Question about Emerson Smartset Clock Radio
Smart set radio cks 1851. It will not keep the time and now blacks out. New battery installed. Folled plan of reset. lasted approx 10 minutes and blacked back out. Was plugged into electric at the time. Approx. 5 months old. Birthday present 3/21. Joyce
    President:
  • 814 Answers
Sorry it took so long to get back to you with a solution to your problem. You must try to reset the microprocessor in the Clock/Radio. To do this you must unplug the Clock/Radio from the A/C power source.Then remove the Internal battery(CR2430). Let the Clock/Radio set without a power source for about 3 hours. This will discharge the microprocessor and reset it. After you have discharged the microprocessor,you can reinstall the internal battery. Connect the Clock/Radio to the A/C power source. The Clock/Radio's Functions should have returned to normal function. If the Clock/Radio did not return to normal function, you must replace the internal battery and again let the microprocessor discharge. After the microprocessor has discharged,put in the new internal battery and reconnect the Clock/Radio to the A/C power source. The Clock/Radio should have returned to normal function. If you are still having problem with the functions of the Clock/Radio, You will have to call Emerson Customer Support. The telephone number for the Emerson customer support is 1-800-909-1240. you can call them between the hours of 8am-4:30pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance. I hope this information help you with your problems with the Clock/Radio. Thank you for using FixYa and have a nice day!
Posted on Jun 14, 2009
We had a power failure after a few power surges and now I cannot set the clock. The display keeps blinking rapidly. How can I set the clock?
Jensen Smart Talk JCR 290 User Manual Page 10
USING MANUAL SETTINGS
In radio off mode, press SET BUTTON (#5) to enter AL1/AL2/Time
setup mode.
1. The HOUR DIGITS and AL1 indicator in the LCD panel will flash.
2. Using the > (UP) (#6) or < (DOWN) (#4) BUTTONS, adjust to the
desired hour for AL1.
3. Press SET BUTTON (#5). The MINUTE DIGITS and AL1 indicator
in the LCD panel will flash (#25).
4. Using the > (UP) (#6) or < (DOWN) (#4) BUTTONS, adjust to the
desired minute for AL1.
5. Press SET BUTTON (#5). The SOUND EFFECT INDICATORS of
AL1 will flash (#25).
6. Use the > (UP) (#6) or < (DOWN) (#4) BUTTONS to choose a
Wakeup Alarm Sound - Ocean, Rain, Brook, Radio or Beep Alarm.
Jensen Smart Talk JCR 290 User Manual Page 9
Mar 02, 2016 | Jensen Interactive AM/FM Talking Dual...
2003 sierra gauges not working plus dash plus drains my battery any suggestions ?
Try this simple trick. Shut off every thing in your vehicle, radio, ac, lights, windshield wipers etc.Turn off the vehicle put it in park. Disconnect your battery , wait 5 minutes. Then Without turning any thing on leaving the vehicle in park reconnect the battery start the vehicle and let it Idle for approx 10 minutes. This allows your computer to reset all of your gauges. By assuring that everything is off your computer can concentrate on resetting everything correctly without missing a step . This will set your Idle and all of your Gauges. Whenever your battery is disconnected for what ever reason this step should be followed immediately upon reconnect.
Nov 16, 2012 | 2000 GMC Sierra
1995 chev locked after removing battery. radio is also a cassette
This is the anti-theft for your radio, normally this is something the dealer needs to enter a code to clear this for you (however they will charge you approx $45).
Here is something you can try...
Press & hold the 2 & 3 buttons @ the same time for about 10 seconds; a 2 or 3 digit code will appear, write this # down,press & hold the am/fm button for about 10 seconds: another code will appear, write this # down, then call 1-800-537-5140 and enter 202108 followed by the # key, then enter the #'s that you wrote down from your radio followed by the * key. The call will give you a 3 or 4 digit override code. Write this code # down so you have it if you ever need it again. Enter this # into your radio following the instructions in your owners manual. If you get an override code that starts with 0, you drop the 0 when entering the code into your radio.
If you don't have an owners manual, try this, press & hold the hour button until the first 2 digits of your code come up, then press & hold the minute button until the last 2 digits show. Then press the am/fm button. This should reset your stereo. It did mine.
Hope you find this helpful.
Jun 20, 2011 | Car Audio & Video
Grundig s350, installed new batteries and radio keeps shutting off by itself
When you press the Power/Sleep button the radio turns on and displays a number 90, or some other numbers. This is the play time that the radio will stay on then turns itself off. It could be that yours is configured with a sleep timer set to 01 minute, 10 or 15. You need to set the timer for a longer period. Thus we turn it on by pressing the Power/Sleep button, read the timer length then press again. Keep making short presses: The timer will cycle through all preset sleep timer durations. Select the length you want.
Jun 19, 2011 | Grundig S350 AM/FM/SW Radio
Sangean h2o1 clock is flashing. The radio display doesn't flash - only the clock. I've reset the clock, changed the batteries, and generally played with the other settings. Can't figure out why the time...
Here's the thing: When you change the batteries, the radio thinks you need to reset the time, even though the time has been preserved and is correct even after you change the batteries. Here's what you do: Pretend you need to reset the time. With the radio off (recommended), press and hold the "Band" button with the "set" notation underneath it. The hour will flash. "Reset" the hour by using the tuning buttons, as you would if the radio were new, and then change it back to the correct hour. Press the "Band" button again and repeat the process for the flashing minute display. Press "Band" again to end the process. You will have successfully fooled the H201 into thinking that you have reset the time, and the time display will have stopped flashing. (This does not appear to work if you do not actually pretend to change the hour and minute and just keep pressing the "Band" button -- you have to go through the procedure as though you were actually changing the time.)
