Question about M-Audio PROJECT MIX I/O Sound Card
Project mix i/o not recognized by computer
The device was working fine until I had to unplug the unit from computer and reconnect it. The computer was unable to recognize the device, so I uninstalled the driver, downloaded the latest driver and installed it. The same result. I connected Firewire410 to the same computer and it worked just fine.
Could it be that I damaged Firewire port on Project Mix somehow?
Thank you for your time, Richard
  • jfogart Jul 23, 2008
    I've had the same problem. I purchased a Project Mix in August of 2007 for a home studion I was assembling. I connected it fine. When I upgraded my DAW, I tried connecting Project Mix - would not recognize. Tried two other computers - same thing. Sent off for repair, returned 3-4 weeks later - same problem. Received a replacement - same problem (3 PCs tested). Received another one - PC recognized it. I sent it to Black Lion Audio for mods, received it back; now computer doesn't recognize it.
    It's been a year, I'm on my third one, I just spent $500 for improvements, and I've never recorded a single thing, as I have been battling problems since day one.
    Somebody....anybody....please throw me a rope, and help me understand what the heck is going on. I'm at the point that I will pay to have it fixed, but I want it fixed! Or tell me the firewire port is ****, and I have to use tongs, ESD strap, and kill the breaker before unplugging it. Just please give me answers.
    Thanks
    -Jim
fire sine
  • 382 Answers
SOURCE: firewire410
You should install service pack 2, the go to the m-audio site and upgrade the drivers again. Also, since your computer most likely have a 4 pin firewire, make sure you have the power cqble for the 410 connected. Ofcourse, do not have the 410 connected when upgrade either sp2 or the drivers. make sure you power cycle both devices before reconnecting and attempting to record....
http://www.m-audio.com/index.php?do=support&tab=driver&serie_ID=2&PID=5f35def5b4107998b11119907053a313&OS=15
keep me posted...
Posted on Nov 27, 2007
SOURCE: firewire audio problem
Please notice that the firewire 410 is known to have problems with firewire chipsets that are not manufactured by either Texas Instruments or NEC.
This means that it's not enough to buy a Firewire card or to make sure you have it on your motherboard. You have to make sure that the chipset (the chip that actually manage the data transfer) is manufactured either by NEC or TI.
It's not always easy finding out the manufacturer of the chipset, but it's possible (for example my GigaBute motherboard came with a TI chip and it was written on its spec). Good luck!
Posted on Feb 04, 2008
SOURCE: UNABLE TO INSTALL FIREWIRE 410????
I got the same problem, but cannt find out or google it how to reset the device, found just some scripts, cannt use that, do you have some help?
THANKS
Posted on Sep 15, 2008
josetapia162
  • 155 Answers
SOURCE: Can't get Yamaha motif to work with new M-AUDIO
Go to your computers control panel find your devices section locate your settings for your synth in/out to see if there active or not. consider to go tothe M-Audio website to chec for recent downloads for ti. You may need to upgrade your windows?
Posted on Jun 29, 2010
SOURCE: M-audio Firewire 1814 unrecognized
yes
Posted on Jul 01, 2010
My webcam has stopped working, It just says 'No video capture device was detected on your system'
The camera device is likely disconnected from computer port. Attempt to establish connection cables by unplugging and reconnecting several times to allow the computer to recognize the activity. The sensitivity of the computer with device would simply recognize a reconnect. Usually, the computer has to be restarted to acquire the connection capacity with prior computers and peripheral devices.
Jan 26, 2011 | Computers & Internet
Windows Not Recognizing Device
Insert your operating system disc in to your cd/dvd rom drive, then go to my computer properties, now go to device manager and right click on keyboard or mouse what you want, now re-install your device from your cd/dvd rom, and restart your system.
Jun 04, 2010 | Logitech Wireless Access Duo Optical...
Overload light on Aims 5000w inverter
try to disconnect all cables from front and back, then turn the unit on and let all the stored charge drain and reconnect and test...make sure the unit grounded
Sep 06, 2009 | Inverter AIMS Power 5000 / 10000W
MODEM NOT RECOGNIZING ROUTER
You need to check the router's admin page to make sure the DSL/Cable modem is being recognized properly. This can happen when unplugging the devices. Ck your routers user manual for login instructions. Should be default IP address of router typed into internet explorer browser then you need login/password (like admin/admin) then check the status to see if router/modem are talking to each other. Probably good idea to unplug both devices at the same time and then power back up. I can be more specific if necessary.
Hope that helps,
TankMurdock
Apr 24, 2009 | Trendware TEW-432BRP Wireless Router...
My brand new mixmax won't power on
How unfortunate. Its probably a malfunction with your player. When I plug my daughters mix max into the usb it says do not remove. I waited and removed it anyway and it worked fine. I suggest you take it back and get a new one.
Dec 27, 2008 | Disney Mix Max Digital Media Player
No device recognized when connected to computer
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Mar 13, 2008 | RCA OPAL M4001 MP3 Player
Unit suddenly not recognized by computer
uninstall driver then turn off the PC then unplug the power cord from power socket, short its legs then leave it unconnected for 5min, then reconnect it to power socket and turn on PC and install driver it should work :)
let me know if that helped !!!
Oct 12, 2007 | Panasonic RR-US006 Handheld Digital Voice...
Computer doesn't recognize unit when connected
Hi All,
I had the same problem and was going crazy trying to figure this out, but I found that I had installed the GPX mw3816 on my bottom USB port and was trying to plug it into the port above it, because I had plugged another unit into the bottom port, but I switched the ports and it immediately installed. This is another reason, I am thinking of dumping windows and moving to a MAC. Peace!
Aug 13, 2007 | Samsung YP-T8 Digital Media Player
M-Audio PROJECT MIX I/O Sound Card Logo
761 people viewed this question
Top M-Audio Computers & Internet Experts
Gareth Cockram
Gareth Cockram
mukhtar21 shaikh
mukhtar21 shaikh
John Bolton
Are you a M-Audio Computer and Internet Expert? Answer questions, earn points and help others
