Question about Frigidaire Refrigerators
I have a frigidaire RL6003B - it is running all the time and the thermostat appears not to be working. Is this likely - the cost of a replacement thermostat compared with a new fridge is a good part of the price
  • Frigidaire Master
  • 5,568 Answers
If the temps. seem normal, it is probably low on refrigerant. If it is freezing the milk and wilting the salad, then the thermostat has died.
If in the US, you might check with Johnstone Supply to see if they stock the thermostat used in your fridge; they are basically wholesale but have never asked for a business license and their prices range from 20-50% of dealer costs and the thermostats are only made by a few companies, they are not proprietary.
Posted on Jul 19, 2008
How do you test a frigidaire thermostat / heater
A frost free refrigerator must defrost itself.
it appears that you have a bad component in the defrost system. first try to advance the defrost time into "defrost cycle" if it start to defrost, replace the timer, if not, replace defrost heater and thermostat.
Dec 22, 2014 | Frigidaire Refrigerators
Can you please tell me the best way to defrost a Fridgidare RL6003b?
That question comes up many times here, so I wrote a tip about how to defrost your freezer
How toDefrost a Freezer
heatman101
Sep 01, 2011 | Frigidaire FRS23F4C Side by Side...
Frigidaire RL6003B Fridge - running constanly
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 14, 2011 | Frigidaire Refrigerators
It quit running and everything thawed. It's got electric going to the dial. plugged it in and can't hear anything running.
The power coming into the fridge goes to the thermostat and when it's time for cooling the thermostat tells the compressor and other components to come on so it has to be the thermostat..Does the light insinde the fridge work? If so i would replace the thermostat and it should fix the problem!!!
Nov 06, 2009 | Frigidaire 12 cu. ft. / 340 liter Upright...
For a couple of days now, my Frigidaire RL6003B small fridge ,the compressor keeps running all day and night and does not switch off. I have felt the compressor and it very hot. The fridge seems to be...
it is possable that a thermostat or sensor is faulty or perhaps the compressor is low on gas you will probably have to call service engineer
Sep 27, 2009 | Refrigerators
Frigidaire Ultrafreeze upright just stopped working
It sounds as if your compressor it's running. This could be a bad compressor, bad capacitor, bad thermostat. See that there are no fans or defrost, it is one of the other. I would start with checking the capacitor. You can replace it with a Supco 3 in 1. It cost around $30.00. Anything else is going to start costing $100.00 and more. If you need a freezer that big, I would have it fixed unless it ends up being the compressor.
Please rate solution
Sep 04, 2009 | Frigidaire 12 cu. ft. / 340 liter Upright...
Running to much and freezer to cold. Thermostat was just changed
This is under warranty. Just call Sears back and they will come out and fix it for free.
Apr 20, 2009 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire freezer not working
The thermostat may have shorted out so that it is no longer making contact to put power to the compressor. After drying out the components try bypassing the thermostat and see if it will start or make any sound whatsoever. If it does start and run with the thermostat bypassed replace the thermostat. 4-6 inches of water can also get to the relay on the compressor. Replacing the relay and over load assembly also be a good idea.
Sep 13, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
We have water accunulating at the bottom of our fridigaire RL6003B fridge
is there a gulley towards the bottom of the back wall with a drain hole in it?
if so, this drain is blocked. push something flexible down the drain till water flows away freely
Sep 07, 2008 | Frigidaire Refrigerators
Frigidaire Gallery Side by Side - Fridge not cooling
Locate the defrost timer and rotate the dial a small amount clockwise. If the compressor starts the timer should be replaced. If the compressor does not start check the temperature control. It may be bad, if it is bad try jumpering the thermostat wires. If it starts and runs the thermostat is bad. Replace the thermostat.
Mar 30, 2008 | Frigidaire FRS26ZSG
Refrigerators Logo
791 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
