Question about Gateway Media Center 610XL PC Desktop
Looking for a manual
Took the gateway 610xl apart a few months ago. I finally got the part I needed. The problem is I don't recall the exact location of all the connections I need to make. I can't seem to locate a manual for this. any help would be appreciated.
    Problem Solver:
  • 19 Answers
Unless gateway will support you in this they are the only ones that can get that kind of information for you...... either that or ya could call the geek squad at best buy and have them come to your house and fix it .
Posted on Jul 19, 2008
Ignition switch stoped working, just locked up and wouldn't turn. How do I know this isn't part of the recall problem.
Call the dealer and provide them with the VIN of the vehicle, just tell them you want to know if any recalls are open on your paticuliar car.
Mar 07, 2014 | 2005 Chevrolet Impala
How do you take apart a gateway zx4800-06 all in one computer to put a new hard drive in. I took the case screws off but the cover won't budge and I don't want to take a chance of damaging...
You don't need to take apart all the back cover. Only the small rectangule part where the back support is located. The hard drive is located under the small cover.
Aug 12, 2011 | Gateway ZX493131e Notebook
ECM Giotto toggle (power) switch needs replacement ASAP in Seattle area.
i had this happen myself a few months ago, power switch blew, i took the machine apart took out the power switch, and visited a few local electrical component suppliers, its a standard switch but its 2 stage single throw switch, home depot/Lowe's don't carry this type. ended up going to 3 diff suppliers and finally found a commercial supplier that had it connected the new one and now its fine, works better than the old one ever did. just make sure you bring the broken switch with you when you go to show them, most good suppliers can match it and see if they have one like it in stock.
Apr 21, 2011 | ECM Giotto Espresso Machine
Afew years ago my low beams both went out at the same time, I took it in and had repaired, a few months later received recall for the problem, had my money refunded and everything worked well, until 2...
yes easiest solution since it was a recall take it back to suzuki and tell them politely it has the same problem and let them deal with it..good luck I hope they look after you
Dec 21, 2009 | 2005 Suzuki Forenza
94 accord, the speedometer doesn't work.........
I had a similar problem a few months ago. I changed the speedometer sensor as well as the instrument cluster with no result. Finally I decided to take out my ECU. As soon as I took it apart, I noticed a burnt node. Replaced the ECU and the speedo worked fine. You might try this if tinkering with your cluster doesn't work.
Mar 06, 2009 | 1994 Honda Accord
How do I change the video card in my 610XL PC?
After the side of the case is opened and the computer unpluged and the video to the monitor unplugged, if it has a card already installed , remove the screw holding the card down then pull the old card straight up out of the card slot. Align the new card that you purchased , pushing it straight down into the slot. Install the hold down screw. Reinstall the side . Install the software after hooking  the computer and monitor up.   If you don;t jknow which type of card ,down load a manual and maybe even further instructions from the weblink I provided.
Below it the Gateway support center for your model. All you have to do is to put in your 22 digit serial number.
http://support.gateway.com/support/drivers/dlcenter.asp
Feb 16, 2009 | Gateway Media Center 610XL (610XLMDIA) PC...
How do I install a power supply in a gateway 610xl computer?
REMOVE THE CASE AND UNPLUG ALL.THERE SHOULD BE 4 SCREWS HOLDING IT IN PLACE REMOVE THEM.REINSTALL NEW IN REVERSE.RICHARDM69
Nov 26, 2008 | Gateway Media Center 610XL PC Desktop
Blinking screen
change the refresh rate of the monitor
Oct 01, 2008 | Gateway Media Center 610XL (610XLMDIA) PC...
Screen frozen and will not pick up location...
I had the same problem, and finally figured out to reset it. The reset button is on the left side under the strip. You need a pen to push it in. It took a few seconds to reboot but it came on normal after that.
Jan 20, 2008 | Magellan RoadMate 2000 GPS Receiver
Turntable problems
buy a better record player
Sep 27, 2006 | Emerson NR303TT CD Shelf System
Gateway Media Center 610XL PC Desktop Logo
69 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
