1999 Honda Accord Logo
A
Anonymous Posted on Jan 29, 2011
Need to unlock radio code - 1999 Honda Accord
Anonymous
Level 2:
  • Expert 128 Answers
  • Posted on Jan 29, 2011
Anonymous
Expert
Level 2:
Answers
128
Questions
0
Helped
46851
Points
411
If you do not have the code you need to go to the dealer and get the code from them. You just have to show them the car is yours and you id. Do not let them charge you it is a free service.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 09, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
126
Points
Honda crv cd code me
How do I unlock my radio on an 2016 Chevy equinox
Step 1: Look at your radio. Check and see if the code "RDS" is written on the face of the radio. If "RDS" is present, contact a GM dealership to have your radio unlocked by them.
Step 2: Check for the identification code. Press buttons 2 and 3 for 8-10 seconds. If a code does not appear on the display, you won't be able to unlock your radio in this manner.
[If that doesn't work vvv]
In order to obtain your radio unlock code, you need to find your radio's serial number. You can get the radio serial number directly from your radio.
Step 1: Turn on the ignition. Turn the key to "accessory" mode or "on" mode.
Step 2: Turn on the radio. Press the power button to turn on the radio.
If your radio displays any functions such as playing a CD, cassette, or a radio station, your radio is not locked. If no sound is heard, you may need to replace your radio unit.
If your radio is locked, "LOC" is displayed on the screen.
If "INOP" is displayed, keep your ignition on for 60 minutes with "INOP" on the display. After the hour is up, it should change to "LOC." After this you can proceed with the next step.
Step 3: Write down the code. Press buttons 2 and 3 at the same time and hold for 8-10 seconds. Write down the three-digit code that is displayed.
Step 4: Note down the code. Immediately press the AM/FM button. Another three-digit code is displayed. Write it down as well.
This is your six-digit radio serial number.
Now that you have your radio's serial number, you can obtain the radio unlock code from General Motors. Be ready with a pen and paper to write down your radio unlock code.
Step 1: Contact the GM radio hotline. From any landline or cell phone, call the toll-free GM Radio hotline at 1(800) 537-5140.
Step 2: Enter the code. When it requests a code, enter "106010" on the keypad, followed by the pound (#) sign.
Step 3: Enter the radio serial number. You will be prompted to enter the radio serial number you have just obtained.
At the prompt, enter the number followed by the pound sign.
Step 4: Write down the radio unlock code. The prompt will read out your four-digit radio unlock code. Write it down precisely.
Now that you've obtained your Chevrolet radio unlock code, you need to enter it into your radio.
Step 1: Switch on the radio. Turn your ignition on and press the radio power button. Your radio will display "LOC."
Step 2: Enter the first two digits of the radio unlock code. Press the hour button on the radio to enter the first two numbers of your radio unlock code.
Continue pressing the button repeatedly until the first two digits of the radio unlock code are displayed.
Step 3: Enter the last two digits of the unlock code. Press the minute button until the last two numbers of the radio unlock code are displayed.
Repeatedly press until they match the two digits you need.
Step 4: Confirm the code. When the code matches, press the AM/FM button. "SEC" will display on the radio, indicating a successful attempt to enter your radio code.
If you enter the code incorrectly eight times, the display will switch from "LOC" to "INOP." You'll need to leave the ignition on for an hour as described in Part 2 before you can retry.
Write the radio unlock code in a safe place such as in your owner's manual for future use.
Most car dealers will charge you a lot of money just to get the code for you. If you follow the right steps, you can get the code for free and be able to start listening to the radio again in just a few minutes!
How to Unlock Chevrolet Theftlock Radio
1helpful
Radio unlock code
When you disconnect the car battery you will disable your car radio, (this is an anti-theft device).The unlock code is in your Owners manual. If you do not have this code you need to go to your Mitsubishi service centre to get them to unlock your radio for you.
Car radio unlock code
The unlock code is in your Owners manual. If you do not have this code you need to go to your Mitsubishi dealer/service centre to get this code or get them to unlock your radio for you.
2helpful
2answers
I need a code to unlock my car radio for 2002 mitsubishi galant
take you vin number to amitsubishi dealer if its the orignal radio he will be able to get it for y
9helpful
4answers
My radio is locked i just need the code for a monte carlo 97 GM delco radio
If the code is not at the back of your manual, try 0000 and if the radio locked it self from taking any more codes. Just disconnect the battery and that will reset the radio so you can re-enter the code. If 0000 did not work then log on to Radio-code.com, you can get your cod there for like $12.00 which is cheaper then the dealer and you get to know the codes as most dealer will just unlock the radio. Good luck and hope this helps, keep me posted if you have any more question.
3helpful
Unlock 2000 ls2 saturn radio
well the only way to unlock the radio is this,,,there is a 4 digit code stored in the radio you need to get it from the radio,you must press and hold radio preset buttons 1 and 2 for 5 seconds and then a 4 digit code will appear,write down that code and respond to me so i can get you the unlock code,,only dealers can get the unlock code,i need to call saturn with that code thats in the radio to get you the unlock code,and then you enter the unlock code and you good to go,,,or you can take it to saturn and they may or may not do it for you for free,,but if you want just get back to me with the unlock code
3helpful
Need radio unlock code 99 olds aurora
They are all random codes that are stored in the radio. The radio can lock it's self with possible 10.000 differant codes. You will need to take it to the dealer to have them use the gm scaner to retreive the code that is in the radio then they call the gm headquarters and those egg heads give an unlock code for the car. All of the make since?
2helpful
3answers
Unlock radip code,1998 honda accord 4 door
if you do not have original anti-theft radio code you will need to remove radio and retrieve s/n off of radio. once you have that you can go into nearest honda dealer and with s/n they can give you correct radio code
3helpful
Need unlock code for 2003 buick century car radio
You will need to take the car to a dealership to have the service department unlock the radio for you. They have a special code to unlock the radio and then you are required to change the code to one that you will remember. An appointment should not be needed because this takes about 5 minutes. I do not remember the code, sorry.
Need radio code to unlock
if you have your code and need to know how to enter the code , it should be as follows .
Unlock procedure for six digit codes. Push the "Hr" button, 000 will appear in display. Press the hour button until you match the first number of your unlock code. For second two digits of unlock code press the "Min" button until numbers match. When first three digits of unlock code is entered into display, push the AM/FM button. Repeat the above process for second set of three numbers of unlock code.
if you need more assistance, post comment before voting thanks .
Top Honda Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Honda Expert? Answer questions, earn points and help others
