Question about Linksys Wireless-G WRT54G Router
Useing WRT54G WITH STARBAND
How can I set up my WRT54G router with Starband broadband?
  • Thomas Van Tress
    Thomas Van Tress May 11, 2010
    Is Starband Cable or DSL provider? And did they supply you with a modem? If so what type is it.?
    Problem Solver:
  • 19 Answers
Your starband is if im right the cable modem ? connect the modem to the router and then the router to the computer ? then run the linksys easy connect @ www.linksys.com/support
Posted on Jul 19, 2008
Hi I have a linksys wireless-G broadband router but I have no instructions to set it up
go to http://homesupport.cisco.com/en-us/wireless/lbc/WRT54G, click on downloads tab and select a Quick Installation Guide.
Sep 27, 2010 | Linksys Wireless-G Broadband Router
I lost my cd to my linksys wireless router m#.WRT54G ....how can I get the router to work???
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Aug 26, 2010 | Linksys WRT54G Wireless-G Broadband Router...
We are on Starband Satellite internet. Have windows programs , both vista and xp. We have the linksys G wireless internet system. How do we install it ?? So far, when we put it in, nothing works. No...
Yes you can but it is not as easy as using a router with a cable or dsl connection.
The 360 modem requires the Mission Control software in order to run properly so you can't just hook it straight to a router.
What you need to do is use an old computer to sit in the corner and act as a router(kind of) and then connect it to a real router.
When your finished you won't even need a monitor for it. You will need either two network cards in it or 1 network card and a usb port to hook it up to the 360 modem. Make sure network cards are also working correctly. Install the starband mission control software and make sure it is working correctly.
In Winxp go to network connections and right click on the one hooked to the starband modem and click properties. Now click on the advanced tab and check "Allow other network users to connect through this computers Internet connection.
You can plug the other network cable straight into a switch and this computer will hand out ip addresses through ICS(Internet connection sharing) built into winxp.
You can also get a wireless router and change the ip address of it to match the range that ics is handing out and disable the dhcp server so that you don't have two things handing out ip addresses.
If you use the web accelerator you will have to put it in the browser of each computer that you will be using (in the browser under proxy). It will be something like 192.168.0.1:9877.
Also make sure your running a firewall on your little router-computer. If the computer is running winxp professional you can take the monitor off and use remote desktop connection to check on things or to control it. Or search the Internet for VNC.
from____cajun101...yahoo
hope this helps you get more confused :)
Oct 24, 2009 | Linksys Wireless-G Broadband Router
Need settings for Huawei HG510 with Linksys wireless WRT54G
You could reset you router to default settings.
On the back of you router, you will find a little hole
using a pen, press that reset button.
Mar 27, 2009 | Linksys Wireless-G WRT54G Router
I have a wrt160n router hooked up to a desktop computer and a
Sound like you have a bad network card on the PC or the router ports have gone bad.
Have you tried different ports on the router?
The problem could also be in the ethernet cable.
Try another cable and see if that makes any difference.
Mar 12, 2009 | Linksys Wireless-G WRT54G Router
Connectivity
Hi Joe,
That just depends on how you want to connect with your laptop.
If you need wireless access, then you have to use the WRT54G, because the RT31P2 has no wireless capabilities.
If you are connected via ethernet cable, then you can simply take the WRT54G out.
If you like to read up on different scenarios, here is my favorite page.
Enjoy!
Jan 07, 2009 | Linksys WRT54G Wireless-G Broadband Router...
Setting up network with wrt54g with dial-up internet
There is no way a wirless or brodband roter will work for any dial up conecsions only will work for hugh speed internet or DSL internet. If you are chosing to upgrade lock at the chosis verizon has. Just go to www.verizon.com to see if you are elagable. They haves some very low cost deals and if it is ordered online you get a discount,
Jan 04, 2009 | Linksys Wireless-G WRT54G Router
Lost disk
Umm, try going to the linksys website, but to be honest, I have set up several linksys networks using your type of router and it works perfectly fine without the setup cd.
Mar 22, 2008 | Linksys Wireless-G Broadband Router
Linksys wireless-G router configuration on PPPoE internet connection
Connect modem to the internet port of the wrt54g
Connect pc to port 2 of the wrt54g
Reset the wrt54g, push reset button for 30seconds with the power on, uplug the power for 10 seconds
Open internet explorer, type 192.168.1.1, you will be asked to login, no username, password is admin. This will take you to the router page. On the page you will se AUTOMATIC CONFIGURATION DHCP, change that to PPPOe, enter your broadband username and password. Click save settings at the buttom of the page. YOU WILL ONLY GET CONNECTION IF YOUR USERNAME AND PASSWORD IS CORRECT.
GOOD LUCK
Mar 14, 2008 | Linksys Wireless-G Broadband Router
Linksys Wireless-G WRT54G Router Logo
119 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
