Question about Brother HL 5140 Laser Printer
Won't print from usb or parrallel cable
I have two Brother HL-5140 printers that have the same problem. They won't print anything from the computer via the usb or parrallel cable. They will print a test page using the control panel on the printer, but not through the controls on the brothers control program on the computer. Neither printer has any yellow or red lights. Both printers were used about twice a week for two years when they quit working. The computer recognizes the printers when attached through a usb cable, but nothing prints. Another Brother HL-5140 attached to the computer works fine.
  • AIVARS PITANS May 11, 2010
    Hi there
    have you tried an internal test print.
    Switch printer on and await steady state.
    Then tap the big start key 3 times in rapid succession.
    This should cause the printer to print out a configuration sheet. If it prints the there is no internal fault except for possibly the main board, If it prints OK check the internal seetings against the printer driver settings.
    Let me know.
    Cheers
    ivorpits
  • 5 Answers
Try a different brother driver or an HP 4000 driver / pcl 5 or 6. You should get a printout.
Posted on Aug 12, 2009
    Scholar:
  • 169 Answers
Well what yu need to do is if the printeris printing a test page then the hardware is fine,its a concern with the drivers on the computer,just get it uninsatlled from the control panel>printers.Then restart the computer and try a plug and play.It should work
If you want any further support a technician can help you online for free.You can find free online technical support at http://tinyurl.com/m7ghqz
Posted on Jun 20, 2009
  • 30 Answers
Check the usb sucket on the printer board and see if the legs are firm if ok check the board
Posted on May 18, 2009
Need to get a total page count or report off of my Brother HL-5140
hold down the "blue GO" button on the printer intill it prints the report.
Have a nice day!
Aug 23, 2011 | Brother HL 5140 Laser Printer
How do you get a page count from an HL 5140/
On the HL-5140, you can print out a config page which will show the page count on it by pressing down the Go button (the blue button). Hold it for a few seconds, until the config page starts to print out.
To find configuration page instructions and page count tips for other printers, copiers, and fax machines, check out How to Print Configuration Pages.
Aug 22, 2011 | Brother HL 5140 Laser Printer
Can I print w/just the USB cable?
No, the USB cable is sufficient. Besides, you may not have a parallel port on the printer. You should install the drivers compatible with your Operating System.
Usually you receive a CD-ROM containing the software you need to install. When you run the application it will normally install the relevant drivers.
If you have lost the CD-ROM just go to Brother Solutions Center (Google it). On the Map click/Select your region and enter the regional site. From the instructions. Download the software and install it on the computer before connecting the printer to the computer.
If you have several printers installed on the computer, You must select the one physically attached to the computer as the Default printer. If not, you will have to select the printer each time you print something.
Jul 27, 2010 | Brother HL 5140 Laser Printer
I cannot get my brother HL-5140 laser printer to print anything!!!!!! I have tried all troubleshooting suggestions.light on status is red
There is some paper jam inside the printer .Please remove the cartridge and look inside the printer for paper jam. If paper jam is there , remove the paper . I hope it will help to solve the printer problem.
Jan 25, 2010 | Brother HL 5140 Laser Printer
Our Brother HL-5140 is not printing. It doesn't
Replace the paper pcik-up rolly assembly. MAKE SURE TO get a good look at how the existing one is installed before removing it. It needs a little tweeking to get the new one in and everything lined up correctly.
Also replace the separation page on the paper tray itself.
Look for part number PF-1 Kit or OEM PART #: LJ7920001
The only diagrams I could find on-line of the inside of the printer I found by searching for "brother pl-prn067". Look at pages 8-9.
Dec 09, 2009 | Brother HL 5140 Laser Printer
"Drum" light is on.
THAT MEANS YOUR DRAM LIFE IS END. YOU NEED TO CHANGE YOUR DRAM.
Jan 29, 2009 | Brother HL 5250DN Laser Printer
Will not Print online Coupos
Just fixed my Brother HL-5140. Hope this helps :) I have struggled for years and finally figured this out from the Brother website.
If you are unable to print coupons from the Internet the print processor
setting in the driver needs to be changed. To change the setting,
1. Open Printers and Faxes.
2. Right mouse click on the Brother printer and left click Properties.
3. Click on the Advanced tab.
4. Click the Print Processor button.
5. Under Print Processor, select WinPrint.
6. Under Default Datatype, make sure RAW is selected. Click OK.
7. Back on the Advanced tab remove the check next to Keep Printed
Documents.
8. Click Apply and OK.
Try printing the coupons again.
Aug 20, 2008 | Brother HL 5140 Laser Printer
Brother HL 5140 Laser Printer Logo
173 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
