Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
HS500, white/light at top of screen
Hi. Need help/assistance please. For inputs 1, 2, 3, & 4, I am having issues with my satellite TV signal. When watching satellite, and the program has lots of white background, like on many commercials, the picture starts jumping a lot. When the background does not have a lot of white, the top of the screen, about 3 or 4 inches, looks considerably lighter than the rest of the picture.
When I have the satellite receiver off (no signal at all), I think the screen should be 100% black. But there is a thin horizontal line of "white" (about 2 inches tall), that moves from top to bottom. Almost like there needs to be an adjustment with vertical hold.
With input 5, where I have my DVD hooked up with component video cables, absolutely 100% no issues at all.
Any ideas what is wrong?
Maciso,
Thanks for your input. Far as I know, input 5 is component, but not HD. I think only input 7 is HD (looks like a computer monitor input). I don't think my satellite receiver has component outs. I'll double check, though. If it does have component outs, I'll have to rely on my A/V receiver to switch video inputs, since my DVD will have no place to input direct to the TV (I think there is only one component input on the HS500). Thank you again. Will post any results I come up with.
Posted on Aug 06, 2008
  • 125 Answers
I believe input 5 is hd input wich is different from the others
you may want to try hooking the sat to any component input to find out if there is any difference
My digital tv is saying no singal whats the problem and how do I fix it? we have a huge antenna on our roof
1 – Is the NO SIGNAL issue happening on just one TV?
CORRECT INPUT or SOURCE
If it is just one TV that is showing the NO SIGNAL…
-Be sure your TV is on the correct source or input as your CABLE or SAT BOX.
-Press the TV button on TV remote control to turn your TV ON.
-Press the INPUT button on your TV remote control.
-Cycle through all the inputs on your TV.
-Do this until you are on the INPUT your CABLE or SAT BOX is plugged into.
-You should then see the CABLE or SAT programming show on your TV.
HINT: Your TV will most likely list the TV INPUTS as: HDMI 1, HDMI 2, HDMI 3, VGA, Component 1, Component 2, and so on.
If you still see NO SIGNAL on your TV screen, see the next step below…
2 – If you have your TV on the correct INPUT or SOURCE and you still see NO SIGNAL…
CABLE OR SAT BOX NEEDS RESET
-Remove or unplug the power cable from the Cable TV or SAT set top box.
-Keep it unplugged for 2 to 3 minutes.
-Plug the power cable back into your Cable or SAT set top box.
-Give it some time for the Cable or SAT box to power up, get the signal, and initialize.
3 – If you have reset the Cable or SAT box and still have the NO SIGNAL…
UNPLUG THE CABLE GOING FROM THE TV TO YOUR CABLE OR SAT BOX
-Remove the HDMI cable or other cables from your Cable TV or SAT set top box.
-Keep the cable unplugged for 2 to 3 minutes.
-Plug the HDMI cable or other cables back in.
-Give it some time for the Cable or SAT box to get the signal and initialize.
HINT: Make sure all the cables that are connected to your Cable or SAT box and your TV are tight, undamaged, and secured.
4 – If all of your TVs are affected with the NO SIGNAL screen…
BE SURE THE COAX CABLES OR ETHERNET CABLES ARE SECURE or CABLE OR SAT IS DOWN TEMPORARILY
-Be sure to check the ones where the CABLE or SAT come into your home.
-Be sure ALL Ethernet and Coax cables are secure.
-Call your CABLE or SAT provider to see if there is an outage.
-Realign your Dish if you have SATELLITE.
May 10, 2017 | Televison & Video
I touched the wrong button on the remote and know tv says no signal and I can't get it back
Try going to your input button on your remote and see if you are still on the right input like if your tv is using a hdmi cable from your cable or satellite box then your input should be hdmi or hdmi 1 or hdmi 2 etc... also if you have cable or satellite make sure you didn't change the actual tv off of channel 3 or 4 whichever you have your cable or satellite box set on. I hope this helps.
Feb 06, 2016 | Televison & Video
The tv screen on my u-verse tv shows no signal
Hi!
No signal issues are mostly resolve by checking the TV input settings.
