Question about Epson Livingstation LS57P2 57" Rear Projection HDTV
Epson problem I turn on tv it comes on for 2min. then power and lamp lights go solid red with no picture.I tried a new bulb same result.What to do?I've tried unplugging the tv with no results.
  • Anonymous Aug 16, 2008
    same problems
  • 4 Answers
Have you contacted epson?
Posted on Sep 07, 2008
Power light blinking red..tv won't come on after replacing lamp
DLP TV Repair Tutorial - DLP Bulb Won't Turn On - YouTube
? 14:13
https://www.youtube.com/watch?v=5frOnh58Z6M
Jun 26, 2013 - Uploaded by ShopJimmy.com
DLP TV Won't Turn On Common How to Replace Ballast DeadTV ... solid green power light plus sound ...
• New Lamp Doesn't Turn On? Try This! - Fix Your DLP - FixYourDLP.com
www.fixyourdlp.com/forum/viewtopic.php?t=19
Mar 12, 2009 - 50 posts - ‎36 authors
Mine did the same thing after replacing the lamp. ..... TV won't turn on and Color Wheel is GOOD, Temp sensor is GOOD, Ballast is GOOD, and ... • NEW Bulb- still not working
Jan 14, 2010
• Resetting the Samsung DLP Lamp Counter/Hour Meter
Mar 20, 2009
• Samsung Dead Lamp, Black Screen, or Intermittent
Mar 12, 2009
More results from www.fixyourdlp.com
Samsung DLP: replaced lamp however tv won't turn on - HDTV ...
Dec 09, 2015 | Televison & Video
Epson Powerlite 830p lamp light comes on and turns off projector with new bulb.
Clean the fans and filters. Check the lamp door switch is making contact.
Jan 27, 2018 | Epson PowerLite 830p Multimedia Projector
Epson 76C projector that the picture has no red color to it. I have tried the adjustments as described in the manual but no success. The blue and green is great but no red? Thank you.
Youve probably got something gone wrong with your dlp chip with the million mirrors on it, see when the mirror tilts away from the light you get a black shade- tilted toward light lighter shade now throw the color wheel in which gives you color youve got green and blue so the color wheel is fine. Now how to replace chip? Dont. Look for a digital board or video board replace that and that should take care of ya. Good luck hope this helped ya-
Aug 22, 2009 | Epson PowerLite 76c Multimedia Projector
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
May 18, 2009 | Sony KV-36FV26 TV
EPSON POWERLITE BULB REPLACEMENT PROBLEMS
ok
look at your users manual.
all epson models need to have lamp life reset befor the lamp will light.
I have had this same problem befor.
Daniel.
Jan 11, 2009 | Televison & Video
Epson Livingstation LS47P1 won't turn on
Hey,
Very similar problem with my LS47P1. Here is the scoop (I work for a retailer which carried these and I bought one)
- Epson has admitted that there is a flaw in the engineering of many newer bulbs (that is ones that were made after the initial release of the LS47P1)
- Apparently the 3 little metal contacts on the lamp tend to get "squashed" down over time once the lamp has been installed (this takes a little while, like 2 weeks to a month after the replacement lamp is installed).
- The contacts no longer make a connection with the inside TV side contacts and the electrical charge needed to ignite the gases in the lamp does not get through (like 9 out of 10 times)
- You can get it to work temporarily by pulling out the lamp and carefully pulling the inside contacts upward to make a better connection inside. NOTE: I did this for a while everytime it didn't work and after a while the pieces of metal became worn and would break off. So do this only if you have an extra lamp handy or you're on your last witts (as I was).
HERE'S WHAT TO DO:
1. Call Epson of America (I am in Canada, but they are the ones to talk to anyway)
2. Tell the first person who answers the phone to transfer you to the Livingstation (rear projection) department. If they start telling you that it will take like 48 hours and they will call you back tell them "NO! put me throught now!"
3. Tell the real tech expert your issue.
4. Get him to send you out a non-defective lamp (these ones have been retrofitted to not get "squashed" in the TV.
5. Put new lamp in and cross your fingers....
Hope this helps.
Mark
Jan 25, 2008 | Epson Livingstation LS57P2 57" Rear...
No picture
My too, same problem - tried replacing lamp ($150), no luck, replaced ballast ($200) no luck, replaced power supply ($150) no luck and TSC is telling me to replace the main engine ($600) - way too much for this piece of junk (cost me $4000 in 2005) - don't buy optoma products!!!
Nov 11, 2007 | Optoma RD65 65" Rear Projection HDTV
No Picture
its probably the ballast that is bad, call Optoma and you can buy a ballast for it, but you will probably want to have a pro do it, changing the ballast is a lot more involved than just changing the bulb, the ballast is what powers the bulb and it does go out on occasion.
Oct 28, 2007 | Optoma RD65 65" Rear Projection HDTV
Epson Livingstation LS57P2 57" Rear Projection HDTV Logo
145 people viewed this question
Top Epson Televison & Video Experts
janman
Terry Dovre
Terry Dovre
Are you an Epson Televison and Video Expert? Answer questions, earn points and help others
