolls
This unit has chroin bad caps on the 5v, 9v and 12v regulators. If you know circuitry you can check thos caps and replace the weak or open electrolytic caps. If you call on a tech that services mitsu. this is faily common repair for them and should not cost over 150.00 to 200.00 depending on your area.
Apr 07, 2008 | Televison & Video
TV screen jumps and rolls, sometimes won't stay on
Try Re-soldering the vertical yoke connection and the vertical output IC. Thats a common problem in that model.
Feb 26, 2008 | Mitsubishi VS-45607 45" Rear Projection...
The picture rolls vertically sometimes.
I would check the capacitors in the verticle deflection circuit. Also try resoldering the verticle output as well as the verticle yoke pins where they connect to the chassis. Mitsubishi has had some trouble with their capacitors, you may have one that is leaking. Let me know if I can help you further.
Jan 13, 2008 | Mitsubishi VS-60801 60" Rear Projection...
Mitsubishi rear projection tv
I've worked on a few of these sets and have found C2P08 to cause something like rolling bars in the picture and have found C2P05 to cause lines jumping in the picture.
Feb 05, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Televison & Video Logo
635 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
