Question about Saitek (PS28) Joystick, Throttle
X-axis trouble I cannot calibrate the X-axis of the joystick. The Y-axis is no problem, though the x-axis doesn't move at all!
  • Anonymous Oct 21, 2008
    yes have the same problem
    and i test it out ,the component for capture x-axis movment is defeckt
    Where can i find it ? can i order it by Saitek ?
I had the same problem with my X52 and searched high and low on the internet for a solution. What I did was pop the base off and found a loose connection on the x-axis wires. I re-routed both the x and y axis contact wires underneath the p/s2 port and put it back together. Seems to be working fine now. I will not that opening up the controller will void your warranty and it also could be possible that your x-axis problem could stem from something completely different from what was wrong with mine. You may contact me if you need any help with it. mynameisbob AT gmail DOT com.
Posted on Jun 28, 2009
  • 1 more comment
  • mynameisbob2 Jun 28, 2009
    mynameisbob2007 AT gmail DOT com
    I typed it wrong in my original response. Sorry.
  • alex581
    alex581 Sep 10, 2012
    THANKS! I've scoured the internet to find fixes from drivers to profiles and registry edits. You convinced me to pop the button (4 easy screw) and notice a badly soldered yellow wire on the x axis sensor. I feel like I just made $100!!!
  • alex581
    *bottom
Having trouble programing my extreme 3d pro joystick and FSX deluxe. I am using Vista. I can't get the elevator trim up/down to work. Doesn't even seam to work when i press 7 or 1 on the...
I would first of recommend doing a calibration of your joystick. To do that, make sure your joystick is connected to your computer and go to your start menu>>devices and printers. Once your window pops up, find your joystick and right click on the icon, and go to settings. You can find the calibration wizard there. Once that is done, open up your Flight Simulator X, and go to the settings tab. Along the right hand side, click on controls. From there you can configure your joystick buttons to whichever action you like. Please keep in mind as well when your are adjusting the elevator trim, rudder trim, that the adjustments made from one keystroke, or button push, are very very small adjustments. You can change that by moving the slider on the Repeat column, thereby making one keystroke or button push equal to multiple taps!
Sep 13, 2011 | Microsoft Flight Simulator X
I need calibration software for the logitec 3d pro joystick. will not maintain level flight in AP (flight sim ).
this was not originaly my post but i saved it.and it worked for me. HOW TO CALIBRATE THE LOGITECH EXTREME 3D PRO JOYSTICK
I just figured out how to calibrate this joystick. I am using Windows XP. I assume it will work with all Windows operarting systems though.
Go to Control Panel, click on "Game Controllers", or however you get to your joystick settings. Hold down the "Ctrl" (control key) and the "Shift" key together - at the same time, THEN click your mouse on the "Properties". This should take you to a different calibration screen that you would get to without holding the two keys together. IMPORTANT - Click on the "Test" tab first. If you go to the settings tab first, it likely will not work. Without doing anything else after clicking on the "Test" tab, next click on the "Settings" tab. Then click on the "Calibrate" button below. Click "next". Click the thumb button on the left side of the joystick which should bring you to another screen. Then follow the prompts......
* On the "axis calibration", move your joystick in full circles, making sure the "+" symbol moves around the far margins of the square. After a few complete circles, click the "next" button with your mouse.
* On the next screen, click the left button on the joystick again, which should bring you to the next screen. Move the throttle lever back and forth a few times. Then click "next" again.
* On the "Z rotation screen", move the joystick to the left and right (rotate it) a few times. Then click "next" and then "finish" then "ok". Thats it. It should be calibrated now. Hope this helps everyone with problems.
Feb 08, 2010 | Logitech Extreme 3D Pro Joystick
The character in the game moves by itself
Sometimes powering on a game console with the joystick moved other than center can throw the whole calibration off axis during bootup causing this to occur. Also try with another controller. The controller may be going bad.
Oct 30, 2009 | Sony Video Game Consoles & Games
WILL NOT CONTROL AIRCRAFT HAS NO LIFTOFF
Oct 09, 2009 | Logitech Extreme 3D Pro Joystick
Saitek aviator joystick av8r-01
Well.. if you have windows xp.. then you can calibrate your controller fairly easily.
Go here:
Control panel:Printers and Other Hardware:Game Controllers:(your controller should be in the list):Advanced:Calibrate
This should solve your problem ;)
Apr 11, 2008 | Saitek Aviator AV8R Joystick
Why did the Y-axis stop working?
Same happened to my joystick, it happened when i put the drivers for it on, then i deleted them and it fixed it. Them the Y axis just stopped about 2 weeks later....
Mar 19, 2008 | Apple Logitech Freedom 2.4 Cordless...
X52 calibration
have the same problem with my X52; cant get the rudder control (twisting control) work fine, but it goes on its own way to the right and can't be calibrated no way. this is my 3rd SAITEK X52 (2 X52PRO, 1 X52), and all I can say is: SAITEK IS THE WORST **** I EVER HAD IN MY LIFE.
Mar 03, 2008 | Saitek (PS28) Joystick, Throttle
Wingman light app. yrs old
Go to control panel double click game controllers Click add from the drop down list click 2 axis 2 button Joystick click ok and wait for it to show in the installed game controllers window highlight the entry and click on properties in the window that pops up click on the settings tab and then calibrate the joystick with the calibrate tab when you have done this your joystick will be working ok.
Oct 06, 2007 | Logitech WingMan Light Joystick
ST220 Joystick calibration problem
Your joystick contacts make that +cursor to make a crazy movement. You should replace that rubber contact on your joystick.
Aug 07, 2007 | Saitek ST220 (J-30U) Joystick
Saitek (PS28) Joystick, Throttle Logo
1,364 people viewed this question
Top Saitek Video Game Consoles & Games Experts
 TE5LA
TE5LA
Jeff Turcotte
Jeff Turcotte
Are you a Saitek Video Game Console and Game Expert? Answer questions, earn points and help others
