Question about Radio Shack 3808 Digital Answering Machine
Digital answering machine
I am trying to help my mother who called to tell me her machine screeches when she is trting to play messages so she cannot hear the messages.  She also has a fax machine on same line.  Can anyone help me trouble shoot this for her.  Thanks, Bibi
  • Anonymous Sep 25, 2008
    I have a 2+ year old GE cordless 58 gigahertz phone/answering machine on our land line. Worked great for 24 months, now last 4 months instead of recording incoming messages, people are getting the fax "noise" 70% of the time when they call, at which time no message is recorded. I've reread the manual; I have no clue what is going on. Any help out there? Hate trashing phone, but I hate missing what could be important calls more.
    Zman
  • 667 Answers
Hi Bibi - Is this a regular land line? Is the fax machine supposed to answer if it's a fax but not answer if it's a phone call? Let me know exactly what your mothers' setup is please. It sounds to me like the fax is trying to answer all the calls and the screeching she hears is the fax machine try to handshake, or connect, with another fax machine. You've probably heard what that sounds like. Let me know the answers and if you can ask some people that called if they heard anything. Thanks.
Jeff
Posted on Jul 19, 2008
How to change the outgoing message.
Are you at the answering machine or calling into the machine? If you are at the machine, press and hold Annc/Skip. Wait for the beep and then speak normally from about 9 inches away from the mic (just below the Play/Stop button). You will see a dash in the display. To stop recording, press Annc/Skip. The system will play back your message. (If you press and release the Annc/Skip button, it will play back the current message.)
If you are dialing in, once you are into the system, press 7 * and wait for the beep. Speak your message and then press 5. The message will play back.
I hope this helps.
Jan 12, 2011 | AT&T 1717 Digital Answering Machine
Tip
Remote access for machine
This come from a previous model than I have (mine is a ol5870), but seems to work for this one in retrieving messages from another phone.
Default access code is 0000 if you haven't changed it (but you should); when answering machine answer dial in the 4 digit code while the outgoing message is playing.
Once in dial 1,2, or 3 to play messages (mail box number I believe)
You can dial * for a help menu
4 Repeat a message
44 Ignores a message (message won't remote retrieve next call)
6 plays next message (skip to next)
7 Deletes message
8 Lets you record a memo
9 Let's you change the outgoing message (5 stops the recording)
0 Toggles answer on/off
I hope this helps some people at least in part.
on Feb 14, 2009 | Olympia OL5870 Digital Answering Machine
Need answering machine with externally inaudible greeting
You could always simply turn the volume down? to the speaker, well as long as she uses the handset?
Feb 15, 2010 | GE 29871GE3 Digital Answering Machine
I have an AT&T 1738 answering machine that has developed a large amount of static when the announcement message is played. I have tried to re-record the message without success. Any help would be...
The microphone (located inside the unit and points downward to the surface below the answering machine) might be bad (assuming that messages left by callers sound clear).
One option would be to call into the machine and try recording your greeting that way. Else, there isn't much that can be done other than to replace the unit.
Jul 31, 2009 | AT&T 1738 Digital Answering Machine
Machine not answering. new battery. lights on with 0 messages.
When the power went out it may have set the machine to its default setting, "answer function off". Press the "On/Off" button to check for sure. A battery really wouldn't help in this matter because it's only there for backup; when the power goes out the batter will save your settings, outgoing and incoming messages. Perhaps when the power went out you lost your outgoing message, and now, when people call, they don't realize that that they are supposed to leave a message. One more thing you can check is the switch on the side of the phone which tells the machine to answer after 2 or 4 rings.
Nov 17, 2008 | BellSouth Digital Answering System 2006C...
Loud, screeching noise when taking a message
Managed to clear it myself. After making several cell phone calls to my machine last night and unplugging it over and over, etc. I gave up. This morning I again unplugged everything, reset all the settings and called the machine several times. At first I kept getting the "noise", but eventually I was able to call and leave a normal sounding message. Can't really explain what "cured" it! In desparation I did shake the machine and give it a hard slap, but who knows what did it!
Apr 05, 2008 | GE 29875GE Digital Answering Machine
Can this machine be turned off and on remotely
There are zero message on the machine, but the machine says "messages full" to the caller after if answers and plays my recorded message. It also flashes "F" on the display. I can't figure out how to reset it so that it will answer my calls. Can you help?
Mar 20, 2008 | GE 29871GE3 Digital Answering Machine
Remote answering
you have to set the answering machine to accept remote access. Then anytime when you call home and the message is playing you can enter the machines' remote access number to retrieve your messages.
Dec 13, 2007 | AT&T 1738 Digital Answering Machine
Erasing messages
Hi. I think you have to wait until more calls come in. If you did not save original message(s), then these will then go away FOREVER.
Aug 15, 2007 | Southwestern Bell FA-970 Digital Answering...
Radio Shack 3808 Digital Answering Machine Logo
183 people viewed this question
Top Radio Shack Lands Phones Experts
Greg Cann
Greg Cann
Are you a Radio Shack Lands Phone Expert? Answer questions, earn points and help others
