Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Frigidaire Water Dispenser Lever
Kathy, we broke our lever too and I plan to replace it but I am having problems locating the parts. Where did you get your lever?
  • jumijumajam Oct 08, 2008
    I broke the lever off at my sister's house and now I need to replace. Is there any way you can help me?
5304433613 is the part number. It now only comes in black. My daughter's unit was clear plastic, so that is why I am stating the available color..
Posted on Oct 10, 2008
The water from the dispenser is running and i can't stop it how do you turn of???
The cause of the problem you describe could be ether water inlet valve or the water lever dispenser switch.Locate the water valve at the back of the refrigerator, open the water and take off both plugs from the valve. If the water flow want stop replace the water valve. If it will, replace the water lever switch.
Mar 24, 2013 | GE GSL25JFPBS Side by Side Refrigerator
Water dispenser lever is broken
1st, unplug or turn breaker off for refrig. 2nd, remove the slide out drip tray, 3rd, remove the 3 bottom screws at the bottom of the dispenser bezel (behind the drip tray). 4th, remove the bezel (slide up about 1/4" and pull forward, gently), WHEN DOING THIS BE VERY CAREFUL YOU DON'T ACCIDENTLY UNPLUG THE CONTROL BOARD FROM THE MAIN BOARD. 5th, remove the 3 screws holding the dispenser mechanism in place. 6th, remove the water dispensing hose from the dispensing mechanism., 7th, carefully unplug the power supply to the main board. hold down the clip to do this. 8th, with the dispenser out, remove the water dispenser lever plug from the coil board, 9th, remove the 2 screws for the metal hold downs for the lever pivot.
chances are, you will have difficulty removing the water hose from the dispenser unit. I did. I also had a harder time trying to get it back in. The factory hose is pretty rigid and I figured there mus be a better way. I had some 1/4" clear hose from home depot. I got a piece of 1/4' tubing and made a splice from the factory tubing to the clear, flexible tubing. The flexible tubing allows you to have additional tubing to play with and makes the job much, much easier. good luck
Apr 07, 2010 | Frigidaire Professional Side By Side...
My water dispenser lever broke, how can i replace it
order a new one, it is fairly self evident when the part arrives how to put it in
Nov 01, 2009 | Frigidaire FRS3R5EMB Side by Side...
Kenmore side by side refrigerator
If you are asking about the dispenser lever, There is a good chance it is already broke. You will need to remove the front cover. On most models, you will need a standard flat blade screwdriver and then locate the indentations on the underside of the cover trim. It takes a little force to pop the cover trim away from the door, but it will come loose. Once you have removed the cover, the dispesnser levers should be visible.
I hope this will help you to at least determine weather you can just tighten it or need to replace the lever. Please let me know if I have helped you. I can also look up the correct part and get it shipped to you.
Hope I helped
May 08, 2009 | Kenmore 57029 Side by Side Refrigerator
Water dispenser lever on door broken off.
Yes, the levers are easily ordered and replaced.
get manual, obtain part number, order part, replace part. use these websites for help
Oct 15, 2008 | Frigidaire FRS26R4A Side by Side...
any appliace part store can just have right model off serial#plate in top of frigde compartment
Dec 31, 2007 | Frigidaire FRS3R5EMB Side by Side...
Water dispenser lever on Frigidaire
My Frigidaire side by side is a little different from tech17's solution. It has no slots for a screwdriver to pry it off. It is a model FLSC23F6D55 manufactured 3/05. There is a semicircular spill tray in the bottom of the recessed water station. Just pry out the tray, from the bottom corner of the frame from the side and or bottom. (I did this with a knife blade.) This tray is a snap-in fit. Then you will see three phillips head screws in the bottom of the frame. Take out these three screws and remove the frame by lifting up on it and pulling out at the bottom. Then take out three more phillips mounting screws to remove the processor card and key pad. You will then see the top of the water lever mounting. The lever comes out by removing two more screws that hold the pivot shaft of the lever. (These last screws are a little more diffiucult to get to, but not anywhere near impossible.) I wish you well.
Nov 18, 2007 | Frigidaire FRS3R5EMB Side by Side...
Softner dispenser
The detergent dispenser is located above the detergent drawer. A water pipe is connected to it and water entrance and distributed to drawer's cells (following the programmed cycle) by a lever's movement (part of the dispenser). The lever movement is controlled by two solenoids that received their power from the timer. By opening upper machine's cover you will have an access to the dispenser. Disconnect the power cable from the machine before moving to next test !!!! Look first that they are not any disconnected wires. Move manually dispenser's lever and see if water running to all cells (depend on your movement). In case it doesn't work properly remove the unit from the machine and try to clean it (I hope it will help, otherwise you should replace the unit). In case it works properly (manually) - you should test by a multi-tester solenoid's resistance. the one that doesn't have a resistance measurement should be replaced. Good luck !!
Jul 02, 2006 | Frigidaire GSTR1670A Front Load Washer
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
789 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
