Question about LG LRE30451ST Electric Kitchen Range
LG LRE30451SW range
The light bulb in the oven is burned out. According to the owners manual, I remove the glass cover by turning it counterclockwise. The cover will not turn either way to release. I have to get my head out of the oven. Help please.
Little old widow in Florida
  • Anonymous Mar 27, 2014
    Creda S150E Top oven bulb does not unscrew. Glass cover is removed but the bulb does not turn. Have used rubber grip pad to no avail. Ideas anyone?
    Scholar:
  • 191 Answers
The interior oven light in most ovens is a standard 40 watt appliance bulb. Often, to change the bulb, you first need to remove a shield or glass dome. If the bulb isn't burned out, the problem may be with the switch on the oven door frame. If the switch works poorly, intermittently, or not at all, you need to replace it.
Posted on Jul 19, 2008
How do I get the glass cover over the oven bulb off to change the bulb? The cover turns a 1/4 inch and will not go any further. Pushing or pulling will not help.
Sometimes those glass covers are real hard to turn. Get one of those rubber "mats" or "grippers" designed to help your remove stubborn jar lids (that you can pick up at Ace or True-Value Hardware Stores) and try that. You may also find it helpful to remove the oven door, if the cover is really stubborn.
Sep 15, 2014 | Kenmore 92022 / 92024 / 92025 / 92029...
LG stove - glass cooktop broken - model LRE30451SW/SB/ST how do i remove and replace glass cooktop on LRE30451SW/SB/ST?
Open the oven door and you should see screws on the overhang where the door fits in,take those off and that should loosen the whole top of the stove,then you will see what to do next and what you have to remove to replace what you need,hope this helps some what.
Feb 19, 2014 | Kitchen Ranges
How to change oven light
Which model Whirlpool range do you have? For most Whirlpool ranges that I have used , the oven light is covered by a screw-on glass cover. When the oven is cool, unplug the range, open the door and turn the cover counter-clockwise (to the left). Then remove the 40W bulb (again counter-clockwise rotation). Replace the bulb with another 40W appliance bulb. Then replace the cover by turning it clockwise until it is tight. Do not over-tighten either the bulb or the cover. Then plug in the power cord for the range. (Unplugging the unit makes sure that you will not get shocked if anything goes wrong. Sometimes the bulb may break in the socket - in that case, use pliers to unscrew the base of the bulb before replacing it with a new bulb.)
Whirlpool has the manuals for most of their appliances on their support site: https://www.whirlpool.com/webapp/wcs/stores/servlet/OCManualsLiteratureSearchView?catalogId=10561&langId=-1&storeId=10211&krypto=5QgxQhneFliXuEuX564wSQ%3D%3D&ddkey=http:OCManualsLiteratureSearchView .
I hope this helps.
Jan 11, 2012 | Whirlpool 30" Self-Cleaning Freestanding...
I want to change the light bulb in the oven,.Mod.no.ZDQ695A can you help me.
I will assume that the ZDQ695 bulb replacement procedure is the same as that for the ZDQ695A. The ZDQ695 uses a 25 W appliance light bulb (300 C). Unplug the appliance before starting. Open the oven and remove the racks for space to work. Insert a flat blade screwdriver between the side of the oven and the glass cover above the bulb. With your hand support the cover and pry it away from the wall of the oven until it releases. Push the top of the cover towards the oven wall and use your fingers to pry the bottom of the cover away from the housing. Then remove the cover. Unscrew the old bulb (counterclockwise) and then remove the bulb. Then screw in the new bulb. Replace the glass cover (position the flange so that it is pointing to the back of the oven) by pushing it into the hole to cover the bulb assembly. Replace the shelves and close the oven door before plugging the oven back in.
Zanussi manuals are available here: http://www.zanussi.co.uk/en-gb/Support/Manuals/ . Enter the model number in the search box. Alternatively, the manual for the ZDQ695 is available here: http://kitchen.manualsonline.com/manuals/mfg/zanussi/zdq_695.html . Click on the Get This Manual button.
I hope this helps.
Jul 24, 2011 | Zanussi ZDQ695 Electric Double Oven
I cannot remove the oven light cover in my Whirlpool gas range.
