Question about GE Microwave Ovens
Just installated GE microwave does not heat at all. It also cuts off before the time selected.
  • GE Master
  • 9,098 Answers
Normally you have a 30-day return period form most dealers. I would exchange it for another one.
It may have been damaged during transport. Just to check, you could try setting as cook time, then gently holding up (or down) on the handle as you try to cook. If it acts differently, there is probably a loose door switch mount or a misalignment.
But I would get another one, just to avoid a possible lemon.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 21, 2008
Why does my ge spacemaker jvm1740dd1cc no longer heats and the turntable does not work?
Bad door switch. Look for burnt terminals on one of the door switches. Replace the switch and cut off the burnt terminals and splice on new ones.
Aug 08, 2014 | GE Spacemaker JVM1740 Microwave Oven
How everything works but does not heat?
There are some good tips on this website
http://www.ask.com/question/my-ge-microwave-runs-but-does-not-heat
Could be the thermal cut-off relay has tripped, thermostat is faulty or very remote chance the microwave generator itself is faulty. Will need the model number to make any further assessment of repair.
May 01, 2014 | General Electric Microwave Oven
GE Profile Spacemaker 2004 JVM3670BF02 doesn't Heat up
Ensure that you have select the correct range of temperature.
Sep 11, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
Ge microwave je2160sf03
From the description one of the door switches is defective, or a more serious problem has developed.
Jun 02, 2012 | GE Spacemaker Over-the-Range Microwave
Our microwave quit HEATING this morning. What can
Could be the magnatron/thermal cut out seek pro advice
Apr 01, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
How doI change the power on my microwave?
  • Press "Time Cook" or "Micro Cook."
  • Enter cooking time.
  • Press "Power Level".
  • Select a desired power level 1-10 (default is 10).
  • Press "Start"
Jul 06, 2009 | GE JES1855 Microwave Oven
Ge spacemaker runs but wont heat
Hi, there are three issues that will cause a no heat situation in a microwave. these issue are a failed Magnetron, busted cut-off fuse and, failed diode.
I recommend checking all these area that are located inside the microwave for faults.
The most common issue will be a failed Magnetron.
The diode and, fuse will be located on the noise filter assembly.
Jan 16, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker Microwave
This is usually due to a defective or failing magnetron.
When failing, they can emit interference that disrupts the control circuit, or if it has a thermostat on the magnetron, that will disconnect the power until it cools down.
You can save about $50-75 if you remove it from the wall and take it to a GE-authorized servicer. You can find one by calling GE Appliance Service 1-800-848-7620.
Removing it from the wall is ideally a 2-person job and you should have your installation instructions handy. If not, you should be able to find them here: http://www.geappliances.com/service_and_support/literature/
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Dec 04, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Kenmore Microwave Hood Combination: over the stove Model #721.80602500
Disclaimer: I'm a DIYer, not a technician.
Our GE over-the-range microwave stopped producing heat yesterday while warming part of the T-giving feast. Everything else (fan, control panel, light) works fine.
After disassembly and testing last night, I discovered a defective "secondary door switch." Your Kenmore uses a similar switch (~$19 on-line), and that might be the problem. But it also could be other things, such as a bad thermal cut-out.
If you know anyone who's handy with a multimeter, most of the basic diagnostics seem to be pretty straightforward.
Nov 23, 2007 | Kenmore 62622 Microwave Oven
Microwave Ovens Logo
21 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
