I cannot install a new printer cartridge in my canon mx300 printer
  • sbreul Jul 19, 2008
    I have a PIXMA mx300 printer and am unable to install a new black cartridge. It looks as though it should just slide right in but it will not do so.
  • 813 Answers
U have to see your user guide your problem will solves
Posted on Jul 19, 2008
  • 13,433 Answers
Have you installed the software from the cd? or should I get it for you from the internet?
old marine
  • 1814 Answers
SOURCE: installing new ink cartridge, canon pixma 1600
Go here. Type "how to install ink" in the search box. Click "Search", then select "How do I install the ink cartridge(s)". You will get instructions with pictures on how to prepare and install the cartridges.
Posted on Apr 17, 2008
xclancy
  • 82 Answers
SOURCE: I need instalation my printer Canon MX300 ,no have cd instalation
hi
Please dowload the drivers from the below link
Choose the appropriate Operating system of your PC/Notebook
and then dwonload
Canon MX300 printer driver
Even the manuals are provided. in case you need it
All the best
Posted on Jan 04, 2009
nyilasrobert
  • 627 Answers
SOURCE: error 5100
5100 is a Carriage Home Position Error.
try cleaning the plastic strip that runs the length of the carriage, it may be contaminated.
Use alcohol and a swab
Posted on Jun 29, 2009
  • 164 Answers
SOURCE: finding the ink cartridge
Look on the mfr's website for instructions on how to replace an ink cartridge.
Don't forget to rate the advise!
http:www.aa1consulting.com
Posted on Jul 31, 2009
SOURCE: canon mx300 states error 5100 check printer. when
I had the same code, and my cartridge would not move. My dad, who works on printers, told me to turn it off, and slowly pull the white band (to pull the cartridges) back to its place. I did this, and my printer now works perfectly. Try this first.
Posted on Jun 07, 2010
U051 error can i disable printer and use only scanner and fax canon mx300
Sadly not. The cartridge error will have to be resolved before you can use the scanner/fax. You do not however have to have a full cartridge installed, the printer just needs to be able to recognise the cartridge.
Sep 11, 2012 | Canon MX300 Office All-In-One Printer
Tip
How to Reset Ink Level Canon MX300 Cartridges
1. Switch off the Canon MX300 and disconnect the power cable.<br /> 2. While press and hold the power button, Connect the power cable to electric socket.<br /> 3. While pressing the power button, press the "Cancel/Stop" button (red button).<br /> 4. Now release the power button and the printer turns into a kind of factory mode. Wait for 10 seconds until it says "idle".<br /> 5. Press "&gt;" (next button) once "Shipping Mode 3&prime; then Press the "OK" button. Press "OK" again for "without cleaning".<br /> 6. A test page will print.<br /> 7. Open the cover, like you are about to change the cartridges.<br /> 8. Disconnect the power cable again without switch off the printer.<br /> 9. Take out the both cartridges.<br /> 10. Close the cover.<br /> 11. Connect the power cable and turn on the printer.<br /> 12. Now just put the cartridges back and the ink level in the canon Pixma MX300 have full again.
on Feb 17, 2011 | Canon MX300 Office All-In-One Printer
I have a canon pixma mx300 printer that has a message check printer 5800 the troubleshooting says to unplug and plug back in that does not work
When you refill your cartridge or do something to your cartridge,
the printer does not recognize the cartridge.. This is what it happened here.
Any solution?? Unfortunately, there isn't any.
Once your cartridge is shorted... that particular cartridge is useless.
You have to replace with new one.
However, you can always prevent what this happens.
1. Always unplug the power cords before take out your cartridge.
2. Same thing applies when you insert the cartridge.
In this way, you can avoid the cartridge shorts with refilling your cartridge. thanks
Aug 21, 2011 | Canon PIXMA MX300 All-in-One Printer
What does recommend mean when I'm trying to fax on
Probably means to replace the c-crt (ink cartridge c).
Apr 28, 2010 | Canon PIXMA MX300 All-in-One Printer
Canon mx300 not recognize reffil cartridge color 51,
This cartridges has a memory chip and printer will recognized refill cartridges like empty.You can't reset the ink level on all Canon Pixma printers.Push resume button and hold it for 5 seconds.This operation releases the function for detecting the remaining ink level of the above ink.The printer shows empty cartridges but it will printing.
If this not help there is a minimum chance your cartridge is failed electrically and printer not recognized.In this case replace the cartridge.
Nov 18, 2009 | Canon MX300 Office All-In-One Printer
I just refilled my black ink cartridge in my mx300 canon printer, but it still says out of black ink, I think because the cartridge has been a little overfilled. when I click on supply levels it says...
You will have to purchase a new cartridge as your printer has a mechanism built-in which detects the date of the cartridge and locks it if it was once empty and then re-filled.
You can try and ask the re-fill vendor to reset the cartridge time but not every cartridge can be initialized.
Sep 15, 2009 | Canon PIXMA MX300 All-in-One Printer
Cant print using Canon Pixma MX300
Hi
1. Disconnect the power cable
2. Connect it while holding down the power button
3. With the power button still down, press twice the "Cancel/Stop" red button
4. Release the power button
5. The prints turns into a kind of factory mode...(wait for about 10 seconds, utile it says "Idle")
6. Press the ">" (next to the "OK" button) once.” Shipping Mode 3"
7. Press the "OK" button.
8. Press "OK" again for "Without cleaning"
9. A test page will print.
10. Open the cover, like you are about to change the cartridges.
11. Disconnect the power cable again.
12. Take out both cartridges.
13. Close the cover.
14. Connect the power cable once again.
15. Turn the printer on.
16. Now just put the cartridges back...
Or try this
Here the Solution to reset the ink level for Canon Pixma MX300 follow this steps to reset the ink level in your canon MX300.
  3. While pressing the power button, press the “Cancel/Stop” button (red button).
  4. Now release the power button and the printer turns into a kind of factory mode. Wait for 10 seconds until it says “idle”.
  5. Press “>” (next button) once “Shipping Mode 3′ then Press the “OK” button. Press “OK” again for “without cleaning”.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Sep 08, 2009 | Canon PIXMA MX300 All-in-One Printer
Startup
catridge were not installed correctly, follow the user maunal
Sep 19, 2008 | Canon MX300 Office All-In-One Printer
Installation of catrdiges
Go to this link. Type "install cartridge" in the search window in the center of the screen and click on the Search button. Select the appropriate answer and you will see step-by-step, illustrated instructions for installing the cartridges.
Sep 15, 2008 | Canon PIXMA MX300 All-in-One Printer
26 people viewed this question
k24674
