Kenmore washer 4yrs old.Model #11024622300 Top loader
It fills up but then nothing happens,so I replaced the timer and now it fills up and advances but thats it.I left it on to see if anything would happen but then it started to smell like something was burning so I shut it off.It doesnt agitate,drainor spin.could it be a dead motor? Its only 4 years old! Any suggestions? Thanks for the help.
    Scholar:
  • 191 Answers
If your washer doesn't agitate, check these:
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it.
Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Transmission The transmission could have either of these problems:
  • Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may not agitate properly or at all.
  • The transmission may have a worn or broken gear, or some other internal problem.
If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it.
Agitator The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
Posted on Jul 19, 2008
Kenmore Diagram
What appliance is this? I suppose washer that wont start. Or does it fill and does nothing else?
Check power supply. Check Lid switch if this is a top loader machine (lid on top)
More info would be helpful.
Oct 18, 2013 | Dryers
My kenmore 800 washer is off cycle for example when i start a load of clothes it starts agitating before filling, and doesn't always spin all the water out of the clothes
I have the exact same problem with my Kenmore 800 top loader, Model # 110.29822800. It is only 1.5 years old. Any suggestions?
Jan 19, 2011 | Kenmore 22422 Top Load Washer
My frigidaire top loader fills with water at the beginning of the wash...then nothing. it just sits there full of water.
Hi, could be your timer motor, timer or water level switch, first push timer knob in and manually advance to wash or spin cycle (program) then pull knob, see if machine operates, let me know, then i can tell you exactly what's problem.also advance timer, to spin cycle (program) machine should pump out water, or you can lower drain hose into bucket and empty machine, you should empty machine and try again, let me know what happened, we can solved this together. good luck.
Aug 12, 2009 | Frigidaire FWS933F Top Load Washer
Kenmore washer will not drain
I would check the lid switch first using a pen open the lid set into spin and depress down on the lid sw if you dont hear it click then it is bad
Aug 17, 2008 | Kenmore 24032\24036 Top Load Washer
My kenmore washer fills up but then just stops
it could be several things, something is lodged in pump, so the motor wont run, the motor is bad, or you have a bad transmission.
Start with the pump and see if it has sock or something stuck in it.
Jul 12, 2008 | Kenmore 24032\24036 Top Load Washer
Washer does nothing but FILL!!
suspect timer contacts bad but ck wire harness to motor just to be sure also if i remember correctly those may also have off balance switch that would cause problems but not sure if water would run in if they are bad ..sorry oldfixer memory ain't what it use to be
May 01, 2008 | Washing Machines
Kenmore 22956 top loader quit running after agite cycle
If the timer cycles your lid switch is ok.
most likely: motor Switch (on Motor), condenser next to motor, motor itself, or wiring going from the time to the switch,
It is probably cost efficient to replace the unit rather than trowing parts at it .
AB
Apr 06, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
575 people viewed this question
Top Washing Machines Experts
