Question about Sharper Image Ionic Breeze GP SI730 Air Purifier
Red Cleaning Light won't turn off
I clean my unit religiously, but the red cleaning required light turned on and won't re-set. I have cleaned the unit, blown air into it, and even turned it upside down. How can I get the unit to re-set? The red clean light on my purifier won't go off and the purifier won't run while the light is on. I have cleaned the purifier, tipped it upside down and all that and it still isn't working....help!
  • 4 more comments
  • Anonymous Jul 27, 2008
    got the same problem, can't find a fix
  • Anonymous Jul 28, 2008
    I have tried cleaning the unit over and over again as well. The cleaning light just blinks at me. Same problem, and solutions?
  • Anonymous Aug 23, 2008
    I have the same problem. D id you find a solution?
    Ern
  • Anonymous Aug 26, 2008
    tried it all nothing works. cleaned it; turned upside down. blewout with air cleaner.
  • Anonymous Sep 06, 2008
    not only does the red light stays on,but i don't feel any air coming out .i don't think its working.don't know where to take to fixed.also have another one the gp ionic breeze and thet one's blue light stays on.i'v e tried everything to keep it clean turned upside down numerous time and using hair dryer to blow out the particles nothing works.
  • rmay365 Oct 12, 2008
    My Ionic breeze red light comes on and stays on it has been cleaned the wires are intact and turning it upside down doesn't work.
If the cleaning light stays red it is do to a failure of the nichrome wire sensor that detects deposit build up. This wire is locatied in the center where the grids are removed and easily broken. It runs from top to bottom twice. Look inside and if you see a loose wire that looks like a fine thread that is your problem. Not a do it yourself job.
Posted on Aug 29, 2008
  • rrxpert Aug 29, 2008
    My previous post was incorrect. The wires in question (after a more complete analysis) are a safety feature. If excessive arching occurs the wires will be broken by the arc and a spring loaded switch will deactivate the cleaner causing the clean light to flash red. Replacing the wires requires a lot of dismantling, any wire of the proper diameter/guage and strength will do (someone used guitar string). Replacing the wire however does not consider that there may be an electronic problem and the arcing will continue.....excessive arcing can cause a fire.
After cleaning the unit, replace the grid into the unit. Hold upside down for at least 30 seconds to reset.
Posted on Jul 28, 2008
I have had the same problem with my one of my ionic breeze units. I noticed that when I pushed the boost button the red clean light would remain off while the boost cycle ran. I don't know how long the cycle lasts, 10 minutes? My solution was to keep the boost button depressed permanently by sticking a small piece of metal between the plastic button and the housing. The unit has been running that way for two days so far. Hope that helps. I don't know what location or type of sensor turns the clean button but that would be a good starting point.
Posted on Aug 01, 2010
We need to find the manufacture since it is a private labeld product. They will be our solution. I have two units that had the blue lights come on after almost a year use. I have cleaned them back to original condition to no avail.
Posted on Jul 26, 2008
Red light comes on after cleaning S1730 GP Sharper Image
Make sure filter is positioned correctly and fully seated.
If it does not come on with a clean dry filter it may be a faulty high voltage component.
Feb 05, 2012 | Sharper Image Ionic Breeze GP SI730 Air...
My unit keeps turning off, attention required red ligth is blinking, I just clean te unit
make sure not to forget cleaning the corona wires. i used light grade sandpaper and gently cleaned the wires as well as scrubbed the metal grids with scotch brite pads. the unit has been running normally .
Aug 01, 2010 | Sharper Image Hybrid GP (SI724) Air...
"Cleaning overdue" red blinking light after cleaning was done
Check that there are no fine pieces of lint that are bridging the plates or the ionizing wires, to ground.
Check the contact points of the collector cell and inside the unit.
The light is caused by a shorted collector cell and associated components.
Dec 21, 2009 | Sharper Image Ionic Breeze GP SI730 Air...
Red light stays on continually.
Same problem : after cleaning thoroughly inside by removing the Front & Rear Plastic grid and the stainless blades, I also cleaned the 2 wires (very softly and carrefully, not to break them), but the Red light goes on after only few minutes :
Here is my last Solution :
1 - Turn on (Low position) although the Red ligt is on
2 - Release the Rear plastic Grid (or Front plastic grid, or both of them) : That stop the unit automatically
3 - Replace it and make sur it's well locked : the unit turns on automatically.
After that, my unit works well, no mor Red light.
But my husband will see if he can by pass the Cleaning detector, so we will not have this stupid Red light on anymore !
Good luck.
Feb 22, 2009 | Sharper Image Ionic Breeze 3.0 Air...
RED CLEAN LIGHT
After cleaning the unit, blue light turns on momentarily then red cleaning light comes back on. Have cleaned and dried unit including the contacts on the end (cleaned with alcohol). Sounds like a common problem, any solution?
Bob
Jun 17, 2008 | Ionic Pro 901P2RIP04 Air Purifier
Take it back. Hopefully it is inder warranty. I have had 2 units do the same.
Nov 29, 2007 | Sharper Image Ionic Breeze 3.0 Air...
Red Cleaning Light is On
I have the same problem. I totally took the unit apart and cleaned it out. After I reasembled it, the same thing. Just that little cleaning overdue light on. I can tell that it is not working as well as there is no breeze coming from the front. That is what I get for buying a serviced unit.
Nov 25, 2007 | Sharper Image Professional Plus Ionic...
Ionic pro won't turn on
Solution, perhaps...
All electrical contacts can get a film on them. Try cleaning the contacts (at the bottom of the blade unit; you should see the three with the blades out) with an alcohol swab (make sure the contacts are dry before reassembly in this case) or a pencil eraser (vacuum the debris out before attempting to start it again).
If those contacts don't make up properly, the unit will think it needs cleaning, even though it doesn't.
Mar 27, 2007 | Ionic Pro 901P2RIP04 Air Purifier
Sharper Image Ionic Breeze GP SI730 Air Purifier Logo
1,120 people viewed this question
Top Sharper Image Air Purifiers Experts
Daniel Dollive
Daniel Dollive
Jay Finke
Jay Finke
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
