Question about Dishwashers
Indesit DI620UK Dishwasher fault
My indesit dishwasher has stopped heating the water during the wash cycle and at the end when drying.
When I opened the door light 4 was flashing. Can you tell me what this means.
Is there a way to find out if it is the heating element that is faulty or the temperature sensor.
  • Anonymous Jan 21, 2009
    Water not heating. Dishes not drying. Light 4 flashing when door opened at end of cycle
    Scholar:
  • 191 Answers
If the dry cycle has a problem, check these:
Heating element
Drying fan
Thermostat
Heating element Your dishwasher has an electrical heating element that helps to dry the dishes. If the element is burned out, the dishes won't dry properly, and you need to replace the element.
Drying fan Many high-priced dishwashers have a small fan that blows air or heated air into the dishwasher to speed up the drying process. If the fan is defective, you need to replace it.
Thermostat Some dishwashers have a thermostat that monitors the drying temperature. If the thermostat is defective, the heating element may not cycle on or off properly. If that's the problem, you need to replace the thermostat
Posted on Jul 19, 2008
My indesit dishwasher is not drying when the cycle is finish
Possibly the drying /heater element is faulty. Check the machine isn't on a non drying cycle. Some machines will do the last rinse in hot water but leave the dishes to drip dry in the hot humid air after the rinse. If the dishes or water isn't hot during a rinse , I would say its the element.
Mar 21, 2017 | Indesit Dishwashers
My indesit idl40 cleans everything, but leaves a film? does not seem to rinse?
Hi, what you are currently experiencing is as a result of dishwasher detergent, combined with mineral deposits from hard water, which in yurn can leave a white film on the inside of the dishwasher.
You have to clean the dishwasher by sprinkling baking soda onto a damp cloth. Scrub the inside of the dishwasher to remove soap scum, grime and mineral deposits.
Pour 2 cups white vinegar into the bottom of your dishwasher. Turn the dishwasher on and run it on a full cycle. Stop the dishwasher halfway through the wash cycle and allow the vinegar and steam to work on the remaining mineral deposits for 20 minutes before resuming the cycle.
Open the dishwasher and dry the interior with clean, dry cloths. Keep the door propped open for 20 to 30 minutes to allow the dishwasher to dry completely.
Jun 26, 2011 | Indesit Dishwashers
Dishwasher fault codes
the heating element is probably bad.
i have a idl 600 here in naples italy and it would fill up and go into alarm light 2 and 4 and pump out the water.
heating element cost 28 euro and i changed it out.
had to change the clamps as well.
if you ohm the element it should show about 100 ohms.
if it is open its bad.
the mother board does some checks and if anything fails it alarms out and drains the water after a few minuts
ralph
Jun 02, 2009 | Indesit 24 in. IDL500 Built-In Dishwasher
Indesit DG6100W problem...please help!
Hi, I have the same dishwasher and it fills from the cold supply, not the hot and it doesn't have a cold cycle as is previously suggested, as you will know kellyemb :-)
The Indesit DG6100W does a fill from the cold and heats as it washes, so if it's sticking part way through, it could be the heating element. Have you tried opening the door when it sticks and seeing if the water is hot? The heating element went on ours and it kept tripping the electric whenever the it tried to start to heat the cold water. If it is the element, they don't cost much to replace, even cheaper if you know someone who can fit it for you! Ours cost us around £12 and hubby fitted.
The only other thing I can think of is it might be the timer, like someone has suggested but how to reset it, I have no idea. I have seen on another website that a replacement timer is around £55 plus VAT, which is a little expensive.
Hope you get it fixed.
Jul 01, 2008 | Dishwashers
Dishwasher
Check to see how fast water is entering the dishwasher.
They work on a timed basis with a float switch being a safety.
You may want to check how the water gets into the dishwasher and  then see if there is plugging somewhere.
Feb 16, 2008 | Indesit 24 in. D61 Free-standing...
Indesit D61 Dishwasher element fault?
poss element or heater relay on the pcb.
Jan 19, 2008 | Indesit 24 in. D61 Free-standing...
Indesit IDL40 Slimline Dishwasher - Won't start cycle
indesit idl 40 not pumping water out properly, ends with flashing light no 4 and plates dry but water still in machine -have to pump out using start stop button but within 2 hours base filled up with water. Can't afford massive call out prices as lady on my own.....
Nov 12, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
Dishwasher problem
My dishwasher Indesit DI67S will not run on the number 1 cycle. It will fill and then when that programme finishes it jumps straight to the drying cycle missing all the rinses out etc. If on the number 2 programme it goes all the way through but then doesn't dry. I've also noticed that the water doesn't seem to be heating up much and certainly isn't drying. Is this the element or something else? Once its reached the drying cycle the light for this just flashes then I have a job to try and reset the machine. It can take endless attempts. Will switching the machine off at the mains solve anything or is it the element?
Thankyou
Oct 09, 2007 | Indesit 24 in. DI67 Free-standing...
Indesit dishwasher
element gone. approx 40 quid for element and 30 to fit it.
Jan 16, 2007 | Indesit 24 in. D61 Free-standing...
Dishwashers Logo
927 people viewed this question
Top Dishwashers Experts
