Question about Hitachi 53SBX01B 53" Rear Projection Television
Hitatchi 53sbx10b the picture pulls in from the top and Bottom. and the colors are not lined up. Done a little research and found this could be a convergance problem? and some IC's could be burned out. Is this a part that can be replaced myself?
  • Hitachi Master
  • 3,459 Answers
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Solution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Posted on Mar 15, 2009
    Sergeant:
  • 217 Answers
Yes its the convergence problems and this can be replaced.you will get the required patrs at  www.radioshack.com and check out this link mentioned to do it manually for alignment problem in tv projector http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Posted on Nov 29, 2008
LG Projection TV Model# RT-49NA11T Green color gun shows bent arc on top & bottom.Red & blue guns are ok.How to adjust the green gun to remove the bent arc. This is causing picture shows mix...
This problems ur tv have can't not be fix by adjustment.The tv have a problems known as convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to repair the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 10, 2011 | Panasonic PT-53WX53 53" Rear Projection...
Thin green line is it the cable box
thanx smart home just had the green line prob your fix worked like a charm. any tips on a crisper pic ive always found that unless the source is 1080p perfect the picture is a little blurry. its almost like there is no image processing. man i mis my hitatchi.
Aug 12, 2010 | Sony BRAVIA KDL-46W3000 Television
Sony Bravia with really bad ghosting
The little board on top attached to panel.
Jul 05, 2010 | Sony Bravia KDL-32ML130 32 in. LCD TV
Hitachi 53SBX10B-color and horizontal lines issues
with the original Hitachi remote go into the customer menu and select convergence---you should get a cross in the middle of the screen--look to see which color will not move either up and down or left and right---sounds like bad convergence IC and this is not uncommon in most rear projection sets---if this is the problem the set uses two convergence output IC chips that both should be replaced and then the set adjusted in the Technical menu----the convergence mode can be engaged by removing the front grill and an inspection plate behind it and pushing a small micro switch located on the front of the board; when the switch is engaged with the set turned on a grid of lines will appear on the screen and then the set is adjusted with the remote---hope this was helpful---if you need direct assistance you can contact me : etower.766@netzero.net
Aug 11, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Colors have separated. and top and bottom af pictures are bowed. i have a sony kp-46s55. its about nini years old and it was free. currently the colors are separated and the top and bottom of the pict
nbad convergence ic , this need to be done by a profecional tv tech , because need to check for the pico fuse and resistor around the area
May 08, 2009 | Televison & Video
Lost picture all color lines are at top of screen
Thats what happened your convergence went out, those parts can be found online for as little as 12.50 a piece. If you are good with solder its an easy fix. I found a guy on craigslist in denver who fixed it for 150
good luck
Feb 11, 2009 | Samsung PCN5425R 54" Rear Projection...
Tv set picture is gone
It depends, the center line you speak of, does it go from side to side? Or top to bottom? Side to side you have problems in the vertical circuit. Top to bottom you have a problem in the horizontal circuit. Not picture tube problem. If it is an analog tv and depending on how old it is. What an estimate and the actual repair would be you are better off buying a new one.
Jan 27, 2009 | Televison & Video
53sbx10b
You will need to replace both convergence Ics and the six convergence resistors. Please respond to this same post and verify the model number of your set and I will post the correct ICs and resistors for your model, as well as where to get replacements with free instructions
Jul 19, 2008 | Hitachi Televison & Video
Samsung hl-r4266w bottom black line
Your DMD board is now misaligned. It can happen when you changed the color wheel. All you have to do is pull up on your DMD board. I would use both hands, one on each corner of the DMD board and just a little at a time until you get it the way you want it. If you have a space at the top, then just push the DMD board down the same way.
Mar 21, 2008 | Samsung HL-R4266W 42" HDTV-Ready...
Convergence problem.
This sounds like one of your convergence IC's has burned out or its solder joints have cracked loose. Sometimes when this happens it burns up one or more of the 3 low-value resistors next to it. This should be repaired and realigned by someone with experience.
Jun 26, 2007 | Hitachi 53SBX01B 53" Rear Projection...
Hitachi 53SBX01B 53" Rear Projection Television Logo
300 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
