Question about Freezers
Freezer running all the time
I purchased a Gibson upright freezer model FV10M2WXFD it runds all the time. We replaced the thermostat and it is still not getting cold enough. All shelves get frost except for the one that has the thermostat on it. Any other options on what could be wrong? Thanks
  • 237 Answers
SOURCE: Whirlpool Freezer Model #EV150NXENOO
This one sounds like the defrost timer is not working and you are not getting a defrost cycle every 6-8 hours (or when needed). Another issue could be that air (moisture) is getting in from a leaky door seal, etc. and causing the freeze up. If you have a sealed system problem where the cooling coils are not uniformly frosted up then the defrost thermostat will not "know" there is an ice condition and therefore not go into defrost mode (same issue if the defrost t-stat is bad). After you have ALL the ice out of the unit it would be a good idea to take the interior rear cover off so you can view the coils. Start the freezer back up and watch over the next 1/2 hour or so to see that the entire coil is frosting up uniformly. If it isn't you may have a plugged system, a leak causing low refrigerant, etc. If over time the coils look uniformly frosted up you may have a defective defrost heating element itself (no heat, no defrost sort of thing). The defrost elements can be checked with a multimeter for continuity if you know how to do that sort of thing. It's hard to know a person's ability by these forums or if they can tackle certain test procedures.
Posted on Nov 13, 2006
  • 473 Answers
SOURCE: upright freezer
Three things could be the problem. Most likely would be the defrost thermostat which clips onto the evaporator behind the panel in the freezer. 2nd would be the timer or control board (will have one or the other). 3rd would be a bad defrost heater. Alot of times the def. therm. will show obvious sign of being bad by the cap on top popped open. You can check resistance on the heater. Any resistance at all on the heater means it is good. If it has a standard timer turn it clockwise until it clicks. This is putting it into defrost. If the heater comes on the timer is bad. If it has a control board you would unplug the unit then unplug the power supply to the board and jump line 1 to the wire going to the heater. While unplugged from the board and jumped, plug the freezer back in. If the heater comes on then the board is bad. If you are not sure how to test replace the def. thermostat, which is the cheapest part and see what happens. Note: When conducting the test for the timer or board the def. therm. must be freezing so don't defrost first! Hope this helps.
Posted on Oct 06, 2007
  • 11 Answers
SOURCE: My GE upright freezer does not get cold.
Sounds like the system is low on freon. The other common problem is a dirty condenser. Insure the condenser is clean, if it is. You will need to charge the system with freon. Which only a qualified refrigeration tech should do.
Posted on Nov 28, 2008
  • 370 Answers
Sounds like you are low on freon.
Posted on Dec 01, 2008
  • 10 Answers
SOURCE: My woods upright freezer keeps
check your door seal, by closing the door on a strip of newspaper all round the seal. this fault is usually air getting inside the freezer, it rises to the top making thick ice or snow.
Posted on Feb 07, 2009
Whirlpool Model EV090FXK compact upright freezer does not run. Sat for over 15 years. Any manuals available for this old freezer?
The thermostat may be stuck froze in open position, in off and not closing, calling to replace the thermostat or the defrost timer
Jul 18, 2017 | Whirlpool Freezers
Need a manual for 253-9284215 Kenmore Upright Freezer
The first three number are who made your refrigerator, Gibson (Frigidaire) Below are the model numbers that the user manual falls under, Click Here=> 253.9284215
KENMORE Upright Freezer Model: 25321711103, 216769200, 25321402101, 25321741102, 25329201002, 25321402102, 2539280415, 2539287215, 25321041100, 25321201102, 2539280214, 25321411100, 25321211101, 25321421104, 2539284215, 25320211002, 25321111103, 25321421101 If you have questions please let me know, Thanks, Sea Breeze
Oct 06, 2010 | Freezers
I lost the key for door of my kenmore frost free commercial freezer where can i purchase the key?
Hi, here is the replacement key for your model, you can purchase it for $ 2.65:
KEY (Freezer Door Key)
To buy the part call toll-free at 1-888-895-1535 from 7:00 AM to 9:00 PM Eastern time, Monday to Friday and Saturday from 8:00 AM to 6:00 PM Eastern time. Mention part PS426673 (Part Select Number).
Good Luck
Aug 22, 2010 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Older Gibsonl upright freezer not cold
dear sir
please make sure first your freezer is well clean if it is already clean then contect to maintenance personell for refilling the gas.
hope answer the question.
thank you.
Jul 05, 2010 | Frigidaire Freezers
Old hotpoint upright freezer only has 1 temp artic blast....
I would replace the thermostat because is the only thing that controls the temp. , also there's a timer and a terminator but them are only for defrosting the unit.
Aug 13, 2009 | GE 16.7 cu. ft. / 473 liter Upright...
Upright freeze made a popping noise like a thermostat
If you heard the noise at a fairly routine rate and time it was probably the defrost timer motor. Locate it and you should be able to engage it manually. It is a plug and go part to replace. Be sure to take the old one along with the make n model # with you to the parts house!!
Jan 17, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
hi thanks for the question first is the compressor running if it is & not cooling . your freezer has lost its refrigerant if so not worth repairing worstthing people do is not use a freezer for a long period of time its ok for fridges as they are built different thanks the appliance doc
Sep 26, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
My freezer's defrost systems runs constantly
i dont think so i would look at the compressor kicking out on thermal overload or a faulty thermostat thermostats have two settings cut in cut out your cut in could be bad and not turning the compressor on till the temp reaches melting temps now if your hearing a click buzz then you need to look at the compressor and make sure the compressor fan is running but its not a defrost promblem
Sep 11, 2008 | Frigidaire Freezer Refrigeration White...
Freezers Logo
57 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
