Question about Electrolux 25.9 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel
Power fail light, water and air filter warning light, and crushed ice dispenser light stay on all the time.
Refrigerator appears to be working fine, but several warning lights and function lights are on that should not be on. Filters are okay - when you press the filter status buttons the indicator reads okay. COuld this be caused by excessive water pressure? The manual says pressure over 100 psi may cause the filters to fail but it doesn't say anything about warning lights coming on. Our water pressure is around 100 to 120 psi.
Model number EI26SS55GS
  • 4 more comments
  • Anonymous Aug 08, 2008
    Mine does the same thing. Random lights come on on thier own.
  • tjaedike Sep 02, 2008
    i have the same problem i just purchased these last week and noticed that the power fail light is on, along with the crushed ice light is on, both filter lights are on but when you check them they are good, and when you go to reset them it wont do it, also the control lock light is on but isint locked please help i am very frustrated at this problem.
  • hockms Sep 27, 2008
    Forget the water pressure issue. The problem is the control board. Apparently Electrolux is having a problem because it took 2 months to get the first replacement board, which also failed. I have another board which will be installed Monday. Will update if it works.
  • Anonymous Nov 25, 2008
    Same problem. Replaced filter but the lights come on, lock comes on etc.
  • Anonymous Dec 24, 2008
    Same problem here. I am calling Electrolux for service.
  • hockms Feb 07, 2009
    The problem was the control board. The real bad news is they sent three new boards that all had the same problem. Then they replaced the whole unit twice so I'm on my 3rd refrigerator. Having similar problems with my new Electrolux microwave. Have replaced control board once and waiting for 2nd replacement. Would not buy Electrolux again. Sorry to all that made the same mistake.
  • Electrolux Master
  • 5,568 Answers
Your stated water pressure is abnormally high; well systems supply 30-60 pounds of pressure and municipal systems are *supposed* to be around 60# since most plumbing (faucets, showerheads) is designed around that point.
If your pressure has been measured at that level, more than your refrigerator is at risk of failure.
Posted on Jul 19, 2008
Ice maker crushes ice but wont dispense Crushed ice
Good Afternoon Friend,
I understand that the ice maker in your Frigidaire refrigerator, model# FRS23H7CS, is crushing your ice, but will not dispense the crushed ice. It sounds like the dispenser is possibly jammed. Follow the following steps for a possible resolution:
    1)The ice has melted and frozen around the auger due to infrequent use, temperature fluctuations, and/or power outages. Remove the ice container, thaw, and empty the contents. Clean the container, wipe dry, and replace it in the proper position. When new ice is made, dispenser should operate.
    2)Ice cubes are jammed between the ice maker and the back of ice container. Remove the ice cubes that are jamming the dispenser.
    3)Ice cubes could be frozen together. Use the dispenser often so that cubes do not freeze together.
    4)The ice cubes are hollow or smaller than normal. The ice & water filter cartridge could be clogged. Replace the filter cartridge. Dispensing system operates best at 20 - 100 psi water pressure. Well water pressures should fall within this range.
    If the above does not work, I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Turn the power back on and try dispensing crushed ice. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully.
    -Best Regards-
Jun 20, 2014 | Frigidaire FRS23H7CS Side by Side...
Ice and Water not dispensing. Light button not working
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Jul 04, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GC3SHEx300 ice dispencer does not dispense cube or crush ice. Water comes out, lights work. it is not deactivated.
Sep 06, 2010 | Whirlpool 21.8 cu. ft. Side-By-Side...
GE PSS25MGMA Crushed ice only, nothing else will select on panel.
Yes , replace the main board . Part number WR55X10656 . There is only partial communication between the main board and the dispensor board . This main board , is behind the 8 " X 10 " panel , on the back of the refrig . Do not replace the dispensor board . I have never come across a bad dispensor board yet . Always a first time though .
Sep 27, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Water, ice and crushed ice dispenser doesn't work properly
you need to replace the board in the dispenser front housing on the front of the freezer door / larry
Mar 16, 2009 | Refrigerators
Ice/water maker won't dispense
Icemaker only dispenses crushed ice even when in cube position. Water/light work fine. Have already replaced control module circuit board.
Nov 17, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
Ice maker not getting water after changing filter
Check the following:
 Is the freezer door closed completely?
 Is the ice storage bin installed correctly?
 Is there ice in the storage bin?
 Has the ice frozen in the storage bin?
 Is ice stuck in the delivery chute?
 Has the wrong ice been added to the storage bin? Use only
cubes produced by the current ice maker.
 Has the ice melted around the auger (metal spiral) in the
ice bucket?
Dump the ice cubes and clean the ice storage
 Is the ice dispenser stalling while dispensing “crushed”
Change the ice button from “crushed” to “cubed.” If
cubed ice dispenses correctly, depress the button for
“crushed” ice and begin dispensing again.
 Has the dispenser arm been held in too long? Ice will stop
dispensing when the arm is held in too long. Wait 3 minutes
for dispenser motor to reset before using again.
The ON/OFF switch is located on the top right side of the freezer
To turn the ice maker on, slide the control to the ON (left) position.
To manually turn the ice maker off, slide the control to the OFF
(right) position.
NOTE: Your ice maker has an automatic shutoff. The ice maker
sensors will automatically stop ice production, but the control will
remain in the ON (left) position
 Allow 24 hours to produce the first batch of ice. Discard the
first three batches of ice produced.
 The quality of your ice will be only as good as the quality of the
water supplied to your ice maker. Avoid connecting the ice
maker to a softened water supply. Water softener chemicals
(such as salt) can damage parts of the ice maker and lead to
poor quality ice. If a softened water supply cannot be avoided,
make sure the water softener is operating properly and is well
The Dispenser Lock (on some models)
Your dispenser can be turned off for easy cleaning or to prevent
unintentional dispensing by small children and pets.
NOTE: The lock feature does not shut off power to the product, to
the ice maker, or to the dispenser light. It simply deactivates the
dispenser levers. The ice and water dispensers will not work.
Style 1: Press the LOCK BUTTON to lock the dispenser. Press the
UNLOCK button to unlock the dispenser.
Style 2: Press and hold the LOCK OUT button to lock the
dispenser. Press and hold the LOCK OUT button a second time to
May 15, 2008 | Whirlpool GS5SHAXN Side by Side...
Apr 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice & water control buttons
sound like a bad(shorted) dispenser user interface INTERFACE DISP ASM WR55X10415
Apr 03, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Electrolux 25.9 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel Logo
884 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
