2005 Ford Ranger Logo
Posted on Jan 29, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Engine light is on - 2005 Ford Ranger
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 233 Answers
  • Posted on Jan 29, 2011
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
233
Questions
0
Helped
46845
Points
736
This would indicate something wrong with the enguine such as a sensor or emissions control devise. take it to a mechanic and see what code pops up or try your auto parts store who may have a loaner code reader.
1helpful
2answers
Can a blown cigarette lighter fuse make the check engine light come on
No, the problem lies elsewhere.
Get a diagnostic check done to identify the fault
My Engine Check Light Is Illuminated
3answers
Check engine light on. How do I fix it?
How to fix your check engine light. - Instructables
www.instructables.com/.../How-to-fix-your-check-engine-li...
InstructablesStep 1: Buy an OBD reader. ... OBD stands for on board diagnostic. ... The OBD codes for a leaky gas cap are misleading and this happens a LOT, especially if you've recently gotten gas.
How to fix your "Check Engine" light ' Mobil™ Motor Oils
https://mobiloil.com/en/article/car.../how-to-fix-your-check-engine-light
Discover the mystery behind your pesky "Check Engine" light coming on before ... youcan likely do the job yourself and avoid that expensive repair shop visit.
Top 10 Check-Engine-Light Car Repairs ' Bankrate.com
www.bankrate.com/.../top-10-check-engine-light-car-repairs-1.a...
BankrateWhen the check-engine light flickers on your dashboard, don't stall. ... If you do not have Auto Zone call one of the other auto parts stores to see if they offer that service.... Catalytic converter is an easy fix; cut it out and replace with straight pipe.
HOW TO RESET CHECK ENGINE LIGHT, FREE EASY WAY ...
? 4:02
https://www.youtube.com/watch?v=H0EksnuQdMs
Jul 23, 2013 - Uploaded by Tampatec
HOW TO RESET CHECK ENGINE LIGHT WITHOUT ON ANY TRUCKS ... Code Reader gives you correct error code readings and can do ... How to reset engine warning light Toyota Corolla VVT-i engine and fix ignition error.
Why Did my Car's Check Engine Light Come On? ' Angies List
www.angieslist.com/.../why-did-my-cars-check-engine-light-...
Angie's ListA check engine light on a car can indicate anything from a loose gas cap to a more
2answers
Why does the 2012 kia forte engine light turn on?
Engine Light Is On: 2010-2013 Kia Forte - What to Do - 2010 ...
www.carcarekiosk.com/...Kia_Forte_EX...engine_light/diagnose
A check engine light can indicate a broad spectrum of problems with your 2010 Kia Forte. ... The video above shows how to locate the on board diagnostics (OBD) plug on your 2010 Forte, how to read the trouble codes and how to reset or clear the checkengine light using a scanner on ...
KIA Check Engine Light (CEL) Codes - Kia Forte Forum : Sedan ...
www.forteforums.com/.../11832-kia-check-engine-light-cel-codes.html
May 20, 2012 - 15 posts - ‎8 authors
Old 05-19-2012, 08:42 PM Thread Starter. SketchedOut ... KIA Check Engine Light(CEL) Codes ... P0115 Engine Coolant Temperature Circuit Malfunction. 2012 Forte Koup: Check Engine light
Jun 29, 2015
Automatic Transmission Shifting Harder Than Usual
Apr 27, 2014
Check Engine Light + P200A code on new 2011 SX
Jun 7, 2011
Oil filter caused check engine light?
Check engine light on with the TPS code. replaced TPS and pig tail and it checked out OK with volt meter. The light still comes back on with the TPS code
Check engine light comes on and off, these are indication that there is some error code stored in your vehicles ECM. The engine module computer needs to be scanned. These will give the code and as per the error code the further problem can be detected and confirmed. The engine light indicator blinks or remains steady on dash when engine computer noticed any problem with any engine electrically operated components.
For more help, I suggest you to refer the help links provided below. These will let you know more about which areas to look, check, when there is engine light coming up on dash panel.
Click the link below: -------
CHECK ENGINE LIGHT
http://alltypesofpartsreplacing.blogspot.com/2012/12/check-engine-lightengine-warning-light.html
Check Engine Light Reset Procedure?
http://whoisbyme.blogspot.in/2012/06/check-engine-light-reset-procedure.html
These will help.
Thanks.
2answers
How to reset engine lite in dash
Check Engine Light ON?
http://whoisbyme.blogspot.in/2012/06/check-engine-light-on.html
Intermittent Check Engine Light?
http://whoisbyme.blogspot.in/2012/06/intermittent-check-engine-light.html
WHY Check Engine Light On car?
http://schematicsdiagram.blogspot.com/2011/06/check-engine-light-on-car.html
Check Engine Light, VSC light and Traction Control Light ON?
http://whoisbyme.blogspot.com/2012/06/check-engine-lightvsc-light-and.html
Check engine light flashing?
http://technoanswers.blogspot.in/2012/02/check-engine-light-flashing.html
Service engine soon Light Turned OFF after Jump Start?
http://whatisbyme.blogspot.in/2012/06/service-engine-soon-light-turned-off.html
After replacing throttle body the Check engine light starts blinking?
