I have an RCA 26 inch LCD TV that I bought on February 25, 2006 (Serial # EA033F483E3174. I was watching the British Open golf tournament and left the room for a few minutes and came back to a blank screen. I then tried the remote...shutting off the TV...and tried to restart it (turn it "on") again. The red light at the lower right goes on for maybe a second then goes out with a click. The same happens if I go to the switch on the TV itself (the power "on/off" switch). Tom in Tucson, AZ email address is: archangelx47@hotmail.com
  • archangelx47 Jul 19, 2008
    Yes...this is the first time it has happened.
    Tom In Tucson, Arizona
    It is not a steady blinking light...it just comes ON briefly when I turn it on at the set (power on/off switch) or if I use the remote control. It then goes out and stays out immediately.
    Brigadier General:
  • 3,614 Answers
Is this the first time happen?
Posted on Jul 19, 2008
  • micromaster
    micromaster Jul 19, 2008
    if you have no idea, the tv needs a repair...
    The steady blinking light means there is no specific code. The double-side board (the one lying flat/horizontal just to the right of the vertical power supply board which has the fuses) has a burnt transistor (the one with the sizable heat sink on it, at the back left corner when looking at the board from the rear of the TV). It is blowing the (non-power supply) fuse.
    let me know..
  • micromaster
    try to remove remote battery and use the control on your tv..
What is the model number for a replacement remote control for RCA L26WD21 TV (LCD, 26 inches)
You can use the universal remote and use the code to match your television with the remote control.
Jan 03, 2015 | RCA Televison & Video
We bought samsung LCD 26 inch last july,in august 2010 suddenly our LCD off,engineers said your panel and Ip circuit is not working..so only option is left buy new one or repair the LCD.What should we do?.
Check the cost of repair estimate. If you have covered under General Insurance policy try to get the claim.
Ask the Engineer to identify the fault. Both LCD panel and drive electronics can not fail together. If so it must be a lightning strike!
Check the estimate value and decide. After repairs insist for warranty.
Sep 08, 2010 | Samsung LA26R71BD 26 in. HD-Ready LCD TV
TV picture not available.
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
Hope this help....
Jun 21, 2010 | Vizio L37 Television
Moving objects extremely blurry in SAMSUNG LCD-football, golf,etc
This is a problem that will pretty much just be there on this TV. I know it has an awesome picture...as long as nothing moves. You can try putting it in "Game Mode" in the user menu and that usually takes care of it but you didn't buy the 120/240 Hz tv to watch it in 60Hz. I would say exchange it, and in my opinion buy a good plasma :)
Jul 08, 2009 | Samsung LN55B650 55 in. LCD HDTV
I just bought a Dynex DX-LCD19-09 19 inch TV. I also have a Phillips home theater system. I have digital cable and I cant figure out how to hook it up to where i can watch regular tv but hear it through...
The only audio out jack on your TV is for the headphone on the left side of the TV. You need to purchase a 3.5 mm to RCA audio cable, connect the 3.5mm jack to the left side of your TV and the 2 RCA audio cable ends to the audio in of your Home Theater and then select AUX 1 or AUX 2 on the home theater depending on which jacks you plugged into.
Mar 09, 2009 | Dynex DX-LCD19-09 19 in. LCD TV
RCA 26" SRS WOW has a grey shadow display when watching TV
yeah, I just got one of those and when the picture is full screen I see that also. I just have the picture set to 14:9 and the pic is crystal clear. any good resources for a wall mount?
May 29, 2007 | RCA LCDX2620W 26 in. HDTV-Ready Television
Televison & Video Logo
70 people viewed this question
Top Televison & Video Experts
Electro Med Services...
