Question about Sony STR-DB790 Receiver
Sony STr-DB790 problem
When switched on the sony is atuomatically on protected mode and un able to be taken off of this, how is this done?
  • 682 Answers
Please check your speakers cable for internal short circuit-disconnect all speaker cables and test if everything is fine continue to connect speakers one by one until you find the bad one when you find it change its cable first and test then the speaker itself.if the problem still after disconnection ask for help from good service center.
Posted on Jul 19, 2008
How do I enter the Test Mode on my RISO 790 duplicator?
Do you mean into the unprotected mode?, if so
Turning OFF Protect mode in a Riso MZ 790u (and other models I'm sure).
1. Go to Admin Tab on the main console screen and scroll to the "Protect" button.
2. Select (press) the "Protect" button on the screen; printer will go through a reset function (takes about 3-5 seconds).
3. After printer is finished "resetting", pull out one of the master disposal boxes (doesn't matter which one).
4. Press the "Protect" button again.
5. the screen should say "Protect = Off"
6. You're done and your machine should be un-locked now.
May 11, 2011 | Office Equipment & Supplies
DVD-DZ10 OPEN AND COUSE ATUOMATICAL AND NODISC ASHOK Y.
there is a broblum in your lense block actually sled motor is not working & not tuch the limit switch thats why cd tray doing automatically open close please chang the lense assy to your nearst sony service centre
Apr 13, 2010 | Sony DVP-NS575P DVD Player
I HAVE A SONY RECIEVER SRT-DE597 6.1 CHANNEL AND I ITS ON PROTECTED MODE CAN YOU HELP ME UN PROTECTED
Amp output is damaged and needs repaired. Protect mode cannot be deactivated. When amp is repaired and operating normally protect mode will not be displayed.
Aug 29, 2009 | Sony STR-DE597 Receiver
Kenwood car stereo cd player reads protect mode how do i fix this
i have a kenwood kdc-241 car stereo and it has gone onto protect mode i have done everything it says in the manual and even taken it out of the car just in case it was damp i have tried putting it back in but still is in protect mode can anyone help me please
May 25, 2009 | Kenwood Car Audio & Video
Sony home theater system started blinking protect
Protect mode will kicking whenever a fault is detected.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Mar 23, 2009 | Sony DAV-DX250 System
Jvc protect
Protect mode will kick in whenever a fault is detected.
You get the unit not powering up, and sometimes you hear a clicking noise, that is the protection switch that keeps shutting down the unit.
Bad speaker wiring.
Internal fault.
Regards.
Feb 28, 2009 | JVC FS-S77 Micro 5 Disc DVD Audio/Video...
Sony ht-sl5
If your problem is "switch on then after 10secounds shuts down and protect appears on the display .and cannot do anything with it but turn it off"
Then the unit is on protect mode, that is a special diagnostic mode that starts when the unit detects an internal fault.
To start unplug the unit from power for ten minutes, and see if this reset the protect mode, I guess you have done this already.
The first thing to do is to start the unit with nothing connected, if the unit does not go to protection, then the problem was one of the cables or a connected device.
If that does not fix it , there is a master reset , by pluggin the unit into main while at the same time you hold the power button.
If still no luck then the unit is defective and must be taken apart and tested with a multimeter.
You start checking for burnt areas on circuits, cold solder joints and leaking capacitors at sight, then there is need to grab the multimeter and do the real testing job.
When you find the problem you do the soldering.
Naturally this requires a certain experience in fixing electronics, to complete the job usually a precision soldering is needed.
Feb 17, 2009 | Sony HT-SL55 System
Home theater system hx-tx72
Bad speaker wiring.
Internal fault.
Regards.
May 30, 2008 | Samsung HT-TXQ120 Home Theater System...
Stuck in protect mode
Speakers shorted out, blew a fuse. Replace the unit or (cross your fingers and) open up the box and find the blown fuse.
Nov 23, 2007 | Sony STR-DE425 Receiver
Sony STR-DB790 Receiver Logo
424 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
