Question about Solis Palazzo Espresso Machine
Leak water leaks from the steam valve on the upper right of the machine.. where can I buy a new valve? Thank you, Gary
  • Anonymous Aug 13, 2008
    need replacement steam valve assembly, where can i order,
    thank you.
  • Anonymous Jan 27, 2009
    Did Solis provide you with a replacement part?
  • 515 Answers
Hi Gary,
Go to this site and contact Solis.
http://www.solis.com/contents/customer_service/customer_e.htm
Posted on Jul 20, 2008
My Titanium leaking water. Under it
The steam valve assembly that the steam knob on the right hand side connects into is probably faulty. When you're steaming if you hear hissing coming from behind the knob then this indicates the connections into this assembly are leaking steam, and also hot water, which is why you're getting puddles under the machine. You can get a replacement steam valve assembly that fixes some issues with the original (part code SVM-17, available from www.partsguru.com) and will prevent the leakage, or you could simply try opening the top of the coffee machine and removing the tube that runs from the boiler into the steam valve. It has two o-rings that provide the seal where it connects into the steam valve assembly, and if you lubricate these with a food grade silicon lubricant it may fix the problem. My Gaggia is 7 years old so I decided to replace the whole assembly which costs about $50 and that solved the problem completely.
Apr 04, 2011 | Gaggia Titanium Espresso Machine
Saeco Odea Go - Hot water leaks from bottom of machine
That's leaking from the hoses coming out from the boiler,if the machine is new it should be still under warranty, may have to take it back to the service center.When making coffee the lines are under pressure and the water never have a chance to pass through the ground coffee.
Feb 03, 2010 | Saeco Odea Go
Water is dripping out above ,between coffee and
The steam valve housing is probly broken or leaking the line for it runs under the button panal
Dec 15, 2009 | Saeco Vienna Deluxe
Steam/water valve leaks water, only fills coffee to 50%, help? I have completely removed steam valve assembly to clean and reassemble. Leak persists, suspect o-rings?
Hi
If your water valve is cream or black colored, you need a new manifold. They will get hair line cracks if you steam, but don't cool them down after steaming by running cold water through them. If you have one of the new brass(silver) manifolds it could be your O-rings but i doubt it.
Oct 07, 2009 | Solis Palazzo Espresso Machine
Saeco incanto rapid steam leaking from under
The leak is most likely from the steam valve, you will have to either buy and replace the o-rings and the pistons in the valve or just buy a new valve assembly and replace it. Easiest solution get the new valve assembly.
Jun 25, 2009 | Saeco Incanto Classic Espresso Machine
Steam Wand Leaking on La Pavoni Espresso Si
I HAD the same problem. I fixed it for 50 cents. It takes the removal of 4 screws (2 phillips on top, 2 long standard on bottom by the group) to remove the top to access the steam wand valve. Once the the top (and the chrome bezel) is removed, then screw out the valve counterclockwise buy ALL THE WAY until it comes out. There are 2 O-rings on the stem of the valve that wear out, Cut these off with a sharp knife, go to your local hardware store, buy 2 new ones for 50 cents, install new O-rings, and reverse the disassembly procedure. Voila, no more leaky steam valve!
Jun 20, 2009 | La Pavoni Espresso Si PAB-16 Espresso...
Water is leaking, while the machine heats water for steaming
The steam valve tap rod needs to be replaced, or check machine if it has a plastic steam valve, Gaggia designed a new Stainless steel steam valve for the compact machine.
May 23, 2009 | Gaggia Syncrony Compact Coffee...
Leaking steam valve?
You have to replace your steam valve.
Contact a saeco service center to get the new spare part.
Spare part number: 11003733
Jul 31, 2008 | Saeco Incanto Classic Espresso Machine
Water leaking out of the machine when you use the steamer
The steam valve is leaking on your machine, if you open the door you can see the water drip from the right upper corner.
Jul 07, 2008 | Saeco Incanto Classic Espresso Machine
PUFF OF STEAM,CONDENSATION,GRINDS LONGER
The steam and leaking in the upper right corner turned out to be a leaky valve. I may have been able to fix it by just replacing the O-rings. However, the only place I found to get the right rings was in the kit to replace the steam valve assembly.
Aug 31, 2007 | Saeco Vienna De Luxe Espresso Machine
Solis Palazzo Espresso Machine Logo
123 people viewed this question
Top Solis Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
AZBen
AZBen
gbob59
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