Aug 31, 2010 | Sangean H201 AM/FM Radio
How to reset brake light after changing pads.
Hi Peters6709,
Sorry to tell you, but you need to replace the pad-wear sensors as well. They are the little trapezoid pieces that hang inside the tops of the inside pads. They should run about $10 each. Once replaced, disconnect the battery completely for about 10 minutes, if you have a stock radio keep the code handy.
Next time check the pads every 10-12K miles. I have been running the SAME pad wear sensors on my Z3 for the past 2 pad changes now after making the same mistake the first time.
Best of luck!
May 02, 2010 | 1999 BMW 323 Series
Radio controlled clock not working
Pretty simple: Press reset. Clock should reset within 10 minutes.
Manually set by pressing Set and holding for 5 seconds. The hands will turn. Release when they get to the correct time.
Mine quit working after a year and seems to be dead. The movement won't do anything now with a new battery.
May 10, 2009 | Audio Players & Recorders
Emerson clock radio cks 3516 military time
You will need to try some combination of the set button and time button to change the time back to normal time. Try hold both the time and set button for a period of 5-10 seconds and see if this will cycle the time to normal. If not try hold the set button alone for 5-10 seconds and see if this works. If not try holding the time time button for 5-10 seconds and see if that works. If none of the fixes work. Call Emerson customer support at this telephone number 1-800-898-9020 between the hours of 9am-5pm CT. Tell them the make and model number of your Clock/Radio and ask them for assistance with your problem of resetting the time back to normal from military time. They will be able to help you. I hope this information helps you solve your problem.
Feb 01, 2009 | Emerson Smartset Clock Radio
Emerson Model No. CKS 3020
Sorry it took so long to reply to your problem.You must try to reset the Clock/Radio's microprocessor. To do this you must disconnect the Clock/Radio from the A/C power source and remove the internal battery. Let the Clock/Radio set without any power source for about 3 hours. This should completely drain all the power from the microprocessor. After this is done, reinsert the internal battery and plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal. If they do not return to normal. Unplug the Clock/Radio from the A/C power source and remove the internal battery. Replace the internal Battery (CR2430). Let the Clock/Radio again drain all the power from the microprocessor. Insert the new battery and Plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal.If you should still be having problem with the functions of the Clock/Radio, you will need to call Emerson Customer Support. The telephone number for Emerson Customer Support is 1-800-909-1240. Call them between the hours of 8am-4:30pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance with your problem. I hope this information help you with your problem. Thank you for using FixYa and have a nice day!
Oct 24, 2008 | Emerson Smartset Clock Radio
Wrong date on the radio.
RESETTING THE CLOCK AFTER A TOTAL MEMORY LOSS
If you do not change the built in lithium battery within a reasonable period of time after you see the ‘flashing’ LOW BATT. warning indicator, the lithium battery may become exhausted and will no longer be able to supply back up power to the SmartSet internal computer.
If the unit is disconnected from the AC outlet after the battery is exhausted, or if a power interruption occurs, the SmartSet memory will be lost and the clock will need to be reset when the power is restored. Be sure to install a fresh lithium battery before you reset the clock, otherwise the clock will need to be reset each time the power is interrupted.
If the lithium battery is exhausted and you experience an interruption in the AC power supply, the clock will reset itself to its initial default setting when the power is restored.
The initial default setting is “12:00 AM, Saturday, January 1
(1 1), 2005”.
If you notice that the time on your SmartSet clock radio is completely incorrect, and the day indicator is also wrong, press the MONTH/DATE button to see the date. If the date display is showing “1 1” (January 1 ), you probably experienced
a total memory loss. To reset the clock after a total memory loss, proceed as follows:
1.) Install a new CR2430 lithium battery in the battery compartment.
2.) Connect the radio to your AC outlet and let the clock set itself.
3.) Depress the MONTH/DATE and TIME buttons together. The display will change from ‘time’ to ‘year’. While holding the MONTH/DATE and TIME buttons, press the UP button to
set the display to the correct year, then release the buttons.
4.) Depress the MONTH/DATE button. The display will change from ‘time’ to 'month/date’ (mm/dd). While holding the MONTH/DATE button, press the UP button to set the display
to the correct month and date. The Day indicator will change automatically as you adjust the month/date settings. When the correct month and date appear on the display, release the buttons.
5.) Depress the TIME button and the UP button to set the display to the correct time. Be sure to confirm that you have set the time correctly to ‘AM’ or ‘PM’ by observing the AM indicator.
6.) After you set the time, reconfirm that the Day, and Month/Date displays are still correct. Make final adjustments if necessary.
The SmartSet clock memory is now reset and the new lithium battery will maintain it for the next 5 to 8 years, depending on the number and duration of the power outages you experience.
IMPORTANT NOTE:
After resetting the clock, don’t forget to reset your wake up times, and alarm mode settings, and sleep timer settings as well.
Oct 22, 2007 | Emerson SmartSet CKS1850 Clock Radio
Emerson Smartset Clock Radio Logo
132 people viewed this question
Top Emerson Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
