Question about Wacom Cintiq 15X Graphic Tablet
Waco cintiq My tablet was working great. I opened it today and it says no sync/ go to sleep signals. When i turn on the computer the tablet comes on screen in sync with monitor until wondows starts to load and the goes to sleep and you cannot get it to stay on. Please help Thanks Frank
  • 3 more comments
  • Anonymous Sep 17, 2008
    I have had the same problem. Was working fine, switched it to a new computer and now all of a sudden no sync/going to sleep...any luck fixing this?
  • fourzy Dec 18, 2008
    when i swich on my cintiq 12
    i have a singal "no sync go to sleep"
    what is this
  • Anonymous Jan 07, 2009
    that's happening with my tablet as well. i got it for christmas and it has been working, no problems, but now as soon as windows opens and my computer is fully on, it says "no sync...go to sleep". even though the pen is calibrated and still works...there is no screen display. it's very frustrating
  • 01skyetan Jan 24, 2009
    hmm.. i'm suffering from the same problem on my mac book pro. When i first bought it a couple months back it was okay. after several times usage, the screen on the wacom just decided to go "no sync " and go to sleep without any reason. The tablet is still working fine though and i can still illustrate without the tablet screen. But it's freaking irritating. I called the wacom distributor but they don't seems to have an answer.
  • Anonymous May 24, 2009
    this problem is relevent to my position...
    Old wacon Cintiq 15X, new PC, plug in as dual screen and poof... no synch/sleep. loads up all right. XP welcome screen... no.
We had the same peoblem with our tablet: no sync/ go to sleep. We tried re booting the computer-no luck. We tried turning on and off the tablet.-no luck. The solution for us was simple: unplug the power source, wait a minute, plug it back in. Voila! It worked. I know we had a power outage the night before, so perhaps the problem was associated with the outage.
Hope this solution helps someone!
Posted on Sep 30, 2008
I plug it into my pc and everything, in the end it said no sync and it went to sleep, so do you know whats the problem and how can it be solved?
Please and thanks you
p.s: can u explain the unplug power solution with more details, it'll be a pain for my cintiq to break down on me
Posted on Oct 25, 2009
Cintiq calibration mac fails
Is it possible that Wacom might have released a firmware update for your Cintiq? Wacom may have released a firmware update that will allow it to stay in sync w/ Mac Yosemite.
Jan 05, 2015 | Wacom Cintiq 21UX (CINTIQ21UXNR)
I have come to use my Cintiq 21 ux on a win7 x64 system with a twin firepro V5800 graphics card. My Mac 21" screen is fine but the Cintiq goes green when not receiving a signal and the green shows like...
The output from the graphics card may not be compatible with the screen. I would try to verify that first. Next look for any bad connections. Distortion to that degree in many cases is cased by a bad cable, connector, or just not being plugged in correctly.
Hit us up at our techie forum
http://forum.wasatchtechies.com/
Wasatch Techies Smartphone Tablet and Computer Repair in Utah
Feb 11, 2014 | Wacom Cintiq 21UX (CINTIQ21UXNR)
Cintiq monitor suddenly won't sync
http://www.conceptart.org/forums/showthread.php/201556-Cintiq-12wx-No-Sync-quot-Message
Oct 10, 2017 | Wacom Cintiq 15X Graphic Tablet
I just got a cintiq 12wx and when I plugged it in it worked immediately with my intuos 3 driver but had a message in the middle of the screen. uninstalled the driver and installed latest wacom cintiq...
I had this same problem and just had to go into my system preferences on the imac and select display and then select/check the mirror monitors and now it is on sync-hope that helps! After I did that though my color is off on the cintiq so I am looking for suggestions on how to fix it as the calibration did not fix the problem.
Nov 07, 2009 | Wacom Cintiq 15X Graphic Tablet
Worked fine, now all of a sudden it no sync/go to sleep
I had this problem. Tried everything. Then I hooked the tablet up as my main monitor and adjusted the resolution. Also adjusted the resolution on the other monitor to the same. Then switched them back to normal and it worked.
Sep 02, 2009 | Wacom Cintiq 15X Graphic Tablet
My Cintiq 21ux is not recognized as a 2nd monitor it just works as a huge wacom tablet with a black screen.It recognizes the pen as a mouse on my other monitor I get the same message No /sync /go to...
HI, I've had a similar problem. This solved it for me. Connect the cintiq first to a dvi to vga adapter, then connect that to apples vga to mini display port adapter.
worked for me so I'll keep my fingers crossed for you.
Jun 06, 2009 | Wacom Cintiq 15X Graphic Tablet
Cintiq 12wx
I had a similar problem with my cintiq 12WX - i have managed to sort this problem.
The way i did it was by going into CONTROL PANEL (please note i am using XP windows), then into DISPLAY, then into the last tab on the right aka SETTINGS. Once in SETTINGS go into the ADVANCED section, then click on the DISPLAY tab. In here you should have 3 things - monitor, panel and tv. The tv bit is irrelevant. Look at the MONITOR and PANEL tabs, if your wacom IS set up correctly when you click on the button (it is a circle with a line inside it) on the title (it will either be greeny/turquoise or red). If it is red, click it and the same button on the panel title will turn green aswell. Below the pictures of a computer and a laptop there should be 2 buttons that are the same for each. Currently, my almost working cintiq is set to having the button with two squares on it under the heading of 'MONITOR' and the button with a circle is on under the section entitled PANEL.
If this doesn't work I dont know what to suggest.
Hope this helps.
M
(p.s. you may have to improvise with the settings in the display bit to get it to work).
Mar 18, 2009 | Wacom Cintiq 12WX Interactive Pen Display...
Problem with Cintiq 12wx
Hi...there Jenn!
Go to your toolbar bottom r/h side, look for VGA Display Icon. Open it and look for dual monitor setup. It's might be what you has been looking for... If not, read your cintiq user guide... Have a nice day!
Feb 03, 2009 | Wacom Cintiq 12WX Interactive Pen Display...
Duel Monitor Cintiq Problem... pen affecting wrong monitor
under the calibrate tab in the wacom tablet properties window there is a drop down window with a list of monitors. Change that to the Cintiq
Jan 19, 2009 | Wacom Cintiq 15X Graphic Tablet
Wacom Cintiq 15X Graphic Tablet Logo
3,631 people viewed this question
Top Wacom Computers & Internet Experts
toddmat
Level 1 Expert
jasbo
jasbo
William F. Bryant Jr
Level 1 Expert
Are you a Wacom Computer and Internet Expert? Answer questions, earn points and help others
