Question about Zanussi WJS1265W Front Load Washer/Dryer
OUR WASHER DRYER WONT WORK.
IT IS ONLY ABOUT A YEAR OLD BUT WE SWITCHED IT ON TODAY & ERROR COMES UP ON THE PANAL & WE CANT CHANGE THE WASH TYPE FROM COTTON OR THE TEMP FROM 40 OR THE SPIN SPEED & IF WE TRY TO USE IT WE GET THE ERROR MESAGE? CAN YOU HELP PLEASE.
Hi got it fixed it was the door catch mec.
Posted on Oct 22, 2008
  • 3 Answers
First try power off reset,.. unplug and re try
Changed door switch on my kenmore h2 plus cause of error code and it still wont work
Whirlpool & Kenmore Dryer Repair #01 - Won't Start or Run ...
? 8:50
https://www.youtube.com/watch?v=2WF71WdGn_g
Oct 19, 2011 - Uploaded by canyonman1963
This one deals with testing and replacing the door switch. ...sears wont work wont spin wont wash wont heat wont start fix repair bad noise noisy ... how to change a 4 to a 3 prong cord, to figuring out my door switch problem.
Dryer Door Switch - How To Replace - YouTube
What to do when your washer won't fill, start or run - YouTube
? 2:00
https://www.youtube.com/watch?v=Atd5YHbRh7M
Jun 20, 2012 - Uploaded by searspartsdirect
So if my washer wont start just call Sears. .... Bad sears mykenmore is only 2 years old, fill take 30 mins,,,wash 50 mins rinse never spin never,, ...
Nov 28, 2015 | Kenmore Washing Machines
During spin cycle the washer allows water to enter the machine. If I shut the water during this cycle it spins out fine but when the cycle reaches the off position it doesn't really shut off. Sounds like...
open the door on the washer,in the middle rear just above the tub you will see the shute were the water comes in to the washer,make sure it is connected to the back panal,if is not than you will nead to remove the washer top door and cover assemble,there is a panal between the dryer and the washer,at the top of the panal on each side you will see a screw,remove them and remove the panal,at the back of the cover on each side you will see a clip with a 5/16 screw in it,remove the screws and slide the cover forward about 1 ",next lift the frount of the cover and on the right side you will see the door switch conneter,unhook the conneter and remove the cover,next you can see the water inlet shute,if is broken than replace it and hook it up to the back panal,next replace cover and panal and run a test run.
Jan 04, 2010 | Whirlpool LTE5243D Top Load Stacked...
Hotpoint wdd960 washer dryer error f05
f05 means blockage and cannot drain-switch off at mains to reset error-turn to drain if pump runs but dont drain filter in sump blocked/if no pump action then somthing is jammed inn pump
Nov 08, 2009 | Washing Machines
Washer wont drain....
try the lid switch with a screwdriver in the slot to see if it activates. Mine did the same thing, would agitate but not empty nor spin and it was the lid switch assembly--a 35.00 part that cost 150.00 to repair with a repairman!
Jul 11, 2009 | GE WSM2420T Top Load Stacked Washer /...
General electric washer won't start
no what happens is the control shakes and the solder in the board gets lose only fix is a new board sorry
Dec 13, 2008 | General Electric WCVH6400J Front Load...
Whirlpool washer-dryer has stopped washing
Remove the pump system like this off the Hotpoint wd640 . Remove any blockage inside and retry.
Nov 10, 2008 | Washing Machines
For weeks now I've had to slam the lid on my washer to get it to work. Now nothing! The same thing happened to my dryer...close the lid and nothing. It wasn't even a year old and someone had to come out...
ck lid screws especially on newer models on these the lid switch is located left rear corner just behind lid hinge if switch is on right side close lid slowly and listen for click if none heard try pressing down on lid at switch location if washer starts replace switch if switch lever broke change switch..on other type switch lower lid slowly and listen for click if none heard and hinge screws ok raise lid and push lid hinge toward back slightly and try again still no click raise console switch is on left and just snaps in place
Sep 04, 2008 | Whirlpool Washing Machines
Frigidaire Front Load Washer
It looks like the door switch was not making because the door is defective. Also the switch may just be bad.
Mar 08, 2008 | Frigidaire ATF6000ES Front Load Washer
Error E90
That happened to mine, and apparently it is the connection to the control panal at the front of the machine or the desplay unit (4 blue wires). Take the top off and wiggle them around or re-connect if any are loose. Mine worked for one wash and then started displaying E10........so i'm not amused and I think i may end up getting a hotpoint!
Nov 09, 2006 | Zanussi WJS1265W Front Load Washer/Dryer
Zanussi WJS1265W Front Load Washer/Dryer Logo
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
