Question about SanDisk Sansa e250 MP3 Player
My Sansa said its in Recovery mode
I was putting my songs on a then all of a sudden it said its in "Recovery Mode" please i really need help, wast am i suppose to do
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Aug 14, 2008
E250 How do i downGrade
Recovery mode:
first, Create a blank file with filename "sansa.fmt", put the player to recovery mode this way = you have to enable the hold key then plug it to your computer while holding the record button. you may release it after you see 'welcome the recovery mode'.
Then drag-drop this file, the file will tell the device to format itself after you unplug it
Hope this help, if so please leave rating
81
Nov 25, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e200 shows refresh database fail
try putting it in MSC mode and formating it and then putting back on MTP mode. Hope that works
Aug 24, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250 formatting and memory troubles
you should try putting into recovery mode. to do this, connect it to your computer, then push the hold button down so the orange is showing. Next you want to hold down the record button on the side of your mp3 player, now while holding that down also press and hold the power button. in a few seconds it should go to recovery mode. if you need more information, heres a link to the forums. http://forums.sandisk.com/sansa/board?board.id=e200
Feb 07, 2008 | SanDisk Sansa e250 MP3 Player
Bad trak
format the player in MSC/Rhapsody mode. Then restransfer the songs back to the player.This is usuall cause by a bad file in the player, If you are unable to get to the menus of the player. Perform recovery mode on the player and create a sansa.fmt on the player then let if format the device.
Dec 07, 2007 | SanDisk Sansa E280 MP3 Player
Few issues with my sansa..
Sounds like your music may have become corrupt.
You can follow these steps to erase and start anew.
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://rapidshare.com/files/67740173/e200fw01.00.12.exe____
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Nov 08, 2007 | SanDisk Sansa e250 MP3 Player
I cant find the songs to delete and it the refresh database fails everytime
If you cant see it in MTP mode, the MTP drivers may not be installed on your computer.
Its easier to do this than explain the other solution.
Follow these instructions and you will be back in business.
http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe
Best of Luck.
Oct 14, 2007 | SanDisk Sansa e250 MP3 Player
Formated the SanDisk Sansa E280
You dragged & dropped files in recovery mode? Recovery mode is only for re-installing the firmware or formatting the device if it is unresponsive. If you are wanting to drag and drop files onto the device, the music needs to be put into the Music folder on the device. If you do not see the Music folder, you will need to enable hidden files and folders on your PC. Best of Luck. p.s. - you can add to this question this doesnt work.
Oct 08, 2007 | SanDisk Sansa E280 MP3 Player
Recovery mode
Recovery mode won't help you unless you have the recovery files to go with it. Most likely you will need to re-install the firmware on to the device. Download this "recovery tool" from the SanDisk website and run it with your device connected in recovery mode. Make sure you select "format" when prompted. Tool is here; http://sandisk.com/assets/file/downloads/firmware/e200fw01.00.12.exe Recovery mode - power off device. Slide "hold" switch into hold position. Press and hold "record" button and then connect to PC.(keep record button pressed until after connected to pc) Hope this helps.
Sep 04, 2007 | SanDisk Sansa E280 MP3 Player
Computer won't read mp3 player
Same exact problem! Sorry I'm no help > My Sansa e250 has been working fine for about a year. No problems, I can charge and sync it. > Now all of a sudden I have a problem. > My PC does not see the Sansa. Why? > I enter recovery mode. I see: > Welcome to "Recovery mode" Please connect USB Cable. > I connect the usb cable AND NOTHING HAPPENS! > Yes I read all about recovery mode on the internet. I tried it in both MSC mode and MTP mode. > How can I get my computer to see the sansa? > If my PC can not detect the Sansa then I cant get a firmware update now can I?
Jul 23, 2007 | SanDisk Sansa e250 MP3 Player
Why won't it turn on!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Recovery Mode:
Jun 09, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
15 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
