Question about Maytag Atlantis MAV6000 Top Load Washer
Off balance spin cylce
My washing machine starts to wobble excessively during the spin cycle. Almost like if you had a very heavy unbalanced load. However, even with small loads it still gets out of control. It just started doing this. At first I thought the springs at the bottom of the tub must have broken free but I see nothing obviously wrong. I read that this symptom is often associated with the pump but really have no way to confirm since it seems to be pumping water out...maybe just not pumping fast enough?
Thanks!
  • bacardid Jul 19, 2008
    When I first moved the washer yesterday, there was a bit of grease, not oil on the floor...no more since.
    I didn't see any sign of splatter on the inside of the cabinet and nothing in the white cap.
    Am I back to the pump? Seems like from what I've read I have a 50/50 shot between the pump and transmission.
    Thanks for your time.
  • Anonymous Mar 17, 2014
    Maytag Neptune washer. When large loads or heavy cotton loads are washed. On the spin cycle, the spinner starts knocking like unbalanced load then cuts out. By pressing start button it restarts but continues to cut out until enough water is expelled to maintain a balance. Does not seem to affect light loads.
My Maytag top loader would wobble very bad even when clothes were balanced. It turned out to be a spring for the tub had broken.
Posted on Feb 15, 2012
  • 413 Answers
The base of the tub assembly rests on a white plastic ring called a 'snubber'. If any type of lubricant gets in this area, the tub will wobble excessively. The major cause for this issue is a failed transmission where oil has leaked out and into the snubber. The transmission may be warranted for 10 years. Check your owners manual. A good method to check for oil is to tilt the machine back and remove the plastic cover in the center of the pulley, if it contains oil, the transmission is leaking also look at the inside cabinet wall for signs of oil splatter.
If you need further assistance, let me know
Regards,
reg501
Posted on Jul 19, 2008
Spin cycle is going on balance
Betty, if you suggesting the machine is out of balance/ causing the machine to jump around in spin cycle
1. it may be due to a heavy wet load ,like towels unbalancing the machine, try less load or slower spin ,then fast spin
2. could be concrete balancing block inside machine has come loose, both problems causing a unbalancing affect on the spin cycle.
Nov 11, 2016 | Washing Machines
Why does it always become unbalanced in spin cycle?
how confident are you to get inside it? Check the balance springs and shock absorbers.
Normally it is two simple things.
First the machine must be level front to back and left to right. Also all 4 feet must be in equal contact with the floor.
Make sure you load the washer evenly with clothes. Mix large and small items so when the spin starts the clothes even out. Never wash just one large item that is very absorbent, like one bathrobe or one blanket..
Dec 26, 2015 | Washing Machines
When it goes into the spin cycle, the inside "basket" seems off kilter and wobbles noisily
This may be due to an unbalanced wash load. When you load your washer, try to distribute your laundry evenly in the basket. Try to balance heavy stuff opposite each other.
Hope this helps.
Mar 05, 2015 | Washing Machines
Kenmore Elite Oasis HT makes loud noises during spin cycle.
The tub may be unbalanced and wobbling. This may be due to washing heavy items such as rugs, towels, etc. If it is noisy with regular laundry loads, the mechanism that supports the tub may be loose or broken.
Sep 10, 2012 | Kenmore Oasis Agitator 4.5 cu. ft....
Washer spins than it gets off balance and shuts
Hi, Washing machines can become unbalanced when the wash load has too much weight in one area of the basket. A machine in good working order can handle most problems through its balancing mechanisms. However, when washing heavy single items such as comforters, the machine's tub can become so lopsided that it damages the washer.
Washing machines that get unbalanced can shake, make banging noises, and even more across the floor. When machines are secured in one place, they can vibrate and bang so much the entire house shakes and things fall off shelves. This is not good for the washer. Bolts can come loose, and parts can break.
When washing heavy items such as pillows or down coats, stay near the washer so you can correct any balance problems as they occur. Some washers have an automatic shut-off feature when they become too far off-balance. If yours does not, stop the spin cycle, open the lid, and redistribute the load. If this is a continuing problem, you may want to wash heavy items at a coin-operated laundry in a heavy-duty machine.
Take care
Jul 14, 2010 | Whirlpool Washing Machines
Makes a loud banging noise as if the load is underbalanced even through the load is balanced.
HI There
Try this even tho you said it's balanced. Sometimes it looks like but a slight unbalanced can cause this problem.
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Let me know how this goes and thank you for writing to fix ya.
Best Regards Richard
Jan 07, 2010 | Kenmore Washing Machines
Excessive noise during the spin cycle. we have owned the washer for 16 months. problem started 1 wk. the machine is level.
Jan 03, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
It won't spin or do anything, it will only fill, last night it started banging during the spin cycle now it doesn't make any noise at all
I would need a little more infor. - but when your machine bangs on the spin cycle, it usually means your load is unbalanced. So lift open your machine and balance out your clothes. This should clear this up. You see this problem more with heavier loads (eg. towels, jeans, heavy garments, etc.). I try and balance out my laundry as I put it in the machine. It helps a bit, but even so, I still at times have to go balance it out manually. I hope this helps, but if not - then there's some other question's I would ask, but that's where I mentioned needing more info. at the beginning. Good Luck!
Dec 28, 2009 | Kenmore 22622 Top Load Washer
Excessive wobble
If there's a loud thumping noise during the spin cycle, the load of clothes has probably gotten unbalanced. Open the lid, redistribute the clothes in the washer, then re-start it. Repeat these steps if necessary.
Sep 06, 2008 | Maytag Neptune Washer
WASHER STARTS MAKING LOUD NOISES WHEN SPINNING SOUNDS LIKE IT IS OFF BALANCE BUT NOT. ALSO FAINT SMELL OF BURNT RUBBER.
The washing machine will do this if the load is unbalanced. Usually due to either an excessively heavy and/or large load. The burning rubber smell is just the drive belt dealing with the imbalance. Often the washing machine will self-balance itself, but it's a good idea to open the lid and re-distribute the load. Or remove some stuff if it seems too heavy.
Sep 06, 2008 | Maytag Washing Machines
Maytag Atlantis MAV6000 Top Load Washer Logo
349 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
