Question about DeLonghi Heating & Cooling
Hello i have delonghi bambino radiator its has switched off ( safety reset overheated) can any one advise me how to reset it thanks
2 Suggested Answers
  • 133 Answers
SOURCE: my delonghi dragon safeheat is
It does have a thermal safety and it very well could be the problem. I looked up this review for you. I hope it is what you were looking for. Roger http://products.howstuffworks.com/delonghi-dragon-oil-filled-radiator-heater-hm25e-review.htm
Posted on Apr 06, 2011
My delonghi dragon safeheat is cutting off. I have not set the timer to turn it off. Is this a safety shutoff from overheating?
Apr 06, 2011 | DeLonghi Heating & Cooling
My heater fell over on its side for about 20 seconds and niow won't heat. Is there a resent switch? Thanks
your tilt safety switch went off.. stand back up and keep unplugged, for about a min..then try it, or until it cools down
Dec 18, 2010 | DeLonghi TRD0715T Oil Filled Radiator...
The oil filled heater has not been used over summer --- now it blows the house safety switch each time it is switched on
Hello, if this heater has tripped the main breaker its on, you have a dead short somewhere in the unit. Even though it may have worked fine when you stored it, you do have a direct short. There is not much to go wrong with these heaters, I would grab a strong light and a few tools and check the wires at the on/off switch, thermostat control to see where the short is. Could be a mouse has chewed a wire in to causing this to happen. Its hard to say, but should be easy to find. Check everywhere you have wiring, and you will find the problem. You can also disconnect one control at a time and have some one reset the breaker, or you can unplug it, reset it and plug it in as you try disconnecting each control. There couldn't be many. Keep me posted please. Let me know what you find, it should be very easy to locate.
Sincerely,
Shastalaker7
Jun 11, 2010 | DeLonghi TRD0715T Oil Filled Radiator...
Hello, I have a Model # TR0715 that needs a power
yes a switch opens and closes the power take old one to hardware store or local electrical supplier
Jan 16, 2010 | DeLonghi 6707E Oil Filled Radiator Heater
I need to reset my Delonghi radiator. it overheated
Unscrew the four screws holding the front faceplate on (two are on the bottom of the radiator). From the bottom end gently pry up the faceplate, it will stay attached at the top end near the temperature selector. Look inside and you will see a black bridge like piece of metal with a plastic and metal thing stuck to it's center with two wires leading into it. It's basically a connection that melts when high temperatures are reached, therefore it must be replaced (pictured). You can bypass this by prying the metal bridge out, removing the wires leads from the switch and connecting them using a wire nut. BE AWARE THAT THIS WILL OVERRIDE THE HIGH TEMPERATURE SHUT OFF MECHANISM, so don't use it for drying off your coat again._361.jpg
Feb 08, 2009 | DeLonghi 6707E Oil Filled Radiator Heater
Heater stopped working suddenly
In the past I have nothing but problems with DeLonghi heaters. I replaced them with Pelonis heaters and have had no problems since. Pelonis heaters are availible from Home Depot at a very reasonable price. This is based on my experience only. Hope it helps.
Ray
Dec 05, 2008 | DeLonghi Heating & Cooling
How do I reset ?
It should come on automatically, if it does not then the thermal switch is faulty, and has to be replaced.
Jan 22, 2008 | DeLonghi DUH300 Utility Heater
Heating & Cooling Logo
95 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
