Question about Mitsubishi WS-73907 TV
Ws-73907 not turning on
Ive got a mitsubishi 73 inch projection that after you turn it on about 3 seconds later it turns right back off, no lights blink it just powers down. ive been looking around and i think i have to replace one of the boards. what do you think
thanks mat
  • atlemzu Aug 03, 2008
    I'm having the identical problem with mine.
  • thameksta70 Oct 29, 2008
    same power failure to start-up t.v.
  • 1153 Answers
SOURCE: 65 INCH PROJECTION SCREEN IS SUPER BRIGHT
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR LEAKY C9A60 470 PF 1000 V PART # 154P400030, PARALLEL TO D9A57 ON THE POWER PCB (NOT SHOWN IN THE SCHEMATIC). 2. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT. 3. SELF-DIAGNOSIS INDICATES SHORT PROTECT. CHECK FOR A SHORTED IC4B01 PART # 270P261020 (VERTICAL OUTPUT) LOADING 24-VOLT SUPPLY LINE. LOCATED ON THE MAIN PCB
Posted on Sep 19, 2007
  • 927 Answers
SOURCE: dm board (power supply) for mitsubishi rear projection tv (ws-55807)
Good day,
mohiuddin;
If the indicator stays on then you may have an DM PCB problem and to correct this do the the folowing:
SYMPTOM: Power LED does not stop blinking after plug in.
CURE: replace C9B01, C9B02,C9B10, and C9B11 (1000 uFD 16V) on the DM PCB. Replace them with part # 181P734030 (680uFd 16V).
The DM Board (PCB) is located on the very left side of the TV looking from back. Caution on removing Board and note what cables you disconnect to access the Metal Shielded Board.
Good Luck, big IRISH.
Posted on Jul 30, 2008
VOTIT
  • 2071 Answers
SOURCE: Help, Help, Help! Mitsubishi 73" red convergence fiasco
Thats the time you need to replaced the convergence IC.
Just click below for convergence repair kit;
http://servicemanuals.vstore.ca/
Double images and colors are blurry and fuzzy images .Blue,red and yellow wave coming up from the bottom of the screen on the lower left and cannot be adjusted this is the symptom for busted convergence IC,you must replaced this IC in order that will works better again.STK 392-xxx ICs and it's associated resistor,this resistor automatically change value,can caused truoble even though you change the ICs.If you bring this to a service center they cost you $600 to $700,but if you buy the repair kit you can save more,don't wory it is very easy because there is intallation guide including in the repair kit. Feel free to ask whatever the result... click the link for sample picture guide step by step installation;
Hope this may help;
Regards,
VOTIT
Posted on Oct 10, 2008
MrMojoRisin1
  • 412 Answers
SOURCE: I want to buy an
hi. You can use a VGA cable and a VGA- HDMI adapter or one ot this (click here) .
Posted on Aug 29, 2011
  • 4 Answers
SOURCE: Green power light blinking all the time on TV
After changing a defective capacitor, my TV still would not power up. After using a solution I found on this site, I held the power and volume up button down on the TV itself for several seconds, the TV powered up normally. I did notice that you had to do this while the timer light was flashing. Doing so after it went out was not effective. I initially only replaced one capacitor which was noticeably defective, and the flashing green timer light eventually returned. I will be replacing all 7 capacitors and resetting the TV. As mentioned above, the capacitors may look good but in fact may be defective. These are high temp caps which breakdown under a load but function normally when cold. Several people have mentioned replacing the capacitors didn't fix the problem. It appears that you must replace and reset using this method to repair some of these TVs.
Posted on Feb 28, 2012
Why is tv blinking 4 red lights and 8 yellow lights
An error code of 48 indicates a main power board failure. There is a short down the 3.3v or 5v switched supply.
recommend replace main power board.
part# 934C409001
see the following website:
http://www.shopjimmy.com/mitsubishi/wd-73c11?cat=59&q=WD-73C11&tv_models=Mitsubishi+WD-73C11
Jul 01, 2014 | Mitsubishi WD-73640 73-Inch 1080p...
The power on no piture
If the power light comes on (green) for a few seconds and goes off:
MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device"(input) and "menu" buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC's is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and two blinks--this is the most common and easiest to fix.
Nov 06, 2012 | Mitsubishi WS-73713 73" Rear Projection...
I have a Mitsubishi rear projection TV (WS-73909) that didn't turn on and had a green blinking light. I replaced the 7 DM capacitors and now it turns on. Both the remote and front control panel ca
Let me know as I can look for this---the set has a keyboard lockout that is cleared by holding the menu or another front button for more than 5-10 seconds with set on---I can find the service manual and check if needed.
Nov 04, 2012 | Mitsubishi WS-73909 73" Rear Projection...
Mitsubishi 73" DLP powers on, through welcome
If you are getting at turn on source and back ground is all blue the set will shut down rather quickly;
I have a suggestion, if it works fine, and if not it will not hurt anything.
with original Mitsubishi remote turn set on and then Menu, 1,2,3, enter.
This is the soft reset that most of these sets have (cannot be sure since Model number above is correct?)
The reset button on the front (if it has it) just shuts the set down and reboots the DM unit inside.
Most of these sets when it is pressed the green light will blink for about 70 seconds and go out; that is the DM unit rebooting and the soft restart is something else.
Let me know what you find before you rate this information.
SD TECH
Oct 05, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
I have a Mitsubishi TV model WS-48511 it was working fine, I shut it off came back a few hours later & when I turn it on the green light will come on for about 3 seconds but turns back off. What can I...
Unplug it from the wall for about 5 minutes.
with it unplugged, Press and hold the power button for around 30 seconds.
This should discharge the unit and allow it to come back on.
Jul 02, 2011 | Mitsubishi WS48511 48" Rear Projection...
I have a wd 62725 mitsubishi digital tv. the timer light keeps blinking fast and cant turn on the tv nor watch it what could be the problem
Try pressing power button for 10 seconds or until it turns off. Wait for 1 minute and turn it on again.
BTW, I own a 73 inch model.
Jun 22, 2011 | Mitsubishi WD-62725 62" Rear Projection...
Have a ws 73-711 that does not turn on. If you unplug it then plug it back in you get a rapped green flashing light for a few seconds then nothing. any help would be great
Have you tried accessing the led self diagnosis by pressing the menu button and Input button both in together and hold for 6 seconds on the front panel of the set. It should then blink a two digit blink sequence from the power indicator. which will repeat several times let me know the blink sequence and I will assist you.
Feb 18, 2011 | Mitsubishi WS-73711 73" Rear Projection...
I nannot turn off cations on 73 inch tv
look for a button on the remote most probably labeled " CC " or go into the menu in the audio or setup section and you should find the closed caption settings.
Jul 31, 2010 | Mitsubishi WS-73713 73" Rear Projection...
Mitsubishi WS-73907 TV Logo
78 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
