Question about Whirlpool Dryers
I have a broken drum belt,but I don't see how to put the new one on.I see where it goes,but unable to figure out where and how to start it. Whirlpool LEN2000KQ Electic Dryer
  • 413 Answers
Before replacing the belt, purchase a new idler assembly, the one in there is what caused the belt to fail so soon.
Replacing the belt with one person takes a little practice as you have to hold the drum in place while holding the pulley in the slots on the bottom panel and place the belt over the pulley and attach to motor shaft. The diagram shows how the belt is routed:
If you need further assistance, let me know
Regards,
reg501
Posted on Jul 19, 2008
My belt is broken on my tumble dryer.took it apart and don't know how to put the new belt on
The belt goes around the drum, through the idler pulley onto the pulley on the motor. The idler fastens into several holes on the floor of the dryer.
Sep 29, 2011 | Dryers
Dryer not drying clothes
Hello, does the dryer drum turn? If the dryer drum is moving. Is the dryer blowing hot air, cold air, no air at all? Now, if it's doing everything mention above escept blowing hot air then you'll need a new heating element. If not blow air, then the drum belt is broken, belt off, or the drum motor has gone south. It was put for a quitt. Which mean in New Mexico, they fired me, I don't work, no job, finished, I'am out of here, don't bury me with my wires exposed. I hope I was some help to you. have a nice day and be safe, GB. stewbison
Aug 20, 2011 | Dryers
Dyer will not turn on. Can hole the starter button in and dryer will run. remove and the dryer will stop running. When holding the start button the dryer does not heat. Any Idea's as to what may be...
broken belt or broken broken belt switch most likely. Open the door. Hold in the door switch and push the start button. Does the drum turn? If it does turn then the broken belt micro switch is where I would look first. If the drum don't turn of course I would replace the broken belt.
The only Kenmore dryer that has a broken belt switch is the 4 wheel drive model. Here is a video which shows how to get into this dryer and replace the belt:
Jul 08, 2011 | Kenmore 63932 Electric Dryer
Maytag gas dryer broken tumber belt. how do i replace it myself? the tumbler doesn't turn, the belt thah goes around it is broken. i need to put a new belt on.
Each dryer is made differently on how to access the drum (tumbler) and belt replacement. If you can provide a model #, that would be very helpful. On most dryers the model# is located on the door frame usually to the left when you open the door. This will get you started in the right direction.
Mr Tin Man
Dec 19, 2010 | Maytag Dryers
My creda simplicity t622cw condenser dryer wont turn
Broken or belt has come off. If can open back and fix or replace. You may need to remove the top. Careful of the heat element, lift out drum and place new belt on motor holding it while you put the drum back keep hold of belt and place around drum replace top and should be ok. Hope this Helps
May 25, 2010 | Dryers
GE model DQSR483EE1WW. This is what I know so far: the switch on the door works so it shouldnt be that safety, it is getting power because the light work and the timer at least buzzes like its working,...
Try looking for a broken belt. (electrical interlock prevents starting with broken belt) Disconnect power, open door, remove two phillips screws which go from top of door opening into dryer top. Swing top up and back. If belt not present going around drum, that's your problem. Remove one screw from side panel to front panel on each side (near top) and lift front panel forward and off the bottom pegs. Set the front panel to the side (leaving door switch wires attached) so you can slip new belt around drum. Reach under drum to put belt WE12M29 around drive pulley and around tensioning pulley. (grooved side of belt touches drum) Put front back on dryer and manually rotate drum a couple revolutions to make sure belt does not come off before closing up top and reconnecting power.
Dec 24, 2009 | Dryers
Need help with installing belt in Maytag Electric dryer
if not able to remove rear panel,you will need to start,like most models,take top cover off and hinge back to wall then remove frt cover including door as a whole assy. lift up drum put new belt on drum ( and position in same area as old belt,it will have marks on drum from where original belt was on drum) then put rest of belt over mtr pulley and then idler pulley, turn drum by hand to align belts and put it back together in reverse order
Jul 28, 2009 | Maytag PYE2300AY Electric Dryer
Broken belt on hotpoint vtd65 tumble dryer
if it comes on and runs and has heat but the drum does not turn the belt is broken. To replace the belt unplug the dryer, remove the lint filter, remove the 2 philip head screws,with a stiff putty knife pry up in the top of the cabnet on the right and left to litf the top, disconect the door swithch remove the screw from each side and lift the front off romove the old belt the reinstall put new belt around the drum groove side toward the drum. put the idler pully in the slot closest to the motor be sure the tab is under the base and the 2 catches stit in the slot. now pull the belt through the idler pully and around the motor shaft. the reinsatll the front secure with the screws reconect the door switch,close the top, put the 2 screws back in where the lint filter goes then put in lint filter, plug in dryer and test.
Jan 19, 2009 | Dryers
My dryer needs a new belt. I opened the front panel and removed the broken belt but I am not sure how to put on the new one. I know it goes around the drum but does it go in the middle or near the back...
Cheryl the belt goes in line with the pulleys. 1st Put the belt around the drum. 2nd put the belt around the pulley on the motor. 3rd pull down on the idler pulley and set it so that is pushes on the back side of the belt. Remember the ribs on the belt go against the drum. When done the pulley will take up the tension on the belt. Hope this helps.
Aug 09, 2008 | Dryers
Whirlpool dryer
if u can turn the drum by hand than more than likly the belt is bad or there may be somthing stuck in the edge of the drum ie kids toys ect ect or the motor for the drum has failed unplug the unit if you can take off the rear cover you should be able to see the belt that goes around the drum or you should see the motor for the drum check to see if the belt for the drum in inplace if not get a new belt and if the motor can turn by hand buit it wont turn the drum check to see idf there is a red button to reset the motor if not than the motor is probably bad check to see if you still have a warranty good luck keep me posted best regards mike
Aug 09, 2008 | Whirlpool LER5636P Electric Dryer
Dryers Logo
116 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
