Question about Refrigerators
Frigidaire Side by Side model........freezer not working
We have a year old side by side refrigerator and the freezer part is not freezing.  It won't make ice and everything is slowly melting.  We turned the settings up and nothing improved.  The refrigerator side is fine.  Can someone please help!!!!
  • Anonymous Dec 30, 2008
    I have the GE GSS25LSMF and am also having intermittant cooling issues. One day the freezer works and the next day it doesn't. So I disconnected it. Does anyone know how to fix this problem?
  • Refrigerators Master
  • 5,568 Answers
There is most always an adjustment that diverts part of the cooled air into the refrigerator and a fan to ensure that the air circulates.
This adjustment is generally limited so that the freezer gets the lion's share of cooling.
It sounds as if the circulating fan has failed, or, (very unlikely) the path between the two is somehow blocked.
Posted on Jul 19, 2008
FRS26R4CB0-Freezer not freezing and Fridge not getting Cool
Hi Candi,
I don't know this model but most friges are the same,
Check on the bottom back, there should be a radiator with a small fan
If the fan is not working this maybe your problem,
It is not colling the gas.
You also may have a gas leak or the gas compressor is not working
or starting to work because of a faulty capcacitor.
Jan 11, 2014 | Frigidaire FRS26R4C Side by Side...
also check defrost timer,defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Jul 01, 2009 | Frigidaire FRS26R4A Side by Side...
Freezer won't freeze
is the fan running ion the freezer is the compersser runing and the cond fan >??
May 10, 2008 | Frigidaire FRS3R5EMB Side by Side...
compressor may be the problem,by pass the thermostate connections & chelk cooling replace if working.some sort of leakage may also be the problem.
Mar 16, 2008 | Frigidaire FRS3R5EMB Side by Side...
Ice in the bottom of frigidaire side by side frost proof freezer
take all the bottom shelves and baskets out of the freezer. look at the back wall of the freezer. youll see a block of ice in a metal pan looking part at the bottom of the rear panel. there is a hole in the bottom of that pan. thats the defrost drain. its clogged. use a hair dryer to get all the ice out then use hot water to flush out the drain hole.
Nov 28, 2007 | Frigidaire FRS3R5EMB Side by Side...
Food stays frozen regardless of temperature setting
It is possible it has a bad thermostat but most likely cause would be a bad damper motor.  It is the vent inside the fridge that opens and closes, based on temp. setting, to allow cold air from the freezer into the fridge section.
Oct 14, 2007 | Frigidaire FRS26H5AS Side by Side...
Refrigerators Logo
100 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