http://technoanswers.blogspot.com/2012/01/after-replacing-throttle-body-check.html
2005 Chevy Impala: Service Vehicle Soon Warning Light?
http://whoisbyme.blogspot.in/2012/06/2005-chevy-impala-service-vehicle-soon.html
Malfunction Indicator Light ON
http://whoisbyme.blogspot.in/2012/06/malfunction-indicator-light-on.html
Check power-train message with orange engine light came on?
http://howtobyme.blogspot.in/2012/02/check-power-train-message-with-orange.html
2007 Toyota Highlander Hybrid: Yellow Check Engine Light ON dash?
http://whatisbyme.blogspot.in/2012/05/2007-toyota-highlander-hybrid-yellow.html
1999 Toyota Tacoma: Check Engine Light Read Code P0171?
http://whatisbyme.blogspot.in/2012/05/1999-toyota-tacoma-check-engine-light.html
Car Runs Fine But Check Engine light is ON?
http://whatisbyme.blogspot.in/2012/05/car-runs-fine-but-check-engine-light-is.html
Check engine light with codes P2195 and P2197?
http://howtobyme.blogspot.in/2012/01/check-engine-light-with-codes-p2195-and.html
How to Read Codes from Check Engine Light?
http://schematicsdiagram.blogspot.com/2011/12/how-to-read-codes-from-check-engine.html
Vehicle smog test failed Due to NO MIL/check engine light?
http://schematicsdiagram.blogspot.com/2011/12/vehicle-smog-test-failed-due-to-no.html
OBD Code is cleared but check engine light will not RESET?
http://schematicsdiagram.blogspot.in/2012/02/obd-code-is-cleared-but-check-engine.html
Car jerks while going uphill and Check engine light is ON?
http://schematicsdiagram.blogspot.com/2011/12/car-jerks-while-going-uphill-and-check.html
Toyota Camry Check engine light flashes while driving?
http://schematicsdiagram.blogspot.in/2012/02/toyota-camry-check-engine-light-flashes.html
These details will help.
Thanks.
3answers
Derrick Shultz and Lidia Harper - Indian spammers?i get in and the check engine light came on and was flashing and it was idleing (shuttering) what could this be?
To confirm the exact fault,the error code stored in engine computer module has to be retrieved.
But as why check engine light came up,for that issue there are few help link with solutions to correct the issue.========
Click the link below:---
After getting car washed, check engine light is ON and key less entry not working, tried reprogramming. Also car shows fuel pressure? http://schematicsdiagram.blogspot.com/2011/12/after-getting-car-washedcheck-engine.html
------------How to Read Codes from Check Engine Light? http://schematicsdiagram.blogspot.com/2011/12/how-to-read-codes-from-check-engine.html
------------Check Engine Light Reset Procedure? http://whoisbyme.blogspot.in/2012/06/check-engine-light-reset-procedure.html
------------- Check Engine Light ON? http://whoisbyme.blogspot.in/2012/06/check-engine-light-on.html
----------- Intermittent Check Engine Light? http://whoisbyme.blogspot.in/2012/06/intermittent-check-engine-light.html
---------- Service engine soon Light Turned OFF after Jump Start? http://whatisbyme.blogspot.in/2012/06/service-engine-soon-light-turned-off.html
---------- 2005 Chevy Impala: Service Vehicle Soon Warning Light? http://whoisbyme.blogspot.in/2012/06/2005-chevy-impala-service-vehicle-soon.html
--------- Malfunction Indicator Light ON http://whoisbyme.blogspot.in/2012/06/malfunction-indicator-light-on.html
--------- Car jerks while going uphill and Check engine light is ON?
Toyota Camry Check engine light flashes while driving? http://schematicsdiagram.blogspot.in/2012/02/toyota-camry-check-engine-light-flashes.html
----------1999 Toyota Tacoma: Check Engine Light Read Code P0171?
2007 Toyota Highlander Hybrid: Yellow Check Engine Light ON dash? http://whatisbyme.blogspot.in/2012/05/2007-toyota-highlander-hybrid-yellow.html
--------Check engine light with codes P2195 and P2197? http://howtobyme.blogspot.in/2012/01/check-engine-light-with-codes-p2195-and.html
---------Car Runs Fine But Check Engine light is ON? http://whatisbyme.blogspot.in/2012/05/car-runs-fine-but-check-engine-light-is.html
----------After replacing throttle body the Check engine light starts blinking? http://technoanswers.blogspot.com/2012/01/after-replacing-throttle-body-check.html
---------OBD Code is cleared but check engine light will not RESET? http://schematicsdiagram.blogspot.in/2012/02/obd-code-is-cleared-but-check-engine.html
--------These will help.Thanks.
6helpful
2answers
EML light went on. What is this?
Engine Management Light, same as a Check Engine Light... simply means a sensor component on your vehicle is malfunctioning You'll need to have someone with a tester to run diagnostics and retrieve codes to find exactly what the culprit is. Don't be surprised if it's the Throttle Positioning Sensor (TPS), common problem on BMWs
Jun 07, 2009 • 2001 BMW Z3
1helpful
3answers
Engine block amber light
sounds like your check engine light is on. On 99ish 3 series the check engine light was an amber engine in the instrument cluster. I thought 5 series actually said service engine soon. If you cycle your key the bulb check should illuminate all lights. see if you have a light that says service engine soon, if not, the amber engine, is the check engine light.
Top Ford Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Ford Expert? Answer questions, earn points and help others
