Question about Magic Chef 9512 Electric Single Oven
How to light the pilot in my RV?
I have a 1989 Jamboree Searcher RV with a Magic Chef 3-burner gas stove/oven (sorry, don't know the model number) and I can't figure out how to light the pilot light! I know it sounds silly and I know it worked before we bought the RV, but there are no lighting instructions and no diagrams and I don't know, maybe it's just me, but I'd kinda like to have the oven NOT blow up in my face when I light it! Can you help? Thanks so much!
  • Anonymous Oct 07, 2008
    I have the same problem....dont want it to blow up in my face
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 46 Answers
Push in on the themostat when the oven is on piolt hold a lighter under the burner and presto also light the stove to get gas flowing first this can take up to fifteen min to light if it has been awile since lit
Posted on Aug 01, 2009
Magic Chef Chateau stove pilot goes out when two burners are used!
The pilot flame may not be set high enough to cope with the demand of two burners.
Dec 19, 2013 | Ovens
How do i light a old magic chef stove
If the stove is the one that I think that it is... you will have to lift the cover and then between the burners there will be a small orifice that you light... the pilot light will then light the burners when the gas is turned on to them...
heatman101
Jan 16, 2011 | Magic Chef 9122 Gas Single Oven
I have a magic chef gas stove witch has electric pilots.when i turn on oven it seems the electric pilot lights up but the burner doesn't come on.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems
Replacing the Igniter
heatman101
Jan 06, 2011 | Magic Chef Ovens
Gas smell oven does not light
you may need new coupler on pilot system
Jun 23, 2009 | Magic Chef 9122 Gas Single Oven
Stove top gas burners are making my pots black with sut
the flames seem to be to high
try adjusting the air shutters underneath the cook top
May 27, 2009 | Magic Chef 9122 Gas Single Oven
Propane not getting to oven... stove top works fine..
The pilot light must be lit and stay lit before you will have any propane coming into the oven. This is a safety feature.
May 17, 2009 | Magic Chef 9122 Gas Single Oven
Delay in oven burner to light after pilot is lit.
Usually delayed lighting on a standing pilot system is caused by a gas pathway that is dirty from spilled food or grease. If you can remove the burner assembly and clean it that will correct the problem. If there is a removable plate above it then you can remove that and get access instead of removing it. Pilot ignitions work by creating a column of gas between the pilot and the burner that is established when the burner is turned on kind of like a fuse. A small tube my be used to establish the column of gas between burner and pilot and it may get blocked with food that overflows. Sometimes the pilot is just located right next to the burner and may get partially blocked or the orifice in the burner next to the pilot may be blocked. Cleaning all this helps. Be very careful with gas. Work in a well ventilated area. Turn on gas very briefly to run an ignition test. Turn off the gas and vent it off if it fails to light in about 5 seconds. Unburned propane drops to the floor and collects. Natural gas rises. Be aware of this when you ventilate.
Dec 23, 2008 | Magic Chef Ovens
How to light Oven Pilot for Magic Chef stove 31000 PAW
There is a cover plate that has two screws holding it down. Inspect the pilot area and you will see a hot surface igniter sitting right next to it.. That is what lights pilot and then the pilot lights main burner. You need a new igniter. Also do not touch any part of the hot surface igniter as human oil will shorten the life of part.
Nov 25, 2008 | GE JGRP17 Gas Single Oven
Old Magic Chef Gas Oven won't light
sounding like thermostat isn't working. If you could ohm out the t-stat should be closed when you call for heat. If that passes the test then only thing it could be is the gas valve.
Nov 24, 2008 | Magic Chef Ovens
Magic Chef 9512 Electric Single Oven Logo
677 people viewed this question
Top Magic Chef Ovens Experts
Dan Webster
Dan Webster
Sal DeAngelo
Oloyede Monsuru
Are you a Magic Chef Oven Expert? Answer questions, earn points and help others