Put on a rubber 'serving' glove or dish washing glove and it will give you some traction to grip the glass to turn it
Sep 23, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
How to replace oven light bulb for beko DC543 electric cooker
hi
You may need to remove the glass cover by turning it anti-clockwise.
On some models access to the bulb is from outside so the oven has to be slid out of it's housing and an access plate removed.
chek this following steps..
Step 1 Make sure the bulb is actually burned out. Confirm the oven is plugged in and that a circuit breaker is not tripped.
  • Step 2 Look for the manual to determine what size bulb is required. Most use a 40 watt appliance bulb. If you can not find the manual, then buy a bulb to replace it after you take out the old one.
  • Step 3 Confirm that the oven is not on. Allow it to cool to room temperature if it has recently been used.
  • Step 4 Open the door and use a flashlight to light the area where the bulb is located. Do not put weight on the door itself, but go in at an angle or sideways.
  • Step 5 Find the shield or cover over the bulb, gently pull or twist it off. Some glass covers are surrounded by a wire clip or a ring that is screwed in to the back.
  • Step 6 Gently remove either the wire clip or ring. Since the cover is most likely glass, be cautious. Unscrew the entire glass cover similar to a jar lid in older versions of ovens. Then repeat process if there is more than one bulb.
  • chek this usefull link
    http://www.espares.co.uk/advice/cookers-and-hobs/a/1/112/changing-your-oven-light-bulb.html
    hope u will b helpfull
    tnx for contactin fixya
    regards
    Jul 12, 2009 | Ovens
    Could you please advised me how to take a bulb out of my Hoover oven and how to replace? Many thanks Jeanette Jollyjeanette@yahoo.co.uk
    Before doing any work on an electric range or oven, make sure it's unplugged, or turn off the power to the unit by removing one or more fuses or tripping one or more breakers at the main entrance panel or at a separate panel. If the range is fused at a separate panel, this panel may be located adjacent to the main panel or in a basement, crawl space, or other location. If there is a grounding wire to the range, disconnect it. Make sure the power to the unit is off.
    you'll want to replace it using these simple instructions.
    1. Look for the manual to determine what size bulb is required. Most use a 40 watt appliance bulb. If you can not find the manual, then buy a bulb to replace it after you take out the old one.
    2. 3Confirm that the oven is not on. Allow it to cool to room temperature if it has recently been used.4
    3. Open the door and use a flashlight to light the area where the bulb is located. Do not put weight on the door itself, but go in at an angle or sideways.
    4. Find the shield or cover over the bulb, gently pull or twist it off. Some glass covers are surrounded by a wire clip or a ring that is screwed in to the back. 6
    5. Gently remove either the wire clip or ring. Since the cover is most likely glass, be cautious. Unscrew the entire glass cover similar to a jar lid in older versions of ovens. Then repeat process if there is more than one bulb. In most microwaves you simply have to take the cover off by unscrewing holding screws. Replacing bulb is pretty straightforward, simply take out holding screws, disconnect leads, and remove bulb from place.
      To install new one,reverse steps.
      Usually it is really hard to find replacement parts. It is usually better if you take microwave name, model and serial number, and take info to a place that specializes in appliances
    Tips & Warnings
    • Consider replacing the switch on the oven door if you replace the bulb and the light still does not work. Shut the door and open a few times or press the button manually to see if the light works randomly or not at all. hope this helps thanks and Godbless
    Nov 06, 2008 | Kitchen Ranges
    Replacing the oven bulb
    Try taking the cover for the fan and element off -- I found this is the only way of getting a decent grip on the glass. It's four Philips screws. Obviously make very sure the oven's properly cold and isolate the electricity supply before you do it!
    Nov 07, 2007 | Belling DB90 Electric Kitchen Range
    Kenmore oven: glass dome for interior light removal
    Hopefully someone answered your question by now. If not, the glass bulb cover sticks sometimes, but it does turn counterclockwise. Be firm with it, let it know who's boss. Once you've removed it, you can replace the 40 watt appliance bulb. (The manual suggests you unplug the range or disconnect power for your safety). Good luck.
    Oct 23, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
    LG LRE30451ST Electric Kitchen Range Logo
    590 people viewed this question
    Top LG Kitchen Ranges Experts
    JP Services
    JP Services
    Dan Webster
    Dan Webster
    Mike Carew
    Are you a LG Kitchen Range Expert? Answer questions, earn points and help others