You can follow the ff. steps:
1. Using the original TV remote control, look for a button labeled "tv / video", "input" or "source"
2. Select each of the available input until you get the Uverse picture or if you can check the type of cable that you are using to connect the TV and receiver, it'll help you to easily select the input settings. example HDMI cable
I hope this helps you and please don't forget to rate me.
Thank you. :)
Aug 18, 2014 | AT&T Televison & Video
Blue screen
This sounds like a signal issue. make sure your antenna is connected. Try a different input device. connect a dvd player, set top box for satellite or cable, or a camera, set the tv to the appropriate input and check for an image. Hope this helps.
Apr 28, 2014 | Vizio GV42L 42 in. LCD Television
How do i get the TV to play satellite? it just says weak signal when I turn the tv on. JVC RM-C18G
It has to be on the right channel. If you are supposed to be on channel 3, 61, 73, 113 (ask the satellite company which one you should be on) then you'll have to change the channel. If you are not supposed to be on a channel you have to find out which input you're supposed to be on (video 1, video 2, video 3, av 1, av 2, av 3, hdmi 1, hdmi 2, input 1, input 2, input 3 for example).
Jul 19, 2011 | Televison & Video
I can hear the tv but no picture.. i remove the red, yellow, and white cord from the back of the tv to dust...pls help.. Apex tv brand
Hi! Welcome to Fixya!
If you are unable to view video on your television set, the issue may be that the TV's video input selection does not match.
The TV input source must match how the equipment for example DVD is connected to the TV.
* Plug the RCA cables(red,yellow,white cord) to the designated ports.
* Grab your Apex TV remote and attempt to cycle through the video inputs by hitting the "Input" button at the top of the remote multiple times.
* If you have used a DVD player or similar external device recently, you may have neglected to switch the video input back to the one assigned to your TV programming.
* Devices such as DVD players often reside on the AV 1 or AV 2 video input, and failure to switch back off of one of these will result in a dark, soundless screen when attempting to view cable or satellite television.
* Cycle through the inputs until you land on your cable/satellite input once more, which should result in an immediate restoration of picture and sound.
* If it does not, approach your Apex TV and look over the A/V cable connections. The A/V cable has two sets of prongs, one on either of its ends. Each prong is either red, yellow and white, and plugs into corresponding A/V ports on the back of the Apex TV and the back of your cable or satellite box. Make sure the ports and prongs are color-corresponding and have not been switched up.
Thank you for using FixYa. Keep me posted. :
Mar 12, 2011 | Televison & Video
My LG Plasma TV Model 50PC1DRA displays the following message after powering it up and connecting to cable: "Invalid Format" All of our other in house TVs attached to the same cable are fully...
Hi
Thanks for using FixYa. Invalid format indicates issues with the PC Mode, if the signal is not out of range then check the input source.
Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 30, 2010 | Televison & Video
Purchased model NS-LCD32 second hand with no
Since you are getting the signal from the satellite, leave the satellite receiver ON and press input on the TV buttons until you get the signal back, wait 2 seconds after pressing the input button. Make sure the TV is on channel 3 if you are using the antenna input.
Let me know if you need further assistance.
Jun 13, 2009 | Insignia IS-LCDTV32 32 in. Television
Tv screen is white; sound is ok
Need more information about you problem. Does the white screen appear on all functions.Does any input signal like a dvd or vcr show picture. If so, then you have a problem with signal connection coming from the television signal source, like a cable or satellite box. You need to check the connecting cables to see if they are outputting signal. Try using different cables to connect the signal source to the television. If this does not work. Try hooking up the signal source to another television to make sure you are receiving signal from them.If all this seems to be working fine and you are sure that you are using the remote control inputs correctly, you may have a problem the video input signal board on the television. You can contact PROSCAN at this web address. www.oncorpus.com. Go to customer support and ask for their technical assistance with your problem. The telephone number for PROSCAN service is 1-888-977-6722. I hope this has been of help with your problem.
Apr 08, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
I have a Sharp Aquos LC-30HV4U which is supposedly HD ready. I am a Dish Network satellite subscriber. I do not know what to do to make this HD ready set receive HD signals.
Your reciver is already set for the hd. Alls satellite programing and cable already come in hd format. You can also get any info here.
http://www.dtv.gov/
Good luck and please rate FixYa!
Apr 07, 2009 | Televison & Video
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
124 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
